Sly Uk + Sly Italy+gboxDreambox information exchange on the best dreambox software images and help with all other operational problems with your Dreambox. The ultimate Dreambox satellite TV support forum. | |
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | I have seen posts by people who have, but as far as I know, it is only able to accept the card as a CAM emulator, so as yet not causing a real danger to nds. | ||
| | #3 | |||
| Regular Member Join Date: 18-11-2003
Hi Rolf, you're up late. New from Dr Hans below, I think this is not a splitter but a sharer, not sure. Anyway, I aint buying with VR3's and OPUS around. Shame about Taq x though. Ah well. March 12, 2005, 11:01 am NEWS *V1DE0GU4RD cards can now be shared with the "non-public" emulator gbox. This goes for both ***Italia and ***UK. It would be silly to refer to gbox as non-public since everyone probably has downloaded this emulator at this point from various places that chose not to respect the author's wish, which was not to distribude this emulator in public. I do not have the opportunity to test this emulator but the internet is full of step-by-step instructions on how to get it to work. *DIGITAL+ will probably temporarily stop Taquilla services on March 21. When Taquilla's resume they will most probably continue in Nagravision only. The pervs are already being asked to consume all their TQ X credits before 21.3.2005. | |||
| | #5 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | I have no doubt that it works, but it really doesn't do much apart from allowing you to move your legit card from your digibox to your dreambox, a backward step from my viewing point of view, as I have a Sky+. Did have a look at the installation instructions and even the properly translated ones, have info missing, or assume knowledge and are not particularly clear. As is often the case, people who have the greatest technical ability can be pants at describing what they do in terms that the layman can follow. | ||
| | #6 | ||
| Retired Moderator Join Date: 22-12-2003 Location: Brighton
My System: Dreambox 7000, Skystar2 | Well Rolf, you may be right in terms of functionality, but in terms of profile I have it right up there with the opening of S2! Looks like I might finally be able to get rid of that hunk of junk under my TV at last! | ||
| | #7 | ||
| Member Join Date: 23-12-2004
this how to is from other forum, the orignal writing is italian and was translate to english by babilon , the translations is not very good GBOX How-to Miniums - to copy the rows gbox (to use gbox135.crack rename in gbox) in/var/bin via ftp - to change attibuti the to the rows gbox in var/bin/with "chmod 777" - to copy via ftp in var/keys the files gbox_cfg and cwshare.cfg - if they are not present in var/keys, to insert also the several one files rom*.b, s2*.b (beyond to the classics soft*.cfg etc etc) - to open the rows/var/keys/gbox_cfg Z parameter to put the IP of dreambox the Z: { 01 11 } 192,168,0,24 23 to put the IP of dreambox the parameter Or Or: { 00 } 192,168,0,24 to put the IP of dreambox the parameter L L: { 00 } 192,168,0,24 23 - to save and to close the rows. Activation of the GboxKeyGen.exe program: - launch reg.bat (only before the time) - launch GboxKeyGen.exe - in the box serial to insert the number card (es.: if the n. card it is 0001,2345,6789 to remove the zeri and the last number, that is the 9); we obtain the number: 12345678; to use the scentific calculator of windows, to insert the 8 figures and to convert them in esadecimale; we obtain sequence BC61Ê, we add in front of the sequence a pair of zeri (00 BC 61 Ê). This sequence goes inserted in the box "Serial" of the GboxKeyGen; we press the key "Generated NDS ROWS"; in the blue part one serial of codes will appear. - fairies copy-glue in rows of name nds (without extension) - you take the rows as soon as created nds and mettetelo in/var/keys - activated the emu on the img prechosen Connected the your smartmouse/phoenix (set up like smartmouse to 3.57/58 MHz) on the seriale of the DB with a normal seriale cable (pin-to-pin) and inserted smartcard the NDS to you. The IP address is not neccessary to change This post has been edited 1 time(s), it was last edited by pippodark on 11.03.2005 20:33 picture of sky italia on a dream box http://www.satnews.it/vbforum/showt...07&page=7&pp=20 | ||
| | #8 | |||
Looks like the file is really public. h**p://www.satnet.ch/file/download.php?id=507 Not tested by me.
| | #9 | ||
I found a better how to Hi! This is a "how to readme" to configure you dreambox and gbox files, so you can watch the NDS encrypted channels in your dreambox. The necessary equipment: 1) Phoenix interface 2) set it at 3,57 Mhz (frequency) 3) you need a straight Serial cable connected direct to the serial port at the back of your dreambox 4) Dreambox 7000-7020-56x0 (obviously) 5) a smart card: Sky NDS (UK, Italy, Viasat) 6) Skybox NDS Receiver (to read the necessary data) Preliminary operations: First we download the necessary files from the internet. Those must contain the following files: reg.bat, crypt2secur.ocx, Gbox***Gen.exe, gbox, gbox_cfg, softcam.cfg Then, we double click on the file reg.bat so the generator will work. Once opened close the new window and then click on the generator. Now we read the data of our NDS card in the menu of the Skybox. We enter the Menu and enter the following number (via the remote control): 4-6-1. That will take you to the Menu page that interests us. We need the serial box id number of the receiver, which can be found in the third line down - it should be a 10 figure number. We then remove the zeros and we convert it to hex format (with the Windows Calculator**[ see bellow]), to obtain the right values. We put zeros in front of the the hex number, so we then have an 8 figures number -> this will give you your boxid no. The same thing for the smartcard serial number: we take the numbers indicated in the last line (9 figures to you) excluding the last one (becomes an 8 figures one) and we convert it to hex. After we add the zeros, so the 8 figures number is your serial number. An example: Seriale 0012345678, Smart card 456975113: 12345678 converted to hex BC614E --> BOXID: 00BC614E 45697511 converted to hex 2B949E7 --> SERIAL: 02B949E7 When you have both sets of numbers copy and paste them into the Gbox***Gen.exe, then press on "Generate" and you should have a series of numbers like the ones below N: 02B949E7 00BC614E 9764A4059B51ED499C0F33F66003CCC9AB9F3E162608145383 2030EE97E2D6012B42A0A600C6B82C 4EAE3800EADA8E616DC52B9C86EC1DFA870481C1A401000182 B4299A0FDE1671F5CB8D61E275CF4E7C73543F4C6A0E8413B 6EE8E7D460A8A9C10902C4324C9FC4947D1B8B1015FBCB4EC7 269C68270B3903087BF8CF3EB0B2BD18C09 Copy and paste them into your NDS file and save, not forgetting to first delete the old one in there.This is now your own NDS file. Installing the hardware: We connect our pheonix interface by a serial cable to the serial port at the back of the Dreambox, remebering to set the Phoenix to the frequency of 3,57 Mhz. It is necessary to put a tick in the Expert Menue of the Dreambox next to "Don't open serial port". The installation of the GBOX EMU to the RuDream image: Copy the file gbox.crack (or whatever it might be called, over 500kb in size) to var/bin folder via an FTP SW and chmod to 755 (i.e. go to File -> Changing attributes and choose 755) Copy the files gbox_cfg and softcam.cfg to var/keys folder. Edit the file gbox_cfg by inserting :"IP address of your Dreambox" in place of the one that's already there. Then copy your NDS file previously created into /var/keys. Now in the folder var/tuxbox/config - edit the file emulsit.xml by inserting the line: gbox "helptext =" "emuadvanced="gbox "emudemon="gbox "help =" "api="3"/> Installation of emu the GBOX in Hydra image: Copy the file gbox.crack (or whatever it might be called, over 500kb in size) to var/bin folder via an FTP SW and chmod to 755 (i.e. go to File -> Changing attributes and choose 755) Copy the files gbox_cfg and softcam.cfg to var/keys folder. Edit the file gbox_cfg by inserting :"IP address of your Dreambox" in place of the one that's already there. Always copy your previously created NDS file to var/keys folder. Edit the file smartcam.config in var/etc. folder by inserting the following lines: osd-name x = GBOX emulator x = Gbox [ v.1.0 P35 ] camd x = daemon x = gbox kill x = sleep x = zap-sleep x = 2 where x are the progressive number of the emu present. How to start the execution: Insert your Sky NDS card to the Phoenix interface previously connected. We start the GBOX EMU by entering in the Menu of the Emu (for RuDream the same as with Hydra) and then press the blue key, then Select it and Save with the green key. Done! Now you should be able to watch the nds programs in your dreambox. ================================================== Disclaimer The author of this document and the situated one that the public one responsibilities are not assumed on eventual damages to the equipment, neither on the resolution of the described operations over. The document does not want sure to be a esortazione to the pirateria, but if not the contrary and is dedicated to all those makes a subscriber SKY to you, regularly payers, that they want to be able to use a various receiver from the Skybox, assuming itself in toto the own responsibilities in relation to guarantee decays, of royalties not paid, etc. etc... E' be written up according to the principle of the information right. The rows specify to you are not present on our serveur and indications on the reperibilità will not be given. | ||
| | #10 | ||
My System: Dreambox 7000, Skystar2 | Indeed. This has been out there for a few days now, and clearly works. The fuss about the author not wanting it released, and various boards not being allowed to discuss it openly is all history now. Go have a ball. Not tried it myself, as I don't have a programmer (yet!). Personally, I think it's great it's out in the open. So what if no further versions are created or released. Someone else can now use the released code to take this forward. The scene has been strangled enough by the profiteers recently. STICK | ||
| | #11 | ||
| Regular Member Join Date: 03-03-2005
My System: 2.40m Solid Paraclipse Hydro Humax 5400Z G-Guard 9600 Dragon cam 3 Jonsa 1.80m | just curious, can any point the sky card stop working with the dream box gbox software. assuming everyone is rushing to get one | ||
| | #12 | ||
My System: Dreambox 7000, Skystar2 | Of course it can stop working. This isn't officially supported firmware! It's likely that $ly will act to kill it off (or maybe even the developer?!), and it's not the sort of development you would chase if you wanted the quiet life. Purely hobbyist stuff. | ||
| | #13 | |||
| Regular Member Join Date: 31-07-2004 Location: Hampshire, UK
My System: DM7000 + 300Gb + Gemini, HH100 Rotor, 0.8m Offset Dish, 0.3db Invacom LNB |
Any recomended card readers out there? Yours have-been-patient-for-a-long-time-for-this... | |||
| Whose been saying I'm paranoid? | ||||
| | #14 | ||
My System: Dreambox 7000, Skystar2 | My understanding is that as long as it can do Phoenix at 3.57 Mhz and has a serial connection to the DB then it should fit the bill. But as I say, 'I ain't tried it'. | ||
| | #15 | ||
| Specialist Contributor Join Date: 17-08-2004 Location: England
My System: Dreambox 7020 Dreambox DM500 Sky Thomsom Digibox StrongSat FTA Reciever 80cm Dish + 45cm Dish via Disecq A/B. | it 100% works. Also it will work until sky issue new viewing cards, do you guys not remember sky working with the old viewing cards some time ago. Being why they issued new ones | ||
| give me money now | |||
| | #16 | |||
| Member Join Date: 19-03-2006 Location: Europe
My System: Dreambox 7000S |
Does anyone know how can I contact the gbox developer? | |||
| | #17 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | The download location is still there, but the file probably isn't, the link is a year old, as is the thread. The whole scene has moved on since then and now Gbox is not the only emulator to take a Sky card. www.satnet.ch/file/download.php?id=507 | ||
| | #18 | |||
| Member Join Date: 30-03-2006 Location: Birmingham
My System: DM 7020S 4 X DM 500S Keyboard |
Works ok! Better than I expected | |||
| | #19 | ||
| Istanbul 05 -Rafazaman Join Date: 23-09-2005 Location: chester
My System: DB7020 ,Gemini 2.9 ,Gbox ,Broadband (Lol) Motorised >30w | As stated in earlier posts , it does work and you can record your Sly programmes. However every so often and then i have to remove my Sly card and insert it back into the Digibox ? it may just be static i will try and wipe my card when it happens again. If you want a copy of my Gbox files PM me and i will send them to you | ||
| | #20 | ||
My System: Dreambox 7020 Dreambox DM500 Sky Thomsom Digibox StrongSat FTA Reciever 80cm Dish + 45cm Dish via Disecq A/B. | there are 2 cases i think in which you would need to put the sky card back in the original box once a month to be sure 1. You are using a multi-room style card 2. You have been subscribed to sky for under 1 year otherwise gbox will update itself | ||
| | #21 | ||
| Member Join Date: 02-01-2007 Location: EU
My System: DM7025 2xDVBS/80cm/1LNB | I can't get my Sky UK FTA card to pass the initiation in gbox. I've tried putting my card and box id into the NDS file in /var/keys. I'm running gb225 from skystar on a gemini2.4 DM7025 in internal slot. 1. Can anyone tell me if the hanging below is related to not getting the card serial and box id right in the NDS file or related to something else? 2. Regarding the NDS file in gb225, do I need to covert numbers to hex etc and do the "old instructions" still apply, ie remove last number add zeroes etc? Thanks in advance! ![]() Here's a trace of what it looks like: gbox 2.25/Linux@Xileon ( May 21 2006, 18:55:02 ) Seasonport=0 speed=9600 OSD (dbox2) IP = xxx.xxx.xxx.xxx Logger init for IP: xxx.xxx.xxx.xxx on port 7777 RS232gate=0 speed=115200 ping time set to 300 sec mode 03 AU:02/update:01/KeyFile:00 Hash:01 DispECM:01/EMM:01 UDPInit:01 OSD:00 Total 46 EMM keys read from nagra.txt enx_conf = 3 ; reset on zap=0 My IP xxx.xxx.xxx.xxx ID xxxx (xxx.xxxxxx.org) pass xxxxxxxx, we are online Total 1 ports to monitor monitoring port: xxxxx CPU ATI Xileon using LinuxTV api3 TPSCrypt 1 PTS 1/1 internal slot1 opened internal slot2 opened mode: any pid have to init card 2 ATR : xx xx xx xx xx REMAINING KEY STRING REMOVED. Reset Baudrate = 9600 Baud NDS Card | ||
| Last edited by Analoguesat; 01-07-2007 at 07:52 PM. Reason: Removing remaining keystring | |||
| | #22 | ||
| Member Join Date: 29-07-2006 Location: England
My System: connected ot hotbird and sky | why bother with hex and card number and box number... just use CCcam , stick the card in and nothing else to do!. unless u have have have to use gbox for something else. | ||
| | #25 | ||
| Super Moderator Join Date: 08-03-2005 Location: J6 M5
Blog Entries: 1 My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini ![]() If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots | Are you asking about CCcam or gbox? | ||
| gbox, italy, sly |
Similar Threads | ||||
| About GBox and Sly. | DHeart | Dreambox General | 10 | 02-12-2005 10:00 AM |
| sly italy??????? | guinness | Keys and Key editing | 1 | 22-04-2004 03:33 PM |
| Large dish suppliers in Italy | nooranismith | Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 5 | 11-03-2004 10:51 AM |
| Southern Italy | jimbodeans | Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 4 | 02-11-2003 07:49 PM |
