var 97 percent full ?Dreambox information exchange on the best dreambox software images and help with all other operational problems with your Dreambox. The ultimate Dreambox satellite TV support forum. | |
| Regular Member Join Date: 26-10-2004 Location: uk
| I thought i cracked my sticking dm problem by mounting my hardrive but after a few days i had a nasty message which said 97 percent full in var ,can anyone tell me why ,does this mean that it is using my hardrive for some bits and the dm memory for another ,reply would be g8 rhurbarb | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | I had the same problem, but couldn't remember how to move var across to the USB stick, I seem to have solved the problem by going into Hydra control panel, then addon setup and Setup addons to USB stick, in your case hard drive. | ||
| | #3 | |||
| im so sorry sounding simple but you can put everything on your hardrive then? .i also have a usb stick if that is a better option rolf, with thanks rhurbarb
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Yes, the USB stick is better, as the DB doesn't have to work the hard drive to see the addons. | ||
| | #7 | |||
| Td i got flash wizard ,explain that again lol m8 cheers rhurbarb
| | #8 | ||
| . Join Date: 21-12-2004 Location: .
My System: . | Hi rhurbard, Right, here goes, this is what I'm running at the moment and it works fine for me. (You can put images on your HDD instead if you wish). 1. Using FlashWizard 5.0, install un-modified image '1.09 beta CVS 11/02' in DB internal flash memory. (Enter setup info and sat scan or upload saved settings from a 1.08 image). 2. Plug USB memory stick (128MB to 512MB) into DB USB port. (Not for HDD) 3. Format and mount the USB mem stick either from the flash image (can be best for first time format) or with FlashWizard 5.0. (Not for HDD) 4. Select 'Install Image to Multiboot' on FW5.0 and let it install the 'Multiboot menu' on the DB. 5. Click the folder icon in 'Install Image to Multiboot' and browse to your first 'modified' 1.09 image (Hydra Phoenix, Gemini 106, DBF Revolutions 3.1 or W.H.Y). 6. Follow prompts to 'Name' and install the image to USB (or HDD/NFS). 7. Close FW and reboot DB. 8. You will see the multiboot menu on TV screen as DB boots. Use Up/Down on remote to highlight required image and OK to boot that image. Within a short time it will boot to default image if you take no action. 9. With your multiboot image running you can download emus etc as normal but with loads of /var space! (Settings will already be there copied from the fash image by FW5.0 so no setup to do just straight in to use image!). 10. Start FW5.0 and add another image to USB (or HDD/NFS) multiboot whenever you want! NB. a. Once you are using multiboot you do not do 'flash erase' after installing images. b. If a multiboot image freezes or fails to run properly and a reboot to the same image does not cure the problem. Then reboot to a known working image and use FW5.0 to remove the problem image (sometimes a re-install of that image sorts out a problem multiboot image). No need for the null modem cable! It's easy, give it a try. Lets know how you get on? 73 & good luck. | ||
| percent, var |
Similar Threads | ||||
| Problem with full x 3 on astra | cableman | Adult satellite channels | 1 | 27-12-2005 03:04 PM |
| Michelin, full refund US Grand Prix tickets... | gameboy | Jimbo's Football and Sport | 1 | 29-06-2005 01:25 AM |
| Freeview owners rule out full return path for service | net1 | Terrestrial Television, Digital and Analogue | 3 | 18-12-2004 07:09 PM |
| IRDETO & VIACCESS full desc. | heri_1998 | Cams and decoders General | 1 | 08-10-2001 07:51 PM |
