The Ultimate Idiot Guide! For Idiots by Idiots!Answers,Questions,Tips + Tricks: RTFM!
A range of guides, sticky and useful threads, plus FAQs for the Dreambox community - Home of the famous "Ultimate Idiot Guide", made by idiots, for idiots.
Closed Thread
Old 07-04-2009   #51
mhku's Avatar
My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini
If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots
How to manually find and store satellite positions
The DM500s doesn't support gotoXX. The long way is to use stored positions is described below.
Please note that your "drive to zero" satellite (1W in this example) will depend on where you are in the world.
Go to Menu > service searching > motor setup
Mode: drive to zero
and press go
Then change the mode to position and select 1W:
Satellite: 1W
Drive the motor to zero.
Mode: Position
Satellite: 1W
then use the < > arrows to move the dish until you get a lock. STORE the position (I use the same number as the satellite).
Then SEARCH.
Repeat for 13E, 19E, 28E, storing the position for each.
If you use gotoXX you shouldn't have to do it but I couldn't get it to work with my 7020 (and it doesn't work at all with a 500s).
Your screens and options may vary slightly depending on the Dreambox model and image that you have.
Extra info:
Mode is position, drive to zero and a few options.
SATELLITE has the list of satellites.
In simple terms you drive the motor back to zero so you have a fixed position.
Then you change the MODE back to position, select the satellite from the list next to SATELLITE.
Then you move the motor (dish) using the < > arrows (these move the dish east and west).
When you get a lock on the satellite you chose, you store it's position and then go to the next menu screen and scan it.
The Dreambox is very fussy about dish positioning - what works with another receiver doesn't with a Dreambox. I fine tune my elevation on 1W using a sat meter before finding positions and scanning - it makes a big difference.
It is also not a quick/ easy thing to do first time. It took me two weeks to do the first time, mainly because what I thought was my 1W position was actually 5E (they use some of the same transponder numbers).
You don't stop playing because you get old, you get old because you stop playing. Regras
Before posting in the Dreambox section please ensure you've read The Guide
Information is for educational purposes only
mhku is offline
The Following User Says Thank You to mhku For This Useful Post:
Copers74 (28-09-2009)
Old 11-07-2009   #52
mhku's Avatar
List of cards that do and don't work with CCcam
Thanks to Nina on ECS for this list that works with CCcam.
Cards that are read by CCcam DIRECTLY:
- AKTA (ex Max-Tv) (Romania, on 4,8°, Viaccess [which version??]) card works in CCcam on DM500 but doesn't make AU.
- ABS-CBN (Irdeto2, CAID 0604 ACS605)
- AlJazeera Sport (Irdeto, CAID 603, ACS 606)
- AyngaranTV (viaccess)
- ART international (North Africa, viaccess 2.6, 500:21110)
- ART 7W (Irdeto, CAID 604, ACS 505)
- ArenaSat Cryptoworks (Problems with Youghtprotection Code)
- Bulsatcom (Irdeto2 Caid 604 ACS 605)
- BSkyB (UK, NDS2 - blue card, read directly on DM 500, 7000, 7020 and 7025 and now also DM800 and 600)
- BHTV (16E, viaccess)
- Bis TV ( viaccess France )
- Canal Digitaal (Netherlands, Seca 3 v10)
- Canalsat + TPS (France, viaccess 3.0, CAID 0038)
- Canal+ (France, Viaccess 3.0)
- Canal+ Maghreb ( Maghreb, viaccess 500:41140)
- Cyfra+ (Poland, Seca3 v10)
- DeepamTV (viaccess)
- Digital+ tunneled Seca (aka v10)
- Digiturk (Cryptworks? )
- DigiTurk 7E (Cryptoworks, REV5, CAID d00)
- Digiturk (Irdeto2 Caid 604 ACS 605 work ok - new v5.7 card acs608 is NOT working on ANY cardsharing)
- Digitalb (Albania, Conax CAS5 and CAS7, HD channels use CAS7 only and do NOT work with any CS sw)
- Dolce TV (Romania, NDS)
- Dorcel / FreexTV / Xdream (Viaccess)
- Focussat (Romania, Conax) at 0,8W, make AU
- Hayat TV (13E, viaccess)
- HRT (Viaccess 3.0)
- HTB (Russia, works ok with both CCcam version 10 and 11)
- ITV Partner (Cryptoworks card bios rev 3)
- JSC Sport (North Africa, viaccess 3.0, 500:30700)
- KabelDeutschland (Germany, Nagra3, Rom?)
- Kabelkiosk (Conax)
- Martens (Conax)
- Meo (Portugal, Seca3 V10)
- MCT (Viaccess version?)
- MCT (Irdeto version?)
- MTV Unlimited (Conax version?)
- Nova (Irdeto version?)
- Orbit 26W (Irdeto, CAID 668, ACS 606)
- ORF (Cryptoworks, REV3)
- Premiere (Germany, Nagra3, Rom 181)
- Premiere (Germany, NDS, V13)
- Private Spice (Viaccess version?)
- Private Spice (Irdeto version?)
- Raduga TV (Russia 75E, Irdeto2 v5.7 ACS608)
- RTvi (Russia 13E, viaccess [which version??])
- Svt Europa 9E (Viaccess)
- SRG (Viaccess 2.6)
- Sex On Tv (Viaccess version?)
- Sex On Tv (Irdeto version?)
- SexView (Viaccess version?)
- SexView (Irdeto version?)
- SexView (Conax version?)
- SkyLink 23,5E (Cryptoworks Rev6, CAID D03)
- Sky Italia (Italy, NDS 2, CAID 0919)
- Sky Italy (Italy, NDS3, CAID 093B works directly on cccam as of version 2.1.0)
- Showtime 7W (Irdeto, CAID 604, ACS 605 - new card v5.7 NOT working in sharing)
- Telesat (Belgium - Seca 2 - CAID 100:6d)
- TotalTV ( Serbia, Nds )
- TV Vlaanderen (Belgium, Seca 3 v10)
- Viasat 5E (Scandinavia, NDS2, CAID 90F - new card NDS3 does not work in sharing yet. HD channels also don't work in sharing.)
Cards that work on CCcam only if read via NewCS:
- BskyB (UK, NDS3 - new white card - CAID 0963 - works only with newcs version 1.66)
- D+ (Spain, N3, Rom 180)
- DigiTV (Romania, N3, Rom 142?)
- NTV+ (Russia, Viaccess 2.6?)
- Polsat (Poland, N3, Rom 142?)
- RUV (Iceland 0b01)
- Tring (Albania,Conax)
- Tntsat(France, viaccess3, 30b00 (19))
- Zon Tv Cabo (Portugal, N3, Rom 142)
Cards that do NOT work on sharing:
- Cabovisao Portugal HD & SD - Conax CAS7
- Digitalb Albania HD - Conax CAS7
- Digiturk Turkey - Irdeto v5.7
- Showtime - Irdeto v5.7
- Viasat Scandinavia HD - NDS
- Boom TV Romania - NDS
- Vision TV Ukraine - NDS
(Info provided by Sonic1)
Dishtv India (Conax Cas 7) only virgin cards read directly on cccam. once married
with the original box, it wont read with even boxkey.
TataSky (NDS) not reading with boxkey directly on cccam. (info provided by tiku).
And there is a plugin to view CCcam information, called CCcamInfo, that you can download here:
Plugin para gemini+cccam
mhku is offline
HB13DISH (11-07-2009)
Closed Thread
guide, idiot, idiots, idiotsanswers, questions, rtfm, tips, tricks, ultimate
Similar Threads
Idiots guide to using dvbviewer Big Ted Satellite PC Card Receivers & Internet by Satellite 41 3 Weeks Ago 04:46 PM
The Ultimate Idiot Guide by Stick,Rolf,Gameboy & TG! Answers,Tips & Tools .pdf format albaniasat Dreambox General 3 20-01-2005 03:27 PM
An idiots guide to DVB ? Shaygate Satellite PC Card Receivers & Internet by Satellite 11 18-11-2004 11:25 PM
Please help! Idiots guide needed mat_d Seca/Mediaguard system 6 15-10-2004 10:17 AM
The Idiots Guide to Satellites waverider The Meeting Place 5 25-11-2003 12:59 AM
