Ts 2 DvdA range of guides, sticky and useful threads, plus FAQs for the Dreambox community - Home of the famous "Ultimate Idiot Guide", made by idiots, for idiots. | |
| | #51 | |||
| Super Moderator Join Date: 24-08-2003 Location: Dublin....Ireland
My System: Dusty Dreambox 7000s, & Sky HD. |
| Happy Dreaming | ||||
| | #52 | |||
| | #53 | ||
| More dishes than Sense. Join Date: 30-09-2004 Location: Close to Southampton
My System: 7 dishes. 9 LNBs. And a whole load of receivers + One broken TV. | have any of you tried nero vision express? in my experience you can throw any files at it and make a dvd - divx, avi, mpg, mjpeg, etc. -cts | ||
| | #54 | |||
| | #55 | |||
| Specialist Contributor Join Date: 01-01-2000
Sir Chuckles - The Dreambox Knight who laughs! |
Had not spotted that in the huge list of options! Fraid I cant get it to work, it comes up with a message in German and English offering to modify a file and then prompts you to reboot. Still nothing. I think it might work if I loded the image held in flash, but can't see the point of messing about with it really as its as easy to FTP. | |||
| | #56 | ||
| Retired Moderator Join Date: 22-12-2003 Location: Brighton
My System: Dreambox 7000, Skystar2 | Thanks to all for your help with getting DVR-studio up and running. I'll be playing with it over the next few days, so as a total noob to video editing, I'll let you know how I get on! | ||
| | #57 | ||
Sir Chuckles - The Dreambox Knight who laughs! | God luck. Regarding Nero and .TS files, they will load if you have the right codecs in the PC, but O still dont think Nero is great. Almost 4 hours to make a DVD is just too long, and it does not seem very reliable. | ||
| | #58 | ||
My System: Dreambox 7000, Skystar2 | Burnt my first one and I thought it was perfect, but when playing it back it had a two-second-long glitch in the video and audio towards the end (looked like some pixellation and a couple of frames inserted from adjacent position in the movie). The glitch is not there in the .ts files. Problem is evident on my Tosh player, and on two ROM drives. On one machine it even caused PowerDVD 5.0 to go over. My sort of software though. Good quality video and audio o/p, simple editing and no fancy menu stuff on the resulting disc. I'm lazy when it comes to archiving stuff off to DVD (which is what this amounts to for me) but if it's not perfect, then it's no good to me. Got a few more options to try yet though. I'm going to persist, as this is the closest thing by far to what I want. Maybe it's not the software - I'll burn the next one at half the speed. What really bugs me is why this code is so flippin' difficult to write?!?!?! I know that the transmission standard is none too tight, and that DVB-streams don't seem to adhere very well anyway, but it just needs to be a no-brainer. I guess that the 'limited' market has a negative impact on development funding?!? | ||
| | #59 | ||
| Super Moderator Join Date: 08-03-2005 Location: J6 M5
Blog Entries: 1 My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini ![]() If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots | I don't know what spec PC you've got but I would recommend at least a P4 2.8GHz and 1GB Fast RAM (preferably more) when running any DVD or film editing software. And don't run any other software at the same time and switch off your virus checker. | ||
| | #60 | ||
My System: Dreambox 7000, Skystar2 | Burnt a film off Ki*sk earlier and it was completely scrap. Perfect audio, totally fragged video. Suspect that this one failed due to the low original SR. Want to try one more with a high SR and res. Problems are nothing to do with burning speed. Nero's Scandisk function reports perfect file integrity and sector reads for discs written at both 4 speed and 2 speed. It's the demuxing process that screws up, and that's the same problem I had with PVAStrumento although I could fine tune that to about 98% quality. My box is up to the job speed and memory wise. | ||
| | #61 | |||
| Order of "Knight of the Idiot Guide" Join Date: 13-09-2004
![]() Self proclaimed order member Mbranco was finally initiated by cleaning the wizard stable barehanded |
1) When you "Add video files", in the file-selection window, you can select multiple .ts files, so you don't need to do previously the merge operation 2) The audio-track is a bit hidden : in "Edit movie", selecting the clip property (the check just after the scissors in the icon-bar) you can choose the primary audio track 3) yes, the time is long, but I prefer to make a dvd in a single, unattended, step instead to use interactively several tools. Obviously everyone has his preferred tools, and it's a good thing to have so many choices to do one job. Have a nice day! | |||
| | #62 | |||
Bye! | |||
| | #63 | ||
| Regular Member Join Date: 01-01-2000 Location: pj::
| Just reading the thread about having to join up vid files, i've just recorded for the first time as a tester a small file of 113meg on my DB and found that i could transfer this ts file as one file to PC and burn it to DVD and play it on my DVD player no probs, i don't understand why this works when there's all this talk about joining files, is there a maximum segment file size before files are seperated, not quite sure what i'm babbling on about but someone might! Richard. | ||
| pc:: Last edited by richardp; 22-05-2005 at 10:26 PM. | |||
| | #64 | ||
![]() Self proclaimed order member Mbranco was finally initiated by cleaning the wizard stable barehanded | By default, DB segments a recording in 1gbyte chunks (one film is usally 3-4 files). You can setup db to do bigger files, so you can have one recording = one file , but problems can arise after when you want to transfer these files on your PC (for example Samba don't transfer bigger files). Joining files is not necessary for several programs which permit to select multiple input files (for example Nero, PVA....), but other programs need to have just only one input file, so people using these programs need to join them before. | ||
| | #65 | ||
| The Consumate Dreamer Join Date: 01-01-2000 Location: Somewhere where the Sauer is Kraut and the Wurst is Brat
Blog Entries: 5 My System: I bet on red. If I lose, I double the bet on red again. I continue with this until I lost everything. ![]() Muhuhuhahahahahaaaaarrrgggh | If you got network with LAN to your computer you could record it streight onto your computer like I do with my 5620....no problems there with large files. | ||
| | #66 | |||
| Member Join Date: 04-03-2005
My System: 1.8 M Dish 13 deg KU Band DM500s receiver |
Have just entered the murky waters of ts to dvd. saw that dvr studio is the way to go. have downloaded it and would be grateful if you could send me the crack thanks carlysun | |||
| | #67 | ||
Blog Entries: 1 My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini ![]() If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots | try astalavista.box.sk | ||
| | #68 | |||
looks like a huge database...can you give me any other hint? | |||
| | #69 | ||
Blog Entries: 1 My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini ![]() If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots | h__p://www.google.co.uk/search?client=firefox-a&rls=org.mozilla%3Aen-GB%3Aofficial_s&hl=en&q=dvr+studio+crack&meta=&btn G=Google+Search | ||
| | #70 | |||
will keep looking cheers | |||
| | #71 | ||
| Member Join Date: 26-08-2005 Location: Greece
My System: D500 S |
Get descaler codec from http://www.dscaler.org And you will be able to play all .ts files generated by your dreambox with all players and video programs. Notice that you will have to change-rename the files from .ts to .mpg I test it with descaler 5 and dreambox 500S and it works just fine. Regards, Viron. | ||
| | #72 | |||
| | #73 | |||
| Member Join Date: 15-10-2005 Location: Norfolk UK
My System: Tecnomate 5500cip plus. Dragon Cam & loader card. Cards = M2, Blue tit, Gold, Fun 5. Phenix and fun programmers. Skystar 2. 80cm Dish. 36v motor. Dual LNB. |
Thanks. kartherton. | |||
| | #74 | ||
| Regular Member Join Date: 25-05-2005 Location: uk
My System: 85 cm transparent dish jaeger h to h motor v box dreambox 7025 300gig hdd | hi, just a quick question. If your ftp a file of about 2 gig, roughly how fast is your transfer rate? I`ve been trying to transfer a ts file to my laptop and it gonna take about 46 hours. What rate should i be expecting from my 7020? cheers phil | ||
| | #75 | |||
| dvd |
Similar Threads | ||||
| home dvd recorders | doggy | Sky Digital (BSkyB) and Astra 28.2 East General | 4 | 27-02-2006 07:10 PM |
| Informaion on DVD recorder formats | JonnytheKid | The Meeting Place | 0 | 30-08-2004 06:48 PM |
| First European HD DVD | net1 | Multi-receiver/TV systems - Domestic only | 0 | 07-04-2004 08:16 PM |
| Chinese DVD Pirates | Shahid | The Meeting Place | 3 | 09-09-2003 07:36 PM |
| Ezdvbxl 2.5 Main feature DVD playback with some bugfixes etc | Big Ted | Satellite PC Card Receivers & Internet by Satellite | 0 | 16-03-2003 02:06 PM |
