How to stream from Dreambox to InternetA range of guides, sticky and useful threads, plus FAQs for the Dreambox community - Home of the famous "Ultimate Idiot Guide", made by idiots, for idiots. | |
| | #51 | ||
| Member Join Date: 04-06-2008 Location: DE
My System: Dream7020 | I don't understand the guide either.. how do I have to setup the port settings.. I installed DreamView on a local PC and it fished up the stream of my dreambox fine.. I configured the settings for the server output and started it but how can I pick up the stream over the I-Net now? does Dreamview scales down the stream directly on the dreambox so that I can pick up the down scaled stream from the dreambox or do I have to make a port forwarding to the local pc and pick up the down scaled stream from the local pc. I don't understand why I have to portforward the port 8080 to my dreambox.. Can anyone help me ? | ||
| | #52 | ||
| Member Join Date: 30-05-2008 Location: Italy
My System: DB7020 |
In fact, I am pretty sure that there is a mistake in the guide. The mistake consists in the port forwarding setting in the router. In fact, the router should forward port 8080 (or whatever port you decide) to the PC, NOT to the dreambox as indicated in the guide. The stream in fact goes in full resolution from the Dreambox to the PC over your local LAN, and then the PC re encodes it to a lower resolution so as to be capable of streaming it across the internet. The system works perfectly over ANY internet connection, as long as you edit the parameters accordingly. Of course, the lower the resolution the easier it will be to receive it anywhere, but of course also the lower the quality. Ciao! T | ||
| The Following User Says Thank You to trizio For This Useful Post: | cloa75 (26-02-2009) |
| | #54 | ||
My System: Dream7020 | @ "Trizio" thanks, that's what I thougt too. You have to portforward to you local PC like: :sout=#transcode{vcodec=mp1v,vb=384,scale=0.75,aco dec=mp3,ab=64,channels=1}:duplicate{dst=display,ds t=std{access=http,mux=ts,dst=192.168.178.20:1234}} it works fine :-) localPC=192.168.178.20 Port:1234 | ||
| | #55 | ||
| Member Join Date: 02-06-2007 Location: Bulgaria
My System: Dreambox 500S + PC Intel 3000Mhz 1gb Ram +SS2+Arion Ferguson+120cm antena! | How about if i use a switch with a brand new IP from the NET provider,instead of a router?!Thanx... | ||
| | #56 | |||
| Member Join Date: 06-04-2006 Location: saudi arabia
My System: hotbird, |
| | #57 | ||
| Member Join Date: 30-05-2008 Location: spain
My System: 600pvr | hi all ok try this this download firefox browser and vlc when installing vlc change the directory where the file should be installed to this C:\vlc\vlc.exe --extraintf=http copy and paste best. when installed click on preferences then input the change the server port to 8080 then click save. next step is to normally install firefox in the browser address wirte http:then ur dreambox ip then go this way works only with your own network,meaning that your dreambox should be connected to the same network your computer connected to.i dont know why, i wish somebody find out a way to connect throught this way from another network. when you click go the browser will ask you for a name and a password the name is: root password is: dreambox now you should be connected to your dream hit any channel then on the top write you will see vlc click on it then it will ask you what program you want to run to start the stream choose vlc, hit my computer then c: then you open the folder vlc the choose the vlc.exe now you should be able to watch the channel you already choose. enjoy and pardon my english ![]() hope it will work for you guys i wish somebody find out why this metod cant connect you from another network. it worked for me but only withen my netwrork. got it from another forum. good luck | ||
| | #58 | ||
| Specialist Contributor Join Date: 25-04-2005 Location: Austria
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband! | Hello! now it should also posible,to stream the dreambox picture,to a nokia mobile phone n75! does any one know,how the setup will go? | ||
| | #59 | ||
| SAT HUNTER Join Date: 20-08-2007 Location: india
My System: One 12 Feet Heavy Antenna, one 10 Feet Double Rib Antenna Dreambox Dm500S, DM 7025. HD Receiver,Envision, Eurostar receiver, 4 Dual LNBS, 5 PFA Lnbs | IS THERE ANY GUIDE WHICH HELPS US STREAM OUR house DREAMBOX anwhere in world | ||
| The Following User Says Thank You to Moradabad For This Useful Post: | simulacrum (19-12-2008) |
| | #62 | ||
| Member Join Date: 24-11-2008 Location: jordan
My System: win xp dreambox | Hi this software can play dreambox on pc within lan and as web streamer to receive stream anywhere by simple steps _http://www.4shared.com/file/117369127/13dfdfd1/_2__tunisia-sat_dreambox_player_and_streamer5.html | ||
| | #63 | ||
| ASBO Club Member - Persona non grata Join Date: 29-03-2009 Location: US
My System: Dreambox 500, Gemini 4.2.0 | Nice one man, I got it working on my iphone. I might need to change the quality a little but it works. Only problem is.... Is there any way to change the channel on dreamview remotely? I can change the channel on my dreambox but it has no bearing on dreamview thanks | ||
| dreambox, internet, stream |
| Currently Active Users Viewing This Thread: 3 (0 members and 3 guests) | |
