Ts 2 Dvd
A range of guides, sticky and useful threads, plus FAQs for the Dreambox community - Home of the famous "Ultimate Idiot Guide", made by idiots, for idiots.
Old 02-02-2005   #26
Sir Chuckles - The Dreambox Knight who laughs!
Originally Posted by john_graydon
Could you start a new thread on using Ngrab, How to record etc to DVD.
OK, will do!
chuckles is offline   Reply With Quote
Old 02-02-2005   #27
BGonaSTICK's Avatar
Yeah, please write us a V. quick guide, as I want to play too!
Old 02-02-2005   #28
Posted - enjoy!
Old 14-03-2005   #29
john_graydon's Avatar
My System: Dusty Dreambox 7000s, & Sky HD.
Originally Posted by haggard
Sure. Go ahead.
Well Haggard after going back to try again at making a dvd from dreambox ts files I have finally done it. When i got the final 1 ts file after joining them, I ran it through div x to dvd converter and got VIDEO_TS files. I then burned this file to Clone dvd. And hey presto it worked. Now going to make a nice dvd collection out of all my db files. Red hot ones.....
Happy Dreaming
john_graydon is offline   Reply With Quote
Old 02-04-2005   #30
There is a new version of DVR-studio - DVR-Studio pro, which has a DVD wizard and claims to creeate a DVD directly from the .ts files.
I've tried and wasted 3 DVD's but I've seen a report from someone who have it working.
Anyone here had any success?
Old 02-04-2005   #31
No havent tried it yet, will do and let you know how i get on. Do you not use rw discs.
Happy Dreaming
Old 02-04-2005   #32
Cant seem to load this software. Any ideas. Its hidden, you need admin rights. Maybe you need to buy it 1st. How did you get yours running????
Happy Dreaming
Old 02-04-2005   #33
I have a load of cheap discs to give to m8's. Need to start experimenting with RW's only from now on.
Link to download here:
_http://www.haenlein-software.de/haenlein-software/index2.php?navigation=dvr-studio-pro&s=2&unav=nav_progs&sprache=english
There is a crack about as well.
Old 04-04-2005   #34
Just cant get it to open, will look around. Trial version
Happy Dreaming
Old 04-04-2005   #35
What cant you get to open? The site or the downloaded file? Just checked and link is OK. It is a trial version but I can send you the hack if you want it.
Old 05-04-2005   #36
Sent you pm, looks quiet good. Regards
Happy Dreaming
Old 05-04-2005   #37
Replied to your PM.
Old 05-04-2005   #38
Loaded up Troy last night. I ftd it to a troy folder using DCC. Joined it using HJ Split. Opened up DVR Studio Pro and opened the folder button. Double clicked on Troy and then loaded the wizzard. Went to bed then. Took disc out this morning and it worked in my dvd player.
Now I have to fine tune it. Things I have to find out is How to ftp it and join with DVR, Editing it (have a fair idea on this) And getting the computer to shut down after writing the disc. I checked the box after i ran the wizzard and it was still on this morning so maybe need to check it before running it again. Done a bit of manual work but you have to keep going back to it. The wizzard seems to be ideal so will keep working at it to perfect it. Oh yes both audio languages loaded but just used the button on the remote and it went to english. When done manually you can select english. The audio is in sync with the picture and very good quality.
Would be great if i can get the dreambox ip to work with it and then it would do what it says with 1 click of the mouse. Any idea on what tributes you give the file on the dreambox.
Happy Dreaming
Old 05-04-2005   #39
Dreamer
lovelyperson's Avatar
Chief Commander of the Tux
Glad to see you are winning!!
Like yourself, just getting to grips with this amazing prog. May be reading you wrong John, but the DVR prog joins it automatically within the wizard. Editing is simple, start cut and finish cut. You can select which languages you want to edit if required. There IS an option to shut the PC down after writing.
As usual I am in a rush, but to sum up, the program is great, did 5 trial runs, all came out perfect. As I said will tackle more in depth later. Off to Madrid now for a few days but will log in to check your progress. Apologies if I have read your notes wrong.
All in all guess this prog is what we have been waiting for, not as exciting as TMPGenc etc but what results!!
Best of luck.
Cheers lovelyperson
lovelyperson is offline   Reply With Quote
Old 05-04-2005   #40
I would suggest that you get hold of DreamTSman V1.0.2. This program will ftp to your box and give you the option of downloading files as "one". Its very stable and seems to prevent some errors on FTP.
Its freeware also!
Old 07-04-2005   #41
USed DVR Studio pro again and it works fine, How are you getting on with it now.
Happy Dreaming
Old 07-04-2005   #42
Best of luck.
Cheers lovelyperson
Hi Lovelyperson
What a nice name by the way. Was in a rush myself to get it going too. Must try and let it join itself. Will keep hacking away with it. Fab piece of hardware i must say too.
Happy Dreaming
Old 11-04-2005   #43
sputnick's Avatar
My System: DM7000S, movable dish 1m pointing at 13E, 5E and 4W. The Gemini Project 2.90 Image in Flash. No multi-boot.
Guys, mbranco, I dont understand yet too why going throught all that procedures. When with NERO VISION EXPRESS 3.0 you can make a DVD directly from .ts. Quality is quite good, i would even say very good. You can cut out publicity easily. Merge, make menu's. By the way you can download templates for menus. So easy, i can pre-make dvd in two minutes, then you just leave your PC do the enconding job and writing the dvd at the end.
sputnick is offline   Reply With Quote
Old 11-04-2005   #44
sputnick's Avatar
Concerning the quality, now, with double-layer dvd's you dont even have to worry about any quality lost. Technology is wonderfull.
Old 11-04-2005   #45
Talking
Well my experience with Nero Express 3 is that it did not merge the .ts files and I could not find out how to isolate the English soundtrack. Apart from that it seemed to take hours for just one DVD.
Old 11-04-2005   #46
I found that nero ex wouldnt burn the ts files to disc too.
Happy Dreaming
Old 12-04-2005   #47
BGonaSTICK's Avatar
Would one of you nice chaps point me in a not too obvious way at the working crack for DVR-studio please?
I fancy having a go at it...
Old 12-04-2005   #48
Did try to ssend the crack but it got rejected by your isp I think (now mine too I guess)
Old 12-04-2005   #49
Have sent another e-mail with crack to Bogonastick and John_Graydon.
Compressed the files this time so it should get through
Old 12-04-2005   #50
Dreamer
BGonaSTICK,
Hope you have the info now you wanted, I think you will find the prog great.
If you have 5mins, please give us your blunt thoughts on this. Guess you too will be satisfied but I expect you will be twiddling your thumbs as 'there ain't a lot to configure', seems to take all the fun out of the norm, ie: problems en-route. All said, a superb release by Haenlein Software.
Perhaps hear from you later, best of luck.
Cheers lovelyperson
dvd
Similar Threads
home dvd recorders doggy Sky Digital (BSkyB) and Astra 28.2 East General 4 27-02-2006 07:10 PM
Informaion on DVD recorder formats JonnytheKid The Meeting Place 0 30-08-2004 06:48 PM
First European HD DVD net1 Multi-receiver/TV systems - Domestic only 0 07-04-2004 08:16 PM
Chinese DVD Pirates Shahid The Meeting Place 3 09-09-2003 07:36 PM
Ezdvbxl 2.5 Main feature DVD playback with some bugfixes etc Big Ted Satellite PC Card Receivers & Internet by Satellite 0 16-03-2003 02:06 PM
