sly EPG on dreambox
Thread Tools Display Modes
Old 07-11-2005   #1
My System: DM7020 Screambox MAC OSX & windowzz 98SE Gemini 1664 on tap
sly EPG on dreambox
Can I set up a dreambox to get a longer EPG or teletext for the tv guide?
With a sly digibox and FTV card I can view the EPG for the full evening. But when the card is in the dreambox I can only get the EPG for the next programme.
Does anyone know how to get the extended EPG or a teletext tv guide without being on the net ?
whatsthis is offline   Reply With Quote
Old 07-11-2005   #2
RedDevil_UK's Avatar
My System: Sky+ Multiroom,Thompson PVR, Dreambox 7000S, 300gig HDD, 1.1m Dish, Moteck SG-2100A DISEQC Motor, Gemini image, 2g USB Stick.
A defender of the Remote Control Brigade, Sir R can flick channels faster than a Robben dive
id love to know this too.... must admit, the EPG is v.poor on DB
__________________
"A Wise Man can see more from the bottom of a well than a Fool can see from the top of a mountain."
RedDevil_UK is offline   Reply With Quote
Old 08-11-2005   #3
Yes I thought the epg was given by the provider, so how does it work on the sly digibox.
I have found teletext (is that tuxtxt on gemini 2.4) on BBC1&2 and ch5 gives shedule but I can't get the ITVs.
Old 08-11-2005   #4
JTA
JTA's Avatar
My System: Dreambox with PLi-Emerald 1.09 image, Matrix revolution CAS, newcamd emu, movable dish 0.85 m, very happy indeed
install the latest PLi-citrine image. It has MV incorporated with mediahighway EPG capabilities (for dutch/other C+ channels), AND it comes with a downloadable plugin to get EPG data for the main SKY channels. Just download and run. After the first run, don't forget to change MV's input settings, and use the alias manager to map the new channels to your channel list.
JTA is offline   Reply With Quote
Old 08-11-2005   #5
Yes your right JTA but I think you need to have the DB on-line. I don't have an internet connection to the DB and that's why I'm struggling with teletext.
Here is another one I've found if your on the net
h**p://www.spallared.com/epgui/html/epg_for_the_dreambox__eng_.asp
Old 08-11-2005   #6
JTA
JTA's Avatar
it's an internet download (from www.bleb.org ) so yes, your DB needs to be online indeed......
your link goes to the epgui plugin, which I know as well, but which doesn't work with Sky-UK EPG, which was your primary question, wasn't it .....
Old 09-11-2005   #7
could you post the plugin please ? will save us installing a new image
you can find the plugins in
/var/tuxbox/plugin usually
would be great, thanks.
or if not, a link to where i can get this PLI image ? (by pm maybe)
wallycharlo is offline   Reply With Quote
Old 10-11-2005   #8
Back to my original thread. Can we get the sky EPG on the dreambox?
Old 10-11-2005   #9
JTA
JTA's Avatar
I got my copy from http://dreambox.sjerom.com/modules/mydownloads/ - use the appropriate download link at the end of the text !
as for posting the plugin itself, I'll give it a try this evening.
Old 10-11-2005   #10
Then can we get
$ly EPG on Dreambox
Old 10-11-2005   #11
JTA
JTA's Avatar
True Sky EPG : No !
You CAN get EPG info for the main SKY channels using MV with this script. It's not automatic, though, you'll have to download the data manually by running the script every few days.
so everything now depends on your definition of "$ly EPG" .......
Old 10-11-2005   #12
Thanks for your patience JTA - once I get there - there will be no stopping me.
I only have the internet at work so I need to download files onto usb stick and manually put them into the dreambox at home.
I've now got the MV plugin for the gemini image from the ihad site. Once I plug this in can I update the EPG files for sky to see the EPG for the next few days ?
If so where do I get them and where do I ftp them.
Cheers
Old 10-11-2005   #13
JTA
JTA's Avatar
you will need to install the MV plugin first, and make sure it's running OK.
you will then have to install the Sky EPG plugin, which I will post tonight, and install this one. This will give you the EPG files for Sky.
you will then have to modify MV to make it read the Sky EPG files. I will include a small 'readme' file how to do this. And you will have to link the EPG information to the correct channels. You only need to do this once.
When MV shows all the correct EPG information, then you just need to keep your EPG files up-to-date by running the Sky EPG plugin every 2 days.
WAIT A SEC - you don't have an internet connection on your dreambox ! You won't be able to download the EPG files ! I'm afraid that'll be the end of the road for you, as MV cannot extract the EPG information from the SKY data-stream yet.
Old 10-11-2005   #14
and that's what I don't understand. The sly digibox gets the full EPG for the day from the satellite transponder - no internet or telephone line required. This is because the digibox has epg software to do this. So is this software available for the dreambox.
Old 10-11-2005   #15
JTA
JTA's Avatar
As i said before - true Sky EPG : No.
the information IS available, but the dreambox cannot read it. EPG from MediaHighway (Canal+) can already be read, not so for Sky. It'll arrive some day, but until then you'll have to be patient (or connect your dreambox to the internet).
Old 10-11-2005   #16
Cachaceiro
My System: Dreambox DM7025 + 90cm Fibo Dish with Moteck SG2100A mod + Inverto White 0.3dB lnb + 55cm Philips Gregorian + Stab HH-120 + modded BGSat 0.3dB lnb
You need to run a program called 'xmltv' on your work computer. This will download the tv listings in xml format. Then set up mv on you dreambox to use 'myxmltv' and copy the xml file to the myxmltv directory on your dreambox, and press '0' on mv to refresh the data.
You can get more info here: _http://mv.dinglisch.net/
_stu_ is offline   Reply With Quote
Old 10-11-2005   #17
Cachaceiro
I believe Sky use the OpenTV platform to provide the EPG and interactive content. Don't expect to see this on your dreambox anytime soon.
Old 10-11-2005   #18
JTA
JTA's Avatar
okay, here's the SKY EPG plugin as promised. I've included a readme.txt file with all necessary instructions (well, for a dreambox 7000 series anyway, not sure if this will work on a 500 or 7020 but there's no harm in trying).
Old 10-11-2005   #19
JTA
JTA's Avatar
ah - just found an inconsistency in input.txt - I've made a corrected version, please use this one only :
Old 10-11-2005   #20
good stuff JTA, ill have fun playing with this !
yes, i have also heard that sky use openTV. where is the source of the problem in getting the DB to read this info ?
Old 10-11-2005   #21
JTA
JTA's Avatar
I've just realized that the script uses a utility called 'xml2epg' .
I think this comes installed with MV, but just to be on the safe side I've included it in a new, third, package :
Old 30-07-2008   #22
erukus's Avatar
My System: a sky mini dish + a Dreambox 600S with Gemini- 430 and CCcam 2.0.8
hi is the MV plugin referred to here the Multiview plugin avaialbe on the gemini image which is now version 3.5.3
erukus is offline   Reply With Quote
Old 30-07-2008   #23
Irregular Member
compufunk's Avatar
My System: DM 600 PVR with HDD. Gemini 4.50, Moteck SG2100, Fracarro Penta 85 dish, + some puters
Yes,
This thread is way out of date,
Have a look at _http://epg.evolution.project-x.us/index.php
compufunk is offline   Reply With Quote
Old 30-07-2008   #24
erukus's Avatar
do i have to set the file attributes to 755 when i ftp thanks
Old 30-07-2008   #25
erukus's Avatar
also it says ftp to /var/tuxbox/plugins/) but when i use dcc for my dreambox 600 i cant find a "plugins" extension from this. Any help greatly appreciated Thanks
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Forum Jump
