How-to upgrade NewcamD to V5.25 - IG
Closed Thread
Thread Tools Display Modes
Old 21-11-2004   #1
BGonaSTICK's Avatar
Exclamation How-to upgrade NewcamD to V5.25 - IG
This document is now incorporated into the Dreambox Idiot Guide sticky.
Version number updated to V1.0 Final, but no changes made from V0.2 Draft.
It's a bit more than an idiot guide now. Updated for NewcamD version 5.25. New newcamd.conf section. Some errors fixed.
Please provide feedback via the main Dreambox forum. I'd still like the 'unknowns' at the back of the guide answered if anyone knows. It annoys me greatly to not be able to have it 100% right!
Closing this thread for now.
STICK
__________________
BGonaSTICK is offline
Old 22-11-2004   #2
T_G
The Consumate Dreamer
T_G's Avatar
Location: Somewhere where the Sauer is Kraut and the Wurst is Brat
My System: I bet on red. If I lose, I double the bet on red again. I continue with this until I lost everything.
Muhuhuhahahahahaaaaarrrgggh
Originally Posted by BGonaSTICK
This is Version 0.1 - Draft.
It's an Idiot Guide at the moment. More to come later hopefully.
Please provide feedback via this thread, and I will update/correct it accordingly and re-issue.
When it's right, I'll ask T_G to put it in the bible.
STICK
Way to go Stick!
I have had a quick look (at work), and it looks good. I might have one or two things I can answer, but maybe it will only be tonight!
TG
__________________
I only believe stuff that comes straight from Mr. Horses mouth
T_G is offline
Old 23-11-2004   #3
re:accidental deletion of keys
I am using smart ftp and I happened to delete keylist from var/scce how do I put it back, I have tried using the command extract all of the keylist file that I unzipped to the relevant address 192.168..../var/scce folder it still does not work.
any ideas please
neethan30 is offline
Old 23-11-2004   #4
Ding Dang Doo
gameboy's Avatar
My System: DreamBox 7000s - Nokia Freeview - Several GameBoys - DS Lite - ZX81 - SNES - N64 - Sega Saturn Dreamcast - PlayStation - Gamecube - PSP - iPod - iPhone - XBox - PS3 - Wii - No Life!
This is Version 0.1
Very good - the link has todays updated k*y list 23/11/04
Unfortunately I don't know the answer to any of your questions - sorry.
__________________
Only he who does nothing, does nothing wrong.
gameboy is offline
Old 23-11-2004   #5
BGonaSTICK's Avatar
any ideas please
I'm afraid I don't know your particular FTP client, but you simply need to FTP a NEW keylist and rsakeylist file to the /scce directory, and chmod them to 755.
You will need to read the doco that comes with your client.
Sorry I can't be of more help.
__________________
Old 24-11-2004   #6
I have tried various FTP clients including FlashFXP, Smart FTP they all connect to the dreambox fine,even the llama ware dream box edit program seems to work fine. We can view the files but we cannot seem to write any new files into the various folders.
Wondering if there is any kind of write protection on the dreambox that must be overcome. I have a friend here too who is supposed to be a sat expert (!) but even he is stuck with this problem. We are using the RU-Dream Enigma image, latest version.
can anyone please help!!
Old 24-11-2004   #7
T_G
T_G's Avatar
I might be wrong, but I once had a situation where my dreambox was just too full and it did not want to have anything else. So I went and deleted a few programs from the plugins directory such as games and some other stuff. After that it worked...
__________________
T_G is offline
Old 25-11-2004   #8
thanks but still cannot write to the folders, tried deleting some files, it worked , seems strange that you can delete files but cannot add new files.
thank you
Old 25-11-2004   #9
BGonaSTICK's Avatar
Delete a few more, and then reboot. All should be fixed.
__________________
Old 25-11-2004   #10
My System: 7000S - 300GB Maxtor 1GB USB - Syslink wifi bridge from DB to Syslink wifi router to Apple Extreme streaming relay to Apple G5, 2 xG4. Elgato into G4 17 in for Apple DVB-T captures. Panasonic 42 HD ready
Defeater of Dragonii Teqnicali
RW permission
thank you
There are no permissions needed to write to DB by ftp.
You should be able to write or re-write.
A simple way is just to use your web browser e.g. IE
type ftp://192.168.0.24
or whatever you have set DB to.
You will see the files and you should be able to delete/rewrite.
Except from a Mac, where ftp writing from Safari and IE is disabled.
I use Transport from Mac.
haggard is offline
Old 25-11-2004   #11
comment
STICK
New meaning of the word idiot!
Looks v good and is already printed and filed in my work folder.
The comment re WordPad vs Notepad has wider issues. Essentially a Unix compatible windows editor is needed. There are things like Notepad2 that are supposed to work.
The times I have d/loaded a rsakelist file on its own, I didnt need to chmod it to 755, may have been done already.
But well done.
It will be appreciated by many.
haggard is offline
Old 25-11-2004   #12
But well done.
its a shame I think my dream box is somehow write protected, I have tried writing, to it I can't or should I change the port on my dreambox from port 80 to port 21 as it is on my ftp client?
Old 26-11-2004   #13
Followed all the steps of the HowTo. I reckon you can't have too many Idiots Guides, it's the only way of some of us can learn about this stuff.
The only bit I found confusing was step 6:
6) Transfer the files
  • cardserv.cfg
  • cardspider.cfg
from the relevant subdirectories in the downloaded package to /var/tuxbox/config. Check that file newcamd.conf is also present here, and modify/update all three files as appropriate.
I transferred the files OK and I have got a newcamd.conf, but am not sure about the modify and update. Using the latest keylist and rsakeylist it is still all black on Thor.
Bob
Dreambox 5620s, Hydra Angharad,
bob49 is offline
Old 26-11-2004   #14
BGonaSTICK's Avatar
If your newcamd.conf file worked before, it should work with 5.24.
I haven't checked this afternoon, but I believe that there was a key change on 1W today.
Thanks for the feedback. I think I'll include a sub-how-to for the newcamd.conf file.
The other two .cfg files will only need modifying if you're going to card share.
__________________
Old 26-11-2004   #15
T_G
T_G's Avatar
Once you're ready put the relevant text into the Idiot guide. I already officially included you as a Idiot Contributer, so...
__________________
T_G is offline
Old 27-11-2004   #16
BGonaSTICK's Avatar
...included you as a Idiot Contributer, so...
I thought it was FOR idiots, not BY them!
I want to sort out my queries first, and include a guide on newcamd.conf.
In a couple of weeks I'm going to have a go at a new newcamd install.
The week after that I'll be mainly looking at SCAM.
__________________
Old 27-11-2004   #17
T_G
T_G's Avatar
Nope, things are not the way they seem . it is recreational writing therapy with positons for about 3 Idiots and a nerd available(if someone reads this and feels spoken to please apply for idiot status )
Then after that, you will sort out a new cam, crack NDS, and and ....
__________________
T_G is offline
Old 01-12-2004   #18
BGonaSTICK's Avatar
New version. Additional material, and updated for version V5.25.
All feedback welcome.
__________________
Old 01-12-2004   #19
lol74's Avatar
Cool Is NewcamD v5.25 descrambles also MV1 to MV7 ?
HI
Currently I have all T*S clear with MV8 but MV1 to MV7 are still dark (with latest CAMD3 ).
Dream7000S + Hydra angharad 1.08 + latest control panel
lol74 is offline
Old 01-12-2004   #20
BGonaSTICK's Avatar
Originally Posted by lol74
HI
Yes it does.
__________________
Old 01-12-2004   #21
lol74's Avatar
Talking
Yes it does.
COOOOL, I am going to try tonight !!!
lol74 is offline
Old 22-12-2004   #22
BGonaSTICK's Avatar
Thread closed. See first post for update.
STICK
__________________
Closed Thread
Forum Jump
