Re: TS to DVD (MPEG)Dreambox information exchange on the best dreambox software images and help with all other operational problems with your Dreambox. The ultimate Dreambox satellite TV support forum. | |
| Regular Member Join Date: 11-05-2004 Location: South East Midlands
My System: Technomate 9100 and 90cm dish motorised |
Thanks for the idiots guide on how to do this. I have yet to buy a dreambox, still considering it. Might go the DVB PC card route... not sure what to do. Anyway how long would you estimate it takes to create a DVD from a TS file? Is it time consuming, or ok? Would it be just as easy to go and buy a standalone DVD recorder, what are the advantages of doing it the PC way? | ||
| | #2 | |||
| Specialist Contributor Join Date: 06-09-2004 Location: NW England
My System: 7000S - 300GB Maxtor 1GB USB - Syslink wifi bridge from DB to Syslink wifi router to Apple Extreme streaming relay to Apple G5, 2 xG4. Elgato into G4 17 in for Apple DVB-T captures. Panasonic 42 HD ready Defeater of Dragonii Teqnicali |
If you got yourself a DVD recorder then you would feed RGB from decoded signal into recorder and the asics in the DVD recorder will do all the digitising and recompression back to mpg2 and make a DVD complaint disk. Although this route has done mpeg -> expansion -> RGB -> digitisation -> mpeg, you will hardly note the difference. It is foolproof. But if you like playing with toys, like I do, then you can transfer the files on dreambox hdd to PC or Mac. This can take an hour but you can leave it while you do somethign else. Then you convert .ts to .ps and maybe edit top and tail. Then author DVD, then burn. It sounds a lot but I will set things going, go to work and continue when I get back. So you can't count time really. But I have 30+ movies on hdd and I will pick maybe one or two to burn to keep. The rest I keep to watch and then dump. Essentially, the hdd, say 300GB, becomes a very useful and tidy store of movies to watch when you like. I no longer burn and keep movies I will never watch again. | |||
| --------------------------------------------------------- I'd like to live in Manchester, England. The transition between Manchester and death would be unnoticeable. Mark Twain. --------------------------------------------------------- | ||||
| Ding Dang Doo Join Date: 31-01-2004 Location: Scotland
My System: DreamBox 7000s - Nokia Freeview - Several GameBoys - DS Lite - ZX81 - SNES - N64 - Sega Saturn Dreamcast - PlayStation - Gamecube - PSP - iPod - iPhone - XBox - PS3 - Wii - No Life! | It does take a bit of time depends on processor speed - burner speed. The quality of the DreamBox recordings is excellent. You could just transfer and watch the .ts files on your PC without conversion, that's faster. In short it's not any slower that backing up a DVD. | ||
My System: Technomate 9100 and 90cm dish motorised | OK, thats not too bad. I had thought all the conversion involved with D to A then A to D again using a standalone DVD recorder might lose quality. Whie I have been off surfing I have found something even more exciting. There is talk of a new dreambox, the 7085 which has twin tuners and a DVD writer/player built in. It has more memory and a seperate PSU, supports up to 300GB HD! Even talk of it having different tuners eg 1 for DVB and the other for D Terrestrial. Specs and pics here http://www.olmi.cz/ Talk here: http://www.austech.info/showthread.p...7&page=2&pp=15 Anybody know when this is going to be available? Sound like a dream come true, pardon the pun. | ||
| | #5 | ||
| Specialist Contributor Join Date: 24-07-2004 Location: Kent
| If you have a skystar 2 card then you can more or less record the TV to the hard drive and burn the captured file to DVD, no conversion nessisary in the most part. I dont have any problems with two cheap DVD players, its just my expensive sony one that is fussy. If you use ProgDVB then it doesnt seem to work properly on the Sony, meanwhile DVB Dream does. Basically record the file, import it in to something like TMPGenc DVD Author if you want to make a menu system, or even VobEdit if you dont. Very quick, the quality is gonna be the same as the dreambox because they are both just recording the data direct from the satellite, so no loss in quality. | ||
| | #6 | |||
Your guess is as good as anyones. Should have twin tuners(updated) and can handle six streams at once - by all accounts. | |||
| | #7 | |||
| dvd, mpeg |
Similar Threads | ||||
| Informaion on DVD recorder formats | JonnytheKid | The Meeting Place | 0 | 30-08-2004 06:48 PM |
| First European HD DVD | net1 | Multi-receiver/TV systems - Domestic only | 0 | 07-04-2004 08:16 PM |
| Chinese DVD Pirates | Shahid | The Meeting Place | 3 | 09-09-2003 07:36 PM |
| Raw MPEG from a Sky Box | panash | Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 3 | 13-08-2003 12:14 PM |
| Ezdvbxl 2.5 Main feature DVD playback with some bugfixes etc | Big Ted | Satellite PC Card Receivers & Internet by Satellite | 0 | 16-03-2003 02:06 PM |
