How to stream from Dreambox to Internet
A range of guides, sticky and useful threads, plus FAQs for the Dreambox community - Home of the famous "Ultimate Idiot Guide", made by idiots, for idiots.
Old 14-10-2007   #26
My System: Dreambox 7020, iMac 24
Thank you very much mhku!!
nickbit is offline   Reply With Quote
Old 22-10-2007   #27
My System: nanana
I have Vista and could not run dreamView.
I actually cant register comctl32.ocs as I get: "The module COMCTL32.OCX" was loaded but the call to DllRegisterServer failed with error code 0x8002801c.
Anybody got across this error ?
Agent007 is offline   Reply With Quote
Old 22-10-2007   #28
My System: Dreambox 500
Yes Agent007,i think thats because there is missing a.dll file.Take it from _http://file020r.mylivepage.com/chunk20/779932/547/COMCTL32.rar
Then,put those 3 .dll files into the dreamview folder,and try run it again.I think that it will be alright.Try it and tell us about.
nonname_kid is offline   Reply With Quote
Old 22-10-2007   #29
My System: ipbox
Thanx I'll give it a try
malkawiz is offline   Reply With Quote
Old 31-10-2007   #30
My System: Dreambox 500S + PC Intel 3000Mhz 1gb Ram +SS2+Arion Ferguson+120cm antena!
How about if i don't use a router,but a switch?!Please,someone respond!Thanx in advance!
shocked is offline   Reply With Quote
Old 12-11-2007   #31
My System: Novice Do not know much but I am a fast learner
streaming dreambox picture from england to cyprus
Can we stream audio/video signal from England to Cyprus using dreambox but instead of viewing on PC to view on TV?
Regards,
has2befun
has2befun is offline   Reply With Quote
Old 05-12-2007   #32
My System: Standard digital receiver
Originally Posted by Vinniek View Post
Here's a simple way to stream sat channels from your Dream Box to the net.
You will need only a couple of bits of software and to be honest VLC Player can do it by itself, dreamView is a front end for it and makes life a lot easier (especially changing channels).
I can pick up the stream on my PDA when I'm out if I can find a a wireless network and I also stream footy to my mate on a Saturday afternoon. I've got 4mb NTsmell and the settings used in the tut work fine and I can leave it streaming all day long.
You will need a DNS IP and a router and your PC needs to be on all the time to transcode the stream.
Vinnie (Cookie)
(Sorry to have to ask such a noob question, but I've been searching round and round, and I think this is such a basic question to ask, that it hasn't been answered. And I guess I can only ask!).
When one streams from the Dreambox (eg via the above procedure), is the Dreambox actually able to stream different channel requests at the same time? ie multiple channels simultaneously?
And also what happens with the actual TV & viewer connected to the Dreambox directly - I take it, that too is operating independently?
Thanks in advance...
Sat_L_Plater is offline   Reply With Quote
Old 05-12-2007   #33
mhku's Avatar
My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini
If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots
The only Dreambox that can fit two tuners is the 7025- it may be able to stream two channels (but probably not).
I don't understand your 2nd question.
You don't stop playing because you get old, you get old because you stop playing. Regras
Before posting in the Dreambox section please ensure you've read The Guide
Information is for educational purposes only
mhku is offline   Reply With Quote
Old 06-12-2007   #34
Thanks mhku, I noticed your (many) replies on the forum, and I was wondering if it might be your kind self that came to my aid!
Let me reword my original query so it's clearer!
I understand a standard operation of a Dreambox is:
Satellite cable in ->
Dreambox
-ScartAV> TV displaying chosen channel.
But I was wondering what the operation is when streaming is enabled/being used. Is it:
Dreambox
-Stream1> PC displaying chosen channel
I believe ScartAV and Stream1 operate simultaneously (?). But can they operate independently such that each is on a different channel (same satellite source though in this case s.ky digital, nothing like the fancying multiple LNBs more sophisticated users are doing)?
If, as I think you replied not, then does that mean that when one of the users changes channel, all streams & AVs coming out of the Dreambox change as well?
Old 06-12-2007   #35
Dreambox
Dreambox
I think having read more fully and with mhku's reply I've answered this noob question: it is indeed a single stream of a single channel (it's not even possible to have more than one stream of the single channel I don't think?).
And to achieve 2 room, independent channels, that would require second dreambox + satellite cable connection and card sharing over LAN.
(If anyone can look over and confirm the above it would be a great help though!).
Old 26-01-2008   #36
My System: Dreambox 500 Motorised Dish
I seem to be having a few difficulties!
I am using a dreambox 500 s... does this even support this method of streaming?
Also i am using vista x64, but all software seems to work fine.
What can be causing the problem. VLC says it cannot open stream!
ruddyrum is offline   Reply With Quote
Old 26-01-2008   #37
mhku's Avatar
Sorry Sat L peter, didn't see your reply.
As you worked out the answer is no- you either need a 7025 or connect up a 2nd Dreambox.
Ruddyrum: can you give us more details of what you've done, your setup, image etc.
Old 27-01-2008   #38
I am using the latest gemini image, which i believe is 4.2
Webxtv seems a bit temperamental, which i think is a common issue with most users. Perhaps this is where the problem lies? Although ultimately it does work after a while, it is not 100% functional. I have to change channels quiet alot before one is actually visible - sometimes it can take quiet alot of flicking and takes forever!
If i press the VLC button and open the .m3u file, VLC does not play the file at all. Even if i input the stream manually into vlc it never starts a stream. The only thing that can be streamed is the audio - when i open the apid with vlc (audio.pls)
I think i should concentrate on rectifying this issue before streaming to WAN. Perhaps i should even start a new thread regarding this issue.
Any help/suggestions are much appreciated.
The Following 2 Users Say Thank You to ruddyrum For This Useful Post:
mmattys30 (20-04-2009), thesonandheir (08-03-2008)
Old 27-01-2008   #39
mhku's Avatar
Is this possibly a Vista security issue? Have you cheked any log files on the Vista PC? Do you have a Windows XP PC to try?
Old 27-01-2008   #40
Same problem in XP as in vista... changing channels results in no video!
I read on another forum here (in german) that it seems to be a known issue - a bug with the 500plus and 600 DVB API and new drivers have been released as a result to rectify this problem. i do not want to install them though as i only have a 500 not a plus.
Seems the only solution so far is to restart the box everytime you want to stream! as soon as you change channel is buggers up again and you have to change channel like 50 times!
With regards to Vista security, i have pretty much setup everything pretty well within my internal network to allow communications to flow to and from devices without any interferance eg. Recording from the DB to my HDD on my vista system is not a problem, so i doubt it is a security issue.
Old 24-04-2008   #41
My System: D7000S
I was wondering what would be the minimum for recoding the stream with h264/mp3?
I get the thing to work with DIV3 coding but the picture is not that good (even on my server computer). However when I try to do it with h264 codec - I do not get any picture or at best I get now and that pixelation in the windows and some sound. I assume this is because of my insufficient computer performance?
I have: Celeron 2.4 GHz, 1 GB RAM, ASUS P4V88 motherboard and 256 MB Geforce 6200 graphic card, DSL: DL=3456 kbit/s and UL=448kBit/s
Thanks for the info.
Pavana
pavana is offline   Reply With Quote
Old 24-04-2008   #42
mhku's Avatar
You're trying to take an SD stream from a Dreambox and encode it to H264? Are you using CoreAVC codec? I think your PC will not be up to the job.
And welcome to the forum
The Following User Says Thank You to mhku For This Useful Post:
ertan (3 Weeks Ago)
Old 24-04-2008   #43
My System: D7000S
Hi mhku,
what is CodeAVC codec (I installed K-lite codec pack).
What would be a minimal configuration to enable live encoding with h264?
Thanks,
Pavana
Old 24-04-2008   #44
mhku's Avatar
It's a codec- google it. What software are you using?
Old 25-04-2008   #45
My System: D7000S
I am using WinXP SP2, VLC 086f, Dreambox 015, Firefox 2 and k-lite codec pack. I am not very good with Linux so I did not even try it.
Nothing else is running on the system except for the necessary files.
What bugs me is that when I try to transcode with my laptop (Thinkpad x22 with 800 MHz processor) - I get the same kind of problems but with the laptop I do get transcoding with H264 codec although the picture pixels a lot and it is not good for streaming ins Internet.
Regards,
Pavana
Old 25-04-2008   #46
mhku's Avatar
I did post ages ago with a title something like "Is your PC up to HD?" or similar and it had a link to some tests (I did a quick search and couldn't find it).
I tried it on a P4 2.8ghz 2gb RAM and it couldn't do it.
Playing hi-def and transcoding to H.264 aren't exactly the same (I don't think) but this link may be helpful:
_http://www.cyberlink.com/english/support/bdhd_support/diagnosis.jsp
CoreAVC = _http://www.coreavc.com/
Hardware requirements (minimum): _http://www.coreavc.com/index.php?option=com_content&task=view&id=28&Itemi d=1
Old 25-04-2008   #47
Amo Amas Amant Admin
Topper's Avatar
Indeed
You certainly did click here to access it
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Topper is online now   Reply With Quote
Old 25-04-2008   #48
mhku's Avatar
Cheers Topper
Old 02-05-2008   #49
TEZAK's Avatar
To sort this issue with vista add the missing OCX file into system32 then open COMMAND with ADMIN previlages. and write this command:
regsvr32 missingfilename.OCX
then RETURN
Although I cannot yet get the stream to work as yet
Did someone say that I could watch HD MPEG4 channel in the computer using certain codec could you please elaborate a little thanks appreciated
TEZAK is offline   Reply With Quote
Old 01-06-2008   #50
My System: DB7020
Port 8080 to PC?
Great guide.... but I have a question... shouldn't port 8080 be forwarded to the PC rather than the DB?
Please advise
Thanks!
T
trizio is offline   Reply With Quote
dreambox, internet, stream
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
