e2_loadepg stopped working
Dreambox information exchange on the best dreambox software images and help with all other operational problems with your Dreambox. The ultimate Dreambox satellite TV support forum.
Old 2 Weeks Ago   #1
shumifan50's Avatar
My System: 2xDM7025(DVB-S tuner), DM600SPVR, DM800S, TM9100, Triax 90cm with MultiBracket 4 sats.
When I tune to hip hop it does not clear. Anybody else have this problem? This causes e2_loadepg to fail as it cannot read the epg.
shumifan50 is offline   Reply With Quote
Old 2 Weeks Ago   #2
tomthebomb1968's Avatar
My System: Dreambox 800 Nabilo Blackhole v1.0/250 Gig/ Dreambox 500s-(clone) PLi Jade/ Relook 400s 160 Gig-/SifTeam 1.93 e enigma Foretec 90cm Dish with Nikkai Diseqc Motor- 2 sky+ receivers fixed 28.2 east.
You can use IEPG 1 instead of Hip Hop. Just change it from a data channel to a tv channel with Dreamboxedit. Its FTA background music on the same transponder as Hip Hop. Carries the data stream.
tomthebomb1968 is offline   Reply With Quote
Old 2 Weeks Ago   #3
shumifan50's Avatar
tomthebomb1968
Sorry I don't know how to dothat, could you help a bitmore
Old 2 Weeks Ago   #4
Use Dreamboxedit to ftp your settings to the pc. Look for Data channels on 28.2 . Highlight the IEPG1 channel. Right click on it and click on the "Change to tv type" Then Just add it to your epg boquet and if the loader is set to auto download it wiil when you select the channel.
Heres my own with it in it if that helps.
The Following User Says Thank You to tomthebomb1968 For This Useful Post:
shumifan50 (2 Weeks Ago)
Old 2 Weeks Ago   #5
shumifan50's Avatar
Thanks for that.
Unfortunately I use Gemini so it is not quite as automatic as Nabilo. But by inserting the "EPG background audio" into the bslybsat.conf file, it seems to have fixed the problem. Just waiting to see if it updates correctly. Note: I did not have IEPG 1 channel in lamedb.
This could be the start of the blackout tho.
Old 2 Weeks Ago   #6
Mine is downloading from both the fta and hip hop still
Old 2 Weeks Ago   #7
shumifan50's Avatar
Is your hip hop now nd$? Maybe the download works even if the channel does not clear? I am just used to the channel clearing.
It is now working fine again - thanks for your help.
Old 2 Weeks Ago   #8
Dreambox Gimp & Coder
B16MCC's Avatar
My System: 2 Dreamboxes ------ DM 8000 HD PVR ------- ---------- DM 800 HD ---------- -------- Motek SG2100 -------- ---- Triax 80cm Dual LNB ----- -- Fixed Dish 28e Quad LNB -- ---------- Sky HD Full ---------- ------- 24" Apple iMAC --------
Creator of the CCCCC - only a true wizard could come up with such a name!!
Guys I have sly world full card and I still don't clear hip hop, must be a premium channel for some strange reason. However I still get EPG from it and always have done.
There are 10 types of people in the world. Those who understand binary and those that don't.
Check Out My Blog :- Dreambox Utils For Windows
Best Regards, Your Friendly Dreambox Gimp.
B16MCC
B16MCC is offline   Reply With Quote
Old 2 Weeks Ago   #9
shumifan50's Avatar
It used to clear, but I did not look to see if it was encrypted before. Now it is definitely encrypted and does not clear
Old 2 Weeks Ago   #10
Yeah I have full Sky package and it only cleared with a share but it did grab the data stream. Think it must be part of music extra option. But i did have trouble with it freezing the box in the first versions of blackhole with the epg grabber. Thats why I used IEPG1.
Old 2 Weeks Ago   #11
B16MCC's Avatar
I just grab a ready made file now using the SatMan link in BH0.12. I've never seen a sly UK EPG populated as well as that one is. I haven't found anything missing yet.
B16MCC
Old 2 Weeks Ago   #12
Yeah, using that one now myself. Having trouble with 0.12 crashing for no apparent reason after 4 or 5 days use. Well strange. Only thing I downloaded was Armys Ghost HD skin. Have reflashed 4 times since it was released and it never generates a crash log. Just freezes as the boot up screen changes from booting to Starting Enigma 2 where the spinner kicks in. No spinner appears and box is locked up. Havent put Armys Ghost skin in this time and been running for 2 days now so fingers xxxxed. Though that skin is the default on 0.12 for 8000 so its probably not that thats causing it.
Old 2 Weeks Ago   #13
andel's Avatar
My System: DM800 Panasonic 42" Plasma 1080p Pioneer VSX-LX70 Amp Sky HD B & W 5.1 Speaker Setup Popcornhour Media center Xbox 360
so are you saying that with this method you no longer have any gaps in your epg?
andel is offline   Reply With Quote
Old 2 Weeks Ago   #14
Yes very few gaps. Almost everything even fills the interactve channels with the correct games on champions league nights and football first on Saturdays.
Old 2 Weeks Ago   #15
B16MCC's Avatar
Yep, I've just written my bouquets exactly as they are in a sky box and I have no gaps at all. The extra stuff like Setanta ireland is filled too. It also populates sly italia calcio channels, but they're dark at the moment ofcourse.
B16MCC
Old 2 Weeks Ago   #16
compufunk's Avatar
My System: DM 600-S, AB IPBox 9000HD, Moteck SG2100, Fracarro Penta 85 dish, + some puters
Hi B16MCC,
I dont suppose you have a link to this ready made file? It would be handy for my AB IPbox 9000.
If you had a link, I could schedule the box to grab the file at specific intervals.
I'm going to be really cheeky now and ask if you wouldn't mind sharing your Sky UK bouquets. I have some made up, but they are far from complete.
Regards,
C
compufunk is offline   Reply With Quote
Old 2 Weeks Ago   #17
B16MCC's Avatar
I'll check in the nabilo EPG setup panel, I think I can see the path to the file in there.
I'll share my bouquets no problem mate but I'll make a new thread to keep it more relevant. I'll upload them later when I get home.
B16MCC
The Following User Says Thank You to B16MCC For This Useful Post:
compufunk (2 Weeks Ago)
Old 2 Weeks Ago   #18
_http://hqsatellite.com/satmate/skyuk_epg.dat.gz
Is that what your looking for mate
The Following 2 Users Say Thank You to tomthebomb1968 For This Useful Post:
B16MCC (2 Weeks Ago), compufunk (2 Weeks Ago)
Old 2 Weeks Ago   #19
compufunk's Avatar
Thanks very much Tom, that's what I was after.
e2loadepg, stopped, working
