Originally Posted by john_graydon Maybe your lnb needs to be changed, what are you using ATM.? |
I am not sure what do you mean with ATM.
The dish is Nokia 80 cm.
and
LNB's are:
1. ALPS - BSTE8-601B with Nf=0.6 dB.
2. SHARP - BSCR86L00 didn't find any specification for this one.
What would help:
Changing dish to a larger?.
LNB's, i was thinking of trying with invacon 0,3 db.
Would it help if i use only one LNB directed to the center of dish?
Another thing is worth
mentioning that i never had a problem with other Digitall receivers with the same configuration and same SCPC channels.
Thanx for trying to help me
