DB loop through | |
| Specialist Contributor Join Date: 15-11-2004 Location: austria
Hi all, I have the sat cable going to the DB , and then from the loop through of the DB to my digibox. So, when the DB is powered off I can watch TV on the digibox. this works fine. But, when I want to watch DB I must have the digibox plugged out (ie, not in standby). This is a pain, as each time I plug the digibox in again it must scan for channels again. With the same setup, but using an FTA box instead of DB all works as it should. any comments? cheers. | ||
| The Consumate Dreamer Join Date: 01-01-2000 Location: Somewhere where the Sauer is Kraut and the Wurst is Brat
Blog Entries: 4 My System: I bet on red. If I lose, I double the bet on red again. I continue with this until I lost everything. ![]() Muhuhuhahahahahaaaaarrrgggh | Hi Wally I am not sure why it does this...I got the sat going directly to the DB, and from there to my computer. I can actually watch both at the same time provided it is the same channel/transponder. i do turn off the dreambox though when I want to switch the motor to another sat using the PC. Have you tried putting the digibox in standby and then turning the Dreambox off/on? Also, try the cables the other way round, first Digibox then Dreambox..... | ||
| | #3 | |||
| Specialist Contributor Join Date: 06-09-2004 Location: NW England
My System: 7000S - 300GB Maxtor 1GB USB - Syslink wifi bridge from DB to Syslink wifi router to Apple Extreme streaming relay to Apple G5, 2 xG4. Elgato into G4 17 in for Apple DVB-T captures. Panasonic 42 HD ready Defeater of Dragonii Teqnicali |
What are symptoms Do the DB and digibox sit on top of eachother? Even in standby the digibox is up to all sort of tricks and the tuner is active. There might be some IF feedback if they are too close. I have had that before. Do some elimination. Pull lnb cable out of digibox. No fault? Then trouble is either feeding back up the IF cable or radiated. Try a splitter to give one feed to DB and slave to digibox. This stops lnb voltage from digibox getting to IF O/P of DB. If still trouble then its radiated. Separate the two boxes by as much as you can, preferably metres. With digibox on and trouble, can you log in to DB, i.e. does processor still work. If not possibly being zapped by a radiating clock crystal in digibox. | |||
| | #4 | |||
| Super Moderator Join Date: 24-08-2003 Location: Dublin....Ireland
My System: Dusty Dreambox 7000s, & Sky HD. |
the technomate cable again, just to see if it would happen again and it did about a week later. So now it just back in the S*y dish again. Dont think the digibox likes to be messed around with, Or maybe it just likes its own lnb. | |||
| Happy Dreaming | ||||
| loop |
Similar Threads | ||||
| Local Loop Unbundling - questions | BGonaSTICK | The Meeting Place | 1 | 03-02-2006 10:39 AM |
| twin lnb output or use loop? | pothead13 | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 2 | 28-08-2005 03:13 PM |
| Skystar and loop through | brewby | Satellite PC Card Receivers & Internet by Satellite | 0 | 02-05-2005 08:36 PM |
| Force 1122s loop through | kyliesat | Digital systems | 2 | 25-05-2004 11:33 AM |
| 2 Digital recievers loop through+Diseqc 1.2? | steffan_st | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 2 | 02-04-2004 09:42 PM |
