How to stream from Dreambox to Internet
A range of guides, sticky and useful threads, plus FAQs for the Dreambox community - Home of the famous "Ultimate Idiot Guide", made by idiots, for idiots.
Old 28-10-2006   #1
My System: DB500, DM800 (snide), MBOX cam, DiSEqC Motor
Thumbs up How to stream from Dreambox to Internet
Here's a simple way to stream sat channels from your Dream Box to the net.
You will need only a couple of bits of software and to be honest VLC Player can do it by itself, dreamView is a front end for it and makes life a lot easier (especially changing channels).
I can pick up the stream on my PDA when I'm out if I can find a a wireless network and I also stream footy to my mate on a Saturday afternoon. I've got 4mb NTsmell and the settings used in the tut work fine and I can leave it streaming all day long.
You will need a DNS IP and a router and your PC needs to be on all the time to transcode the stream.
Vinnie (Cookie)
Vinniek is online now   Reply With Quote
The Following 35 Users Say Thank You to Vinniek For This Useful Post:
adikari (05-09-2009), anwarsha (24-05-2009), dallyis (22-02-2008), dikaios (17-06-2008), dublindanny (18-08-2008), fak2704 (08-01-2009), grik (04-09-2008), Ian.S (17-08-2008), jeamb (15-09-2007), Koreani (24-11-2008), ks95 (16-08-2009), mahmoud1982 (27-06-2009), maximus2 (23-09-2009), Mexicos (18-10-2007), mk741 (1 Week Ago), mmattys30 (20-04-2009), nautysam (21-09-2007), nghockmeng (24-07-2008), Original_Modifier (01-01-2008), outlander (12-10-2009), Perfex (21-10-2008), poomerang (02-09-2008), SALAH100 (05-10-2008), sionix (01-03-2008), slee1005 (29-12-2007), step2 (02-05-2008), Super_nio (03-03-2009), turkii (20-02-2008), v759 (26-02-2008), vteck (20-07-2007), X-man (17-08-2009), xakis (02-05-2009), xover (2 Weeks Ago), Yannis (28-01-2008), Zia76 (09-10-2007)
Old 01-12-2006   #2
My System: DB7000/ 7020/ 500, Hummy and all kind accesories
great explication, thanks.
if i want to stream out only inside my own LAN thru my router (some resident relatives in same building) to diffrent PC, any better way to get better quality in such simple way? bandwith is not a problem here i guess..?
djkenzo is offline   Reply With Quote
Old 24-12-2006   #3
My System: metabox 5'
hi,
i've went through your guide but i can't get it to work. i'm currently using gemini 3.2. here's my network settings :-
router ip : 60.50.xx.187
router LAN: 192.168.1.1
switch (3com, unmanaged/no ip)
Dreambox LAN : 192.168.1.51
(g/way & DNS set to 192.168.1.1)
i'm using the aztech DSL600EU router, and the guide to set this is stated at http://www.portforward.com/english/r...tech/DSL600EU/
i've tried port forwarded port 21, 23, 80 to try ftp,telnet and web-x-tv/VLC but what i get is the ftp/telnet/web to my router. what possibly went wrong?
(i've port forwarded eMule services and i got HIGH ID with KAD network excellent but it doesnt seem to work with dreambox web)
i've checked my network for port opening thru online port scanning web and it indicated warning of open ports on 80,21,23 & 31339 but i can't get through. tried using IE but i get the router webpage instead of web-x-tv (from LAN). how do i control my dreambox from outside?
one more problem is with HDD recording. it'll stop at 60-70% each time i set it. it will start recording on time but it finishes earlier. any clue?
bonotzm is offline   Reply With Quote
Old 25-12-2006   #4
PCD
DB Magician
PCD's Avatar
Merlin of the Idiot Guide
Tick dhcp on the db comm settings, and reboot. If you see any change to the numbers, you are ok, just change back the box ip last number and untick dhcp, reboot. Otherwise you have no connection between the router and the box. Merry christmas !
PCD is offline   Reply With Quote
Old 02-01-2007   #5
satmaniac ,DIY man
maniacop32's Avatar
minimum internet speed for this task?
What would you say is the minimum speed on the internet connection to try this?The initial post says 4mb dsl connection. Will a 1mb connection do the trick?
cheers and happy new year,chris cyprus.
maniacop32 is offline   Reply With Quote
Old 05-01-2007   #6
1mb will do the trick, you will just loose out on the quality.
You would need to downsample the audio and video streams according to your maximum upload speed.
If you can find out your upload speed (google for broadband speed test), then make sure the values are below your upload speed. Your upload speed will probably be around 250k?
Try using only 1 channel of audio at 32k and video of 128k, then test too make sure the stream is stable, then crank up the video bitrate and test again. Trial and error I'm afraid!
Cheers
Vince
Old 10-01-2007   #7
satmaniac ,DIY man
maniacop32's Avatar
Thumbs up streaming dreambox picture efrom england to cyprus
Yes , thanks to vinnie (vinniek) i was able to pick up his dreambox stream from london england all the way to limassol cyprus.I picked the video on my pc and my smartphone via my wifi network at home
Once again thank you vinniek for the detailed guidance.
The Following User Says Thank You to maniacop32 For This Useful Post:
memtes (05-08-2007)
Old 15-02-2007   #8
My System: 13e and 19e all packages c/s
could someone help me with this im on msn
removed*msn.com
nwostarz is offline   Reply With Quote
Old 26-02-2007   #9
skywave's Avatar
My System: One 100cm dish with 3 Universal Quattro 0.6db LNBs at 28.2E, 19.2E, 13.0E.. One 85cm dish with 1 Universal Quattro 0.6db LNB at 0.9W.. 4 - 4x1 DiSEqC switches.. DM7020S, HUMAX VACI-5300, OPENTEL ODS 4000F
Thanks Vinniek - for the HowTo - especially for the link to usbhell and the OCX info..which was what I was struggling with on my new VISTA OS..
Now dreamView works spiffingly :-)
skywave is offline   Reply With Quote
Old 27-02-2007   #10
BonceChops's Avatar
My System: Dreambox 500, Dreambox 600PVR, Dreambox 7025+, Dreambox 7000, 1m dish on a Moteck SG2100
I would not recomend that personally. I would leave the Dreambox on DHCP and assign it a fixed IP in your router. This way the DNS addresses etc will be assigned to your Dreambox by your router automatically.
BonceChops is offline   Reply With Quote
Old 06-03-2007   #11
My System: DM500 80 Dish .3 lnb
Great guide, I registered on this site after reading that.
There is now a newer version of dreamview
I can get everything to work in the guide up until the broadcasting from the Mystream.m3u part
http://local_ip:8080
It opens up in VLC, but no data is transferred (I can see that from stream info) any ideas?
_s79 is offline   Reply With Quote
Old 18-03-2007   #12
Dreambox Gimp & Coder
B16MCC's Avatar
My System: 2 Dreamboxes ------ DM 8000 HD PVR ------- ---------- DM 800 HD ---------- -------- Motek SG2100 -------- ---- Triax 80cm Dual LNB ----- -- Fixed Dish 28e Quad LNB -- ---------- Sky HD Full ---------- ------- 24" Apple iMAC --------
Creator of the CCCCC - only a true wizard could come up with such a name!!
Nice guide VinnieK thanks a lot. Guys askin about minimum connection speeds bare in mind, So far people have been quoting 1mb and 4mb lines. This is ofcourse download speed and whats important here is ofcourse upload speed. I'd hazzard a guess that no one in the UK has an upload of more than 60k ! So what I'm saying is that you don't need great bandwidth for good results.
Now my question is this. I've followed the guide and I understand what I'm trying to achieve. However , can anyone confirm if dreamview works with the DM7025 or not. As I can't even get that to function on mine. As the 7025 differs greatly from all other dreamboxes I'm wondering if there's a problem with dreamview.
Anyone ???
Cheers MCC.
B16MCC is offline   Reply With Quote
Old 19-03-2007   #13
Heavyweight Dreamboxer!
yazooo's Avatar
My System: 1M Gibertini Dish, 3 Quad Alps LNBs receiving 13E, 16E & 19.2E tied in with Minidish on 28.2E. 3 Dreamboxes 7020S FWP 6 Gemini 2.2 & 2.5. Dragon CAM 4.1, CAS2.
I've been doing this on an 8mb line which has 570k upload, and get a very watchable stream, using my own way, which is based on this. I'm upgrading my line to get +1.5 meg upload with be, so hopefully will be kicking out some very nice streams indeed. I usually let the audio suffer when streaming stuff like sports or something to get adequate frame rate etc
yazooo is offline   Reply With Quote
Old 20-03-2007   #14
My System: dm500
Hi Viniek ,
Thanks for posting the streaming guide. I am having a little trouble getting over the final hurdles here.
My setup;
DM 500 with Gemini 3.2
VLC 0.8.6
Dreamview 0.1.5
Router: Linksys WAG354G
Windows XP Pro
Ok, Port Forwarding was no problem, there was no “Stream” (or anything else for that matter) at 8080 so I added it in - I read up and its says that the router doesn’t care what the name is.
I followed your instructions regards dreamview and all seems to work ok locally, however when I try to access the box via the internet (i.e. using the dyndns.org url I set-up) vlc simply doesn’t open anything.
I have checked and re-checked the server output (of course changing the ip to 192.168.1.66, my DM ip address where appropriate)
DHCP is on, but this isn’t an issue as the router hasn’t re-assigned the IP to the box for ages.
One thing that does seem strange – VLC doesn’t update the stream/save area (I have to do all that manually) for some reason it doesn’t seem to be picking up from the cut and paste from “Edit stream data” in dreamview.
Very grateful for any thoughts
EDIT: I haven't made any changes to the router firewall, most things seem enabled, but the fact I can access the Enigma Web Interface should mean (?) that it probably isn't a firewall issue?
Cheers
Sparrow
sparrow is offline   Reply With Quote
Old 23-03-2007   #15
I would like to pass stream on to my phone which VLC is capable of via re-encode but are there any control interface for WAP.
Maybe it is enough to setup some sort of HTTP-to-wap proxy (if there are any of such out there)?
Or are there any WAP servers for Dreambox out there?
Or maybe a Java application form my phone to control my Dreambox?
Like a mini-HTPC frontend?
Maybe Mediaportal, which uses VLC to watch Dreambox streams, could be used together with a small Java application in the phone?
Nicodemuz is offline   Reply With Quote
Old 23-03-2007   #16
D4ftpunk's Avatar
My System: Dreambox 7020 Dreambox DM500 Sky Thomsom Digibox StrongSat FTA Reciever 80cm Dish + 45cm Dish via Disecq A/B.
I stream to my office over my 512kbit upload using vlc to re-encode the stream. To be able to change chan without any sort of control interface i do this.
Change channel on dreambox web if.
Access my vlc.pl script which is actually a .pls file auto generated from the video.m3u dreambox gives you but modified to work a bit better.
This way i can watch tv and change channels anywhere.
If you like i can make a lil script for you to change chan and watch the stream all inside a browser window (like webxtv but working)
give me money now
D4ftpunk is offline   Reply With Quote
The Following 2 Users Say Thank You to D4ftpunk For This Useful Post:
DreamMate (09-07-2007), Foxy (30-11-2008)
Old 24-03-2007   #17
handsomejackuk's Avatar
My System: dreambox 7000s 40gb hard disk, sky + sky digi box, comgag sl65 *2 twinhan pci sat card. 2* sky digi boxes each with quad lnb's 1M televes dish superjack dg120 motor. dreambox and 4 pc's all networked running vlc from dreambox. Some pc's wireless.hita
streaming to psp
Does anyone know if i can stream to a psp i can get the web interface on psp to open up but channel lists do not show up also when i open remote control only half of the remote control shows up has anyone managed to get streams to a psp ?
handsomejackuk is offline   Reply With Quote
Old 15-09-2007   #18
My System: DreamBox 500
Unhappy
I cant put it work
The Danm Cone doesnt go away(that orange VLC cone)
Someone help
X_Splinter is offline   Reply With Quote
Old 03-10-2007   #19
My System: dreambox general
hi, i have a dish and dreambox as set-top-box.iam interested to stream the video and audio signal from my pc to the tv of my neighbour's house. i would like to know if this is possiple to be done and the ways required.
chris25j is offline   Reply With Quote
Old 09-10-2007   #20
REDA REDA REDA's Avatar
My System: HUMAX 5400Z
Thanks Vinniek
REDA REDA REDA is offline   Reply With Quote
Old 12-10-2007   #21
My System: Dreambox 7020, iMac 24
Can someone post the doc to emailed removedd cause I can not access it although I am registered here?
Thanks in advance
Nikos
nickbit is offline   Reply With Quote
Old 12-10-2007   #22
Unfortunately i cant make the whole thing works.I followed step by step the procedure in the doc but...nothing.
I've got 2-3 questions to ask.Firts of all,when everything with dreamview is ready,i choose the channel i want--Edit Stream data,copy that,open a VLC(open network stream-->Http..etc)and put it in the blank,erase PW @and UN -->chosse settings-->make all as the doc says.....and then?Shall i have to close the VLC?Press ok one time (get out from the settings menu) and let the player running?Press ok two times and let VLC streaming from my LAN IP before i open http://mydyndnsip:8080?
My other huge problem is that when i strat streaming http://mydyndnsip:8080 my connection to the net collapse.Is that a port blocking problem?
Thanks and sorry for asking too many questions.
nonname_kid is offline   Reply With Quote
Old 12-10-2007   #23
mhku's Avatar
My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini
If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots
Please post only in English or one of the languages that have their own forum section.
Thank you.
You don't stop playing because you get old, you get old because you stop playing. Regras
Before posting in the Dreambox section please ensure you've read The Guide
Information is for educational purposes only
mhku is offline   Reply With Quote
The Following User Says Thank You to mhku For This Useful Post:
cygol (28-11-2007)
Old 13-10-2007   #24
Hi mhku,
why I can't dl the doc describing the Streaming??
Is it possible to forward it to me so I can try a few things at home?
The Following User Says Thank You to nickbit For This Useful Post:
purplehorse (14-06-2008)
Old 14-10-2007   #25
mhku's Avatar
nickbit- download it from here _http://www.sendspace.com/file/u9fc4g
dreambox, internet, stream
