DreamBox DM5620 vs DM7000? | |
| | #26 | ||
| Specialist Contributor Join Date: 27-04-2004 Location: NW England
My System: Dreambox 500, Dreambox 600PVR, Dreambox 7025+, Dreambox 7000, 1m dish on a Moteck SG2100 | Well it's arrived!! Dreambox 7000 that is.Only trouble is I am stuck here at work until 9.45PM I hope there are no dibble on the moterway going home Neil | ||
| | #27 | |||
| Regular Member Join Date: 01-06-1999 Location: moon
![]() I am running the latest hydra7000_atlantis img and seems quite nice. u might want to go back to rdgd5 though. tsd
__________________ Life's short, go hard, rest when youre dead. | |||
| | #28 | ||
My System: Dreambox 500, Dreambox 600PVR, Dreambox 7025+, Dreambox 7000, 1m dish on a Moteck SG2100 | @theslydog Thanks for the suggestion of the hydra image. It is working ok as far as I can tell so far. Just trying to get all the sats set up. I thought this box was supposed to find the sats and channels on it's own. I am using an SG2100 HH mount straight out of the box and it supports goto function. I must be doing something wrong LOL. Neil | ||
| | #29 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | If you enter your coordinates it should find the sats.
__________________ | |||
| | #30 | ||
My System: Dreambox 500, Dreambox 600PVR, Dreambox 7025+, Dreambox 7000, 1m dish on a Moteck SG2100 | I thought so but it did not seem to move the dish while searching for transponders. It must be me. | ||
| | #31 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | You need to select the sats first, otherwise it would look for everything in the list.
| | #32 | ||
| You might also have to mannually move the SG2100 to 0 deg, reset it and go from there. U think ur having fun now...wait till u try to work out the conf files for xcam, newcamd, evocamd plus and the like...
| | #33 | ||
My System: Dreambox 500, Dreambox 600PVR, Dreambox 7025+, Dreambox 7000, 1m dish on a Moteck SG2100 | When I send the goto zero command from the dreambox it does goto zero. I programmed a couple of sats manually 1 west and 13 east using the goto position number that is pre stored in the positioner and only had to fine tune position a little. Maybe I should have sent the goto position 1 west first. Then adjusted dish for best signal. The odd thing when I try and search for mulitiple sats is the box just sits there saying searching for transponder but never tries to move the dish. When it has searched all transponders it just says it could not find anything. Maybe I will clear flash (again) and start again. I will reset positioner as well. I like the SG2100 because it has a button on it for moving the dish while up the ladder. Good for seeing if the dish will hit the wall. Mine is an old 1m Lenson Heath on 18" T&K's so it is clear for full motor movement. Neil | ||
| | #34 | ||
| The Consumate Dreamer Join Date: 01-01-2000 Location: Somewhere where the Sauer is Kraut and the Wurst is Brat
My System: I bet on red. If I lose, I double the bet on red again. I continue with this until I lost everything. ![]() Muhuhuhahahahahaaaaarrrgggh | Hi Bonechops There are sometimes problems with the sat finding with "improved" images. What I do is to find one sat with a good reception, and manually move the dish until I get the best signal. Don't forget to store the position, then do an automatic transponder search just on that one. Afterwards, I go to motor setup, choose the next sat I want to use and manually move the dish and so on. As long as I save the positions it will always find it. I know it can find it on its own, but it drove me crazy with some images. Even though it is a bit more work it does work. Don't forget to save all your settings with Llama afterwards, so if you have to put in a new image you won't have to rescan everything again. Another interesting feature to use is the Satellite XML loader plugin. You have to be connected to the internet, and it askd you to choose which sats you are interested in. It then automatically downloads those directly from Lyngsat. So then you only have a smaller number of sats on your list, and that makes using some of the features easier.
__________________ I only believe stuff that comes straight from Mr. Horses mouth | ||
| | #35 | ||
My System: Dreambox 500, Dreambox 600PVR, Dreambox 7025+, Dreambox 7000, 1m dish on a Moteck SG2100 | I will have to try that. The box connects to my router so it is online. I might install an official image. Try the sat find then save settings and reload the hydra7000 I am trying Neil | ||
| | #36 | ||
| Member Join Date: 12-07-2004
| Can any confirm whether this is true. http://www.satellitecentre.co.uk/ is selling a Dreambox 7000S with built in Dragon Cam and X-Cam for £275 inclusive of P&P. I presume built in means both the CI slots are used up. Many thanks. JH | ||
| | #37 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | The DB has them onboard, this is no different from any of the other DBs on sale, you can get the same model, but with a 120GB hard drive for £305 from somewhere like hm-sat.de.
| | #39 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Sorry, don't understand, what or who is Lawrance?
| | #40 | ||
| Re: #37 Thanks rolfw. I finally get the concept of the DB - built in cam is software driven. Shame on me coming from an IT support background. I think it has to be DB 7000S but will get the HD in the uk (120gb WD 5400rpm - £45). Still need to read up on the 5400 vs 7200rpm HD. I know that Hitachi and Samsung 7200rpm drives are very quiet and cooler than other brands. Will check compatibility. JH | ||
Similar Threads | ||||
| The Ultimate Idiot Guide! For Idiots, by Idiots!Answers,Questions,Tips & Tricks,RTFM! | T_G | Dreambox Guides, Stickies and FAQs | 48 | 1 Week Ago 11:38 PM |
| Force vs. DreamBox | morten | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 5 | 30-01-2005 01:56 PM |
| Dreambox? | madman | Digital systems | 7 | 28-02-2004 11:44 PM |
| X-Dream TV - erotic for Dreambox | net1 | Daily Satellite and Broadcast industry News | 0 | 10-11-2003 06:51 PM |
| dreambox 7000s | imthedaddy | Digital systems | 1 | 03-11-2003 10:36 AM |
