Dreambox information exchange on the best dreambox software images and help with all other operational problems with your Dreambox. The ultimate Dreambox satellite TV support forum.
Firstly I told you to stop shouting in you posts, have editited out the large and bold text.
Secondly, it is a commercial card server and will only allow one connection per login, so if your mate is logged in and you decide to login as well, the server will drop his connection. Either pay the price, or look for another server.
sorry man, am reding ur replies, but in the first reply i didn't got ur point of view, but now i got it ....
Shabani
You are using commercial cardsharing server.Your newcamd.conf file contains data of your server/client for example your password user name your server address and port number provided by your sharing provider.If you give your file file to afriend then only one user can cnnoect to server in one time.You can see your file in notepad or another editer but make no change in file otherwise you will need another file from provider.User information is also stored on server so you can not increase your subscription time
If you have an original card then you can find free groups of card sharing on net.
hi i download gemini 3.60 img in dreambox 500s when i go to download and install open cam it not open error;server replied 404 not found _http://download.blue-panel.com/gemin...al/cam/cam.xml) plz help what i can do?
My System: Dreambox 7020 with 120 gig hard-drive disk - running a motorised dish
DM800 +DM600 +DM500
although only usually the 7020 and 800 are both on.
You have to install version 3.7 at least to get access to Gemini server.
