Barry Allen | |
| International Administrator Join Date: 11-07-2005 Location: Setubal, Portugal
Blog Entries: 2 My System: DM800; Nokia 9800s; Nokia 9902S w/T-Rex 3.66 w/ Inverto IDLP-40TL + Technisat 33 dish; Pace DS430N + Humax HDCI-2000 w/ Gibertini OP 1.25m dish w/Inverto 0.3dB. & Invacom 0.2dB. w/ Spaun SAR 411; CAS 3;FUN7; SkyStar2; AltDVB; | Barry Allen Version 4.5.5 by gutemine from 22.05.2008 Barry Allen for Dreambox 7025, 7020, 600 and 800 Version 4.5.5 by gutemine from 22.05.2008 Release infos: 0.1.0 first official Version 0.1.1 add LCD support, copy, rename and erase 0.2.0 add backup and more tools options 0.2.1 bugfixes 0.2.2 quod erat demonstrandum 0.3.0 WebIF and Wizards 0.3.1 nl, 12 images, bugfixes 0.3.2 tar.bz2 images, instant extract 0.4.0 OE 1.5 support, Flashing and user scripts WebIF 0.4.1 keep squashfs and Barry Allen gets fat 0.4.2 time for a new version and new language fr 0.4.3 feeding the GNU 0.4.4 time for a new version 4.4.6 preliminary dm800 support 4.5.1 DM 800 support Thanks to noggie for his nfi file tools ! Thanks to DarkVolli for the enigma1 plugin ! 1) Prerequisites During the installation there has to be CF card in the Dreambox (attention: insert or remove into Dreambox 7025 cardreader only when Dreambox is turned off), or an USB stick which is successfully detected (in case of problems try an USB Hub). If Barry Allen on USB is used then put the CVS Image from OoZooN in Flash, because this image has the USB drivers permanently built into the kernel. If neither CF card not USB Stick are attached then installation takes place on the Harddisk. Because the images then also run from there it will run permanently and it could be necessary that you disable Harddisk Standby in the images to allow running Barry Allen stable from Harddisk. 2) Installation First boot from Flash and then copy the file enigma2-plugin-extensions-barryallen*.ipk to /tmp with ftp (TCP/IP must be working already). If you have an image in Flash that offers a Blue Panel Manual Add-on Install, then you can use this functionality to install the ipk file. If not, then install Barry Allen by entering the following commands in a Telnet session: cd / ipkg install /tmp/enigma2-plugin-extensions-barryallen*.ipk Then restart enigma2 and the Barry Allen Plugin shoudl show up under Games / Plugins. In the Images installed by Barry Allen you don't have to install the Barry Allen Plugin anymore. The Barry Allen Plugin integrates himself into then automatically during the image extract. And you can remove Barry Allen if you are booted from Flash: ipkg remove enigma2-plugin-extensions-barryallen 3) Usage There is now the enigma2 Plugin of Barry Allen included under Games / Plugins of the enigma2 menu, which offers the full functionality of Barry Allen. For extracting of nfi images in Barry Allen copy the image files to /MB_Images (normally a link to /media/hdd/MB_Images created during Barry Allen installation) If there are Problems with image extraction or other tasks with the enigma2 plugin try doing it in telnet: cd /media/ba ba.sh extract nameoftheimage On the next reboot this new Image should be available in the bootmanager for choosing to boot it and then it can be customized and used as usual. The Bootmanager now should remember the last booted image and hence recordings from Deepstandby should work now.
__________________ ![]() ![]() | ||
| The Following User Says Thank You to rato For This Useful Post: | vitoral (22-06-2008) |
Blog Entries: 2 My System: DM800; Nokia 9800s; Nokia 9902S w/T-Rex 3.66 w/ Inverto IDLP-40TL + Technisat 33 dish; Pace DS430N + Humax HDCI-2000 w/ Gibertini OP 1.25m dish w/Inverto 0.3dB. & Invacom 0.2dB. w/ Spaun SAR 411; CAS 3;FUN7; SkyStar2; AltDVB; | O Barry Allen é um plugin que serve para ter a possibilidade de escolher varias imagens para boot. Tem-se uma que está na flash do receptor. Os outros encontram-se numa pen USB. Ao ligar a DM ou ao fazer um restart, aparece uma lista das imagens instaladas na pen(ex: Nabilo; ronaldd; Gemini)mais o que está na flash. A partir da lista é escolher a imagem que pretende.
| Regular Member Join Date: 19-05-2006 Location: lisboa
My System: dreambox 500s | Ok, ainda tou a dar os primeiros passos com a dm800 e é um bocado complicado. Para por as imagens na pen é so copiar ou é preciso criar alguma pasta? e ja agora como é que instalo o bary allen? é que o ingles nao é o meu forte ![]() Last edited by vitoral; 22-06-2008 at 03:08 AM. | ||
| | #5 | ||
Barry Allen Version 4.5.7 Barry Allen for Dreambox 7025, 7020, 600 and 800 Version 4.5.7 by gutemine from 14.06.2008 Release infos: 0.1.0 first official Version 0.1.1 add LCD support, copy, rename and erase 0.2.0 add backup and more tools options 0.2.1 bugfixes 0.2.2 quod erat demonstrandum 0.3.0 WebIF and Wizards 0.3.1 nl, 12 images, bugfixes 0.3.2 tar.bz2 images, instant extract 0.4.0 OE 1.5 support, Flashing and user scripts WebIF 0.4.1 keep squashfs and Barry Allen gets fat 0.4.2 time for a new version and new language fr 0.4.3 feeding the GNU 0.4.4 time for a new version 4.4.6 preliminary dm800 support 4.5.1 DM 800 support 1) Prerequisites During the installation there has to be CF card in the Dreambox (attention: insert or remove into Dreambox 7025 cardreader only when Dreambox is turned off), or an USB stick which is successfully detected (in case of problems try an USB Hub). If Barry Allen on USB is used then put the CVS Image from OoZooN in Flash, because this image has the USB drivers permanently built into the kernel. If neither CF card not USB Stick are attached then installation takes place on the Harddisk. Because the images then also run from there it will run permanently and it could be necessary that you disable Harddisk Standby in the images to allow running Barry Allen stable from Harddisk. 2) Installation First boot from Flash and then copy the file enigma2-plugin-extensions-barryallen*.ipk to /tmp with ftp (TCP/IP must be working already). If you have an image in Flash that offers a Blue Pannel Manual Addon Install, then you can use this functionality to install the ipk file. If not, then install Barry Allen by entering the following commands in a Telnet session: cd / ipkg install /tmp/enigma2-plugin-extensions-barryallen*.ipk Then restart enigma2 and the Barry Allen Plugin shoudl show up under Games / Plugins. In the Images installed by Barry Allen you don't have to install the Barry Allen Plugin anymore. The Barry Allen Plugin integrates himself into then automatically during the image extract. And you can remove Barry Allen if you are booted from Flash: ipkg remove enigma2-plugin-extensions-barryallen 3) Usage There is now the enigma2 Plugin of Barry Allen included under Games / Plugins of the enigma2 menu, which offers the full functionality of Barry Allen. For extracting of nfi images in Barry Allen copy the image files to /MB_Images (normally a link to /media/hdd/MB_Images created during Barry Allen installation) If there are Problems with image extraction or other tasks with the enigma2 plugin try doing it in telnet: cd /media/ba ba.sh extract nameoftheimage On the next reboot this new Image should be available in the bootmanager for choosing to boot it and then it can be customized and used as usual. The Bootmanager now should remember the last booted image and hence recordings from Deepstandby should work now.
| | #6 | |||
| Regular Member Join Date: 11-04-2006 Location: PT
My System: Dreambox 600S e Edision 1120cx | Aqui fica uma tradução feito pelo nosso amigo "google": ------ 2) Instalação Primeiro boot através de flash e, em seguida, copie o arquivo enigma2-plugin-extensões-barryallen *. IPK a / tmp com ftp (TCP / IP deve estar trabalhando já). Se você tem uma imagem em flash que oferece um Azul Pannel Manual Addon Instalar e, em seguida, você pode usar este IPK funcionalidade para instalar o arquivo. Se assim não for, então instalar Barry Allen, digitando o seguintes comandos em uma sessão Telnet: cd / ipkg install / tmp/enigma2-plugin-extensions-barryallen *. IPK Em seguida, reinicie o enigma2 e Barry Allen Plugin deve mostrar-se sob Jogos / Plugins. No Images instalado por Barry Allen você não tem para instalar o Barry Allen Plugin anymore. O Barry Allen Plugin integra-se em seguida automaticamente durante a imagem extrato. E você pode remover Barry Allen se você for inicializado de Flash: ipkg remover enigma2-plugin-extensões-barryallen 3) Utilização Existe agora o enigma2 Plugin de Barry Allen incluiu sob Jogos / Plugins do enigma2 menu, que oferece a funcionalidade completa de Barry Allen. Para a extração de ajuda não alimentar imagens em copiar o Barry Allen arquivos de imagem para o / MB_Images (normalmente um link para / media / hdd / MB_Images criados durante Barry Allen instalação) Se há problemas com a imagem extracção ou outras tarefas enigma2 com o plugin tentar fazê-lo em telnet: cd / media / BA ba.sh extrato nameoftheimage Na próxima reinicialização esta nova imagem deve estar disponível no bootmanager de escolha de iniciá-la e, depois, ele podem ser personalizados e usados como de costume. O Bootmanager agora devemos esquecer o passado arrancado gravações de imagem e, consequentemente, devem trabalhar Deepstandby agora. ------ Cumps. | |||
