Electrical fault???Dreambox information exchange on the best dreambox software images and help with all other operational problems with your Dreambox. The ultimate Dreambox satellite TV support forum. | |
| Member Join Date: 28-07-2007 Location: Europe
My System: Dreambox 5620, 1m dish |
Hi guys, had my dreambox 5620 for about 2 years, been on and working for that long as well. I decided that i was going to update my cam for the first time in about 6 months, because i only use an official card anyway. Followed the usual procedure and reset the dreambox, tick tick tick tick tick, thats all i now get from the box, i dont get any 5600 boot message, no lights, just tick tick tick tick, coming from inside the box. Weird thing is ive had it working twioce since then, once by pressing down on the top of the box and once from switching it off and then on about 10 times. Now it seems permanently stuck in this tick tick tick. Anyone got any ideas or experience of this? P.S i tried hooking it up to dreamup, which recognises the box as a 5620 but cant initialise flash, if that helps. Cheers guys | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Well SMS at Camberley are the UK distributors, you could try them. PS. If you add the correct information to your profile, then everyone will be able to help more easily, it is only because I asked you in another thread that I know you are South of London. | ||
| | #5 | ||
My System: Dreambox 5620, 1m dish | how do i fix that shagx? Could i take it to a normal electrician? OR is there a guide online that i could follow and get my old soldering gun out??? Cheers | ||
| | #6 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | An electrician will not be able to fix a satellite receiver, you need someone like a TV engineer, who is capable of identifying and replacing very delicate surface mount components. If you have no experience of soldering on this type of board, don't try it, it will end in tears. | ||
| | #7 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | At minimum you would need a fine tipped soldering iron and a pair of fine tipped tweezers plus solder. A multimeter would be useful too.The cost of these items alone could be more than the repair cost. Plus you would need to find out exactly which cap has gone and identify replacements with the same footprints and values. Unless you are an electronics hobbyist or a professional engineer or technician its probably best to leave it to someone else. | ||
| | #8 | ||
| Growing Old Disgracefully Join Date: 23-05-2003 Location: Benitachell, Alicante, Spain
My System: Famaval 3,1, IP9000HD plus other FTA and Linux boxes - Astra 1&2, Hotbird, Hispasat | | ||
| | #9 | ||
| Member Join Date: 01-12-2006 Location: uk
My System: Dreambox 8000 Dreambox 800 Dreambox 500 | As stated above you would need a multimeter to be able to locate the power rail drop from the transformer side of the circuit then follow and test the capacitors along the rail to you find the faulty one which has probably gone short circuit. The actual component cost will be pence to buy but locating it can take abit of time, if you dont know how to repair or what to look for id suggest taking it to a local electronics repair shop. Be warned the power supply transformer still can contain voltage even though the power may be switched off!! Regards ShagX | ||
| | #10 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Bear in mind that an electrolytic capacitor test with a multimeter so equipped may show a correct capacitance reading, but will still be faulty (high ESR). Checking using the resistance range for a 'kick' - the same applies. Only an ESR meter will determine whether the capacitor is faulty (unless the signs are obvious - dead short or bulging case). Llew | ||
| | #11 | ||
| | #12 | ||
| ASBO Club Team Spokesmen Join Date: 30-10-2005 Location: Behind pin 9 on an atmel
Blog Entries: 2 My System: Dm500, TM9100, Pace Sky+ box, 1M Dish. Motect 2100.. 43Inch Plasma, Wii, PS2. | Can i just say you do NOT remove surface mount caps off with a Fine tipped soldering iron, you will burn the board and posibly damage the tracks. First identify the cap at fault with a multimeter once you have tracked down the dead cap, take yourself to maplins and buy yourself a gas solder iron with a hot air fittings. Apply the flux, grab yourself small screw driver, heat the cap up (dont get too close). whilst applying heat push the cap away from its track. it will move fairly easy. apply the powerlead to the box it shud then power up and work as normal. BUT remove the powerlead and find a replacement cap from another box which you dont use or is broken. do the above and replace in the box being repaired. I will say again. dont use a fine tipped soldering iron as you will burn the board.. | ||
| | #13 | |||
| | #14 | ||
My System: Dreambox 5620, 1m dish | Ok, opened it up today with an electronic tester screwdriver. I have located the problem as being either the big yellow box thing or the thing that looks like 2 copper wheels next to it. Whilst i was fiddling, the dreambox booted up. I switched it off thinking my tinkering had cracked it but then i tried again and just tick tick tick. Any ideas what parts these are or what to do with it? This is what they have written on them: Copper wheel: LFW10500005C BMC 0339 Yellow Box: .22K275V-X2 MPX GMF40/100/21 250V-CARLI P.S: As a replacement box should i buy a technomate 1500ci to work with my digitalb card? Cheers | ||
| | #15 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | The 'copper wheel' will be the mains smoothing choke, and the other component is a 22nF 275V capacitor. The X2 suffix denotes a mains - rated capacitor, and must be replaced with a similar X2 rated item. However, problems with these items are unlikely to give the symptom you describe. A short between the turns of the choke would blow a fuse. Open turns on either coil and you would have no supply to the rest of the circuit. The capacitor if short circuit would again blow a fuse, but if open circuit may allow mains spikes into the supply, but unlikely to cause your problem. Could replace it I suppose, cheap enough from a component supplier. Llew | ||
| | #16 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Just a reminder - only do cold checks on your receiver if you have no experience of fault - finding. Live receivers are dangerous to work on, particularly on the mains side of the box. Llew | ||
| electrical, fault |
