DCcamd for Prem*ere & MCTDreambox information exchange on the best dreambox software images and help with all other operational problems with your Dreambox. The ultimate Dreambox satellite TV support forum. | |
| Dream-Believer Join Date: 30-01-2006 Location: Guernsey Channel Islands
My System: Dreambox 500s, gemini v3.30 80cm dish 1.0w |
Word is that the Dccamd can open Prem*ere and MCT on the Dreambox. Anyone heard of this?. | ||
| Specialist Contributor Join Date: 06-08-2004 Location: Down South
My System: Dreambox 7020si,SIF 1.9.4- Dreambox 800HD Nabilo BH 0.12 Netgear adsl router, 98cm Funkee on Diseqc motor, Maintaining Hummy 5400 for the old man! | Yes m8 seems to be a version of scam, not got it to work myself with Gemini or Nabilo but many report it working OK | ||
| Super Moderator Join Date: 08-03-2005 Location: J6 M5
Blog Entries: 1 My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini ![]() If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots | DCcamd works fine, no problems at all. | ||
| | #6 | ||
Blog Entries: 1 My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini ![]() If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots | Put the dccamd.tar.bz file into /tmp and did a manual install. Then uploaded the latest nagra2 file (timestamp was about 10pm). | ||
| | #7 | ||
My System: Dreambox 500s, gemini v3.30 80cm dish 1.0w | thanks, where did you get the dccamd.tar.bz file from?. I had a zip with a .ppc file and a scriptfile!!. I ftp'd those files, Dccamd wasn't visible untill I ftp'd the script file?. | ||
| | #8 | ||
Blog Entries: 1 My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini ![]() If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots | You can get it here: _http://www.speedyshare.com/299134127.html | ||
| The Following User Says Thank You to mhku For This Useful Post: | newgen2005 (11-06-2007) |
| | #11 | ||
| The Consumate Dreamer Join Date: 01-01-2000 Location: Somewhere where the Sauer is Kraut and the Wurst is Brat
Blog Entries: 5 My System: I bet on red. If I lose, I double the bet on red again. I continue with this until I lost everything. ![]() Muhuhuhahahahahaaaaarrrgggh | Got it working with Gemini and the Satankeyupdater for the latest keys. Let's see how long it will last though P.S. what are the MCT channels? | ||
| | #12 | ||
Blog Entries: 1 My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini ![]() If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots | I think MCT are ones that make you blind. I'd rather have MTV2 (is it open anywhere else?). | ||
| | #13 | ||
Blog Entries: 5 My System: I bet on red. If I lose, I double the bet on red again. I continue with this until I lost everything. ![]() Muhuhuhahahahahaaaaarrrgggh | | ||
| | #14 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Here's a link to a copy of the tar.gz file for images which don't accept the tar.bz2, plus a few other EMUs. _http://www.hostingserviceall.eu/index.php?dir=7000_EDG/Cams/ | ||
| | #15 | ||
| Regular Member Join Date: 13-01-2007 Location: UK,Sheffield
My System: DM 7025+s-t Raven gemini 70 ,13e,19e,28e 85cm Transparent dish Moteck SG2100 and inverto black ultra lnb. | Just a few question ,do i unrar the files into the folder first,that gives me the var folder with three separte folder in it. How do i get it into the tmp folder ,i have never done a manual download before. Thanks. | ||
| dccamd, mct, premere |
