Xvid, DivX etc....Dreambox information exchange on the best dreambox software images and help with all other operational problems with your Dreambox. The ultimate Dreambox satellite TV support forum. | |
| Super Moderator Join Date: 24-09-2004 Location: Rochdale
My System: Sky+ Multiroom,Thompson PVR, Dreambox 7000S, 300gig HDD, 1.1m Dish, Moteck SG-2100A DISEQC Motor, Gemini image, 2g USB Stick. ![]() A defender of the Remote Control Brigade, Sir R can flick channels faster than a Robben dive |
is it possible to play these files from the hard drive? i have a few files, and at the moment i keep converting them to play them.... its a hassle i wish i could get round. on top of that a few of the files go out of sync when converted ![]() there must be a linux media player for this purpose? | ||
| "A Wise Man can see more from the bottom of a well than a Fool can see from the top of a mountain." | |||
| Specialist Contributor Join Date: 12-08-2004 Location: Hampshire, UK
| It was tested but the processor of the dreambox is not up to the task. To get around the problem I bought an Xbox and installed media centre onto it which plays all of my movies from a network share point. The xbox was only £100 from Ebay | ||
| You can lead a Horse to Water but who said it wanted to drink? DreamBox 7000s, Triax 88cm dish Strong Diseqc H-H Motor SRT dm2100 Sharp BS1R6EL100W 0.3 DB LNB Gemini Image | |||
My System: Sky+ Multiroom,Thompson PVR, Dreambox 7000S, 300gig HDD, 1.1m Dish, Moteck SG-2100A DISEQC Motor, Gemini image, 2g USB Stick. ![]() A defender of the Remote Control Brigade, Sir R can flick channels faster than a Robben dive | i do have an Xbox, with a 120gig HD in it... i just thought this would be easier. has the DB is already linked up with the PC think illhave a play about with the xbox.... see if i can get a network working | ||
| | #5 | ||
My System: Sky+ Multiroom,Thompson PVR, Dreambox 7000S, 300gig HDD, 1.1m Dish, Moteck SG-2100A DISEQC Motor, Gemini image, 2g USB Stick. ![]() A defender of the Remote Control Brigade, Sir R can flick channels faster than a Robben dive | i have successfully connected and played a range of media files on the Xbox now ![]() i FTP'ed the files over using FlashFXP, for some reason CuteFTP wont work??? the sofware on the Xbox is EvoX 2.6 | ||
| | #6 | |||
| Regular Member Join Date: 17-09-2004
but I was refering to cifs/samba (Microsoft Shares). for example: (change the ip, to the ip of your xbox) if you type : \\192.168.0.3 in windows explorer, do you get the files in the xbox listed? can you read/write to this shared directory? thanks, | |||
| | #7 | ||
My System: Sky+ Multiroom,Thompson PVR, Dreambox 7000S, 300gig HDD, 1.1m Dish, Moteck SG-2100A DISEQC Motor, Gemini image, 2g USB Stick. ![]() A defender of the Remote Control Brigade, Sir R can flick channels faster than a Robben dive | | ||
| | #8 | |||
I was asking about CIFS/SAMBA.... | |||
| | #9 | ||
My System: Sky+ Multiroom,Thompson PVR, Dreambox 7000S, 300gig HDD, 1.1m Dish, Moteck SG-2100A DISEQC Motor, Gemini image, 2g USB Stick. ![]() A defender of the Remote Control Brigade, Sir R can flick channels faster than a Robben dive | then the answer would have to be, i dont know?? now i have a question, what is CIFS/SAMBA i take it its not a Brazilian dance then ![]() at a guess... going off what you've said, it must be software that enables the Dreambox to view files at another IP address? as i only have one lead from my PC through the floor down to the front room, i can only have the lead in one machine at a time. i will be leaving this lead in the back of the Xbox, until the Dreambox needs updating, for now | ||
| "A Wise Man can see more from the bottom of a well than a Fool can see from the top of a mountain." Last edited by RedDevil_UK; 25-03-2005 at 03:35 AM. | |||
| | #10 | ||
| You can map a drive to the Xbox - the Xbox can run Microsoft windows and a cutdown version of linux giving you full Samba functionality. I run my xbox with media centre with the xbox mapping drives to my server where I keep my films/TV series/Music complete with all thumbnails for the films etc. The quality is better using the Xbox to play movies as opposed to using a TV output card which is another reason for using the Xbox. | ||
| | #11 | ||
| Why dont you buy a hub for downstairs which is what I did. Ebuyer.co.uk £7 for a four port 100mbit hub. | ||
| | #12 | |||
If you use windows (XP for example) and you click a directory with the right button, and you choose properties/sharing/network sharing, then that directory becomes shared your network. if, on another pc, you enter the "\\192.168.0.3" in explorer (like I said in the previous post!!) you get the listing of the contents of the files you shared... basically that's MS networking, also known as SAMBA... | |||
| | #13 | ||
My System: Sky+ Multiroom,Thompson PVR, Dreambox 7000S, 300gig HDD, 1.1m Dish, Moteck SG-2100A DISEQC Motor, Gemini image, 2g USB Stick. ![]() A defender of the Remote Control Brigade, Sir R can flick channels faster than a Robben dive | after looking around the net, it seems anything your PC can play can be streamed to the Dreambox.... using VLC to play a divx for example, can be viewed on your TV, and you dont have to run between your PC and Dreambox either, starting and stopping play is done remotely from your Dreambox remote control ![]() if someone has successfully done this, please help as i am still in the process of getting it to work. | ||
| | #14 | ||
My System: Sky+ Multiroom,Thompson PVR, Dreambox 7000S, 300gig HDD, 1.1m Dish, Moteck SG-2100A DISEQC Motor, Gemini image, 2g USB Stick. ![]() A defender of the Remote Control Brigade, Sir R can flick channels faster than a Robben dive | ive got it to work, but the sync is out slightly ![]() still trying anyone else fancy trying if you get it to work, you can play DVDs and DivX,Xvid.... worth a try | ||
| "A Wise Man can see more from the bottom of a well than a Fool can see from the top of a mountain." Last edited by RedDevil_UK; 27-03-2005 at 01:32 PM. | |||
| | #15 | ||
My System: Sky+ Multiroom,Thompson PVR, Dreambox 7000S, 300gig HDD, 1.1m Dish, Moteck SG-2100A DISEQC Motor, Gemini image, 2g USB Stick. ![]() A defender of the Remote Control Brigade, Sir R can flick channels faster than a Robben dive | for anyone wanting to try it heres a brief guide... Tools needed VLC media player http://www.videolan.org/ Neutrino DREAM image (best image due to a good movie player it has) Multiboot menu on Dreambox Using your favourite software install the Neutrino DREAM image onto your multiboot menu of the Dreambox as per usual Boot the new image and press MENU on the remote control Choose option 4 SETTINGS Then choose NETWORK SETTINGS Enter the following… IP address this is the address of the Dreambox ie 192.168.0.10 Netmask 255.255.255.0 Broadcast 192.168.0.255 Default Gateway this is the address of your PC ie 192.168.0.1 Go back a screen by pressing EXIT on your remote Go into MOVIE PLAYER and then SETTINGS set this up as follows Streaming server IP this is the address of your PC ie 192.168.0.1 Streaming server port = 8080 DVD drive this is the drive letter of your DVD-Rom ie D: Directory (VLC) this is the place where your files are ie C:\Movies Go back a menu again and press the RED button to save the settings (I didn’t first time and had to type it all in again Doh!!) Now onto the PC side of things… Install VLC then even if you already have a shortcut on the desktop, create a new shortcut and call it DB Stream or whatever you like. Now right click the icon and choose properties In the target box enter "C:\Program Files\VideoLAN\VLC\vlc.exe" --extraintf=http making sure that’s the path to your VLC program (you may have installed it somewhere else) apply that and then click OK run VLC from that new icon.. click on file then streaming wizard. Step 1 Click open then browse and choose a movie file (any, you don’t have to play only this file, you can choose a different one from the DB remote later) Choose a file and open it then click OK Step 2 Click choose Click the tick box next to HTTP and enter IP address (the IP address of your Dreambox) ie 192.168.0.10 Port 8080 Click OK Step 3 Click start If your wanting to play a DVD on the dreambox put one in your DVD-Rom now… That’s the PC side of things sorted…. Back to the dreambox With the Neutrino DREAM image loaded press menu and goto the movie player. To play a DVD press the yellow button (DVD) To play DivX, Xvid, Avi etc etc choose the RED button (play via VLC) When you press a button you will be given the chance to explore your pc For a file, you can play any file from here. With a bit of luck when you do choose a file you will see the message buffering and then the movie will play ![]() Good luck | ||
| "A Wise Man can see more from the bottom of a well than a Fool can see from the top of a mountain." Last edited by RedDevil_UK; 27-03-2005 at 03:43 PM. | |||
| | #16 | ||
| Ding Dang Doo Join Date: 31-01-2004 Location: Scotland
My System: DreamBox 7000s - Nokia Freeview - Several GameBoys - DS Lite - ZX81 - SNES - N64 - Sega Saturn Dreamcast - PlayStation - Gamecube - PSP - iPod - iPhone - XBox - PS3 - Wii - No Life! | Excellent post Red Devil a lot of hard work bet it helps lots of users - wish I had a PC | ||
| | #17 | ||
| I tried the VLC plugin with gemini, and it works... but is is incredibly slow... so much that I thought I crashed the DB... for example: After starting vlc in the PC, I start the vlc plugin at the DB... no response for about 30sec... the I get a menu, press FILE.. another 15 sec... press up/down to select the directory... wait another 15sec... press play... wait...wait...wait... zzzZZZZZzzzz... oh... look it's the file I selected... it's playing... yuppy... (with a very low image quality... must say...) | ||
| | #18 | ||
My System: Sky+ Multiroom,Thompson PVR, Dreambox 7000S, 300gig HDD, 1.1m Dish, Moteck SG-2100A DISEQC Motor, Gemini image, 2g USB Stick. ![]() A defender of the Remote Control Brigade, Sir R can flick channels faster than a Robben dive | well this way its quick enough, and the quality is good......but the audio sync is out ![]() but i am playing with the settings, and i was getting closer......but everytime i try to do anything some bugger is watching something on TV. ill get to actually do it about 1am, when everyone's gone to bed just call me knighthawk | ||
| divx, xvid |
Similar Threads | ||||
| DivX | RedDevil_UK | Dreambox General | 6 | 26-02-2006 12:25 AM |
| Divx to MPEG-2 | Johndoe | Dreambox General | 2 | 19-10-2005 12:56 PM |
| DivX and XVid playing on Dreambx | costasd3 | Dreambox General | 1 | 10-06-2005 12:59 AM |
| DIVx to SVCD | PoloMint | Computer Discussion | 3 | 12-05-2003 01:01 PM |
