Pls Help me receive adult channel | |
| Member Join Date: 21-04-2008 Location: INDIA
My System: TATA SKY |
Hello I am newbie i was going and i was going through an article which says this.1) Can you ppl please confirm by doing this how can i see adult channels and also there frequencies if possible.Thnx all of you in advance There is A Secret Menu in Tata Sky, it will help you to get out of the Hung screen saying ONE MOMENT PLEASE.... All you have to do to enter the menu is. 1>Press ORGANISER on your Tata Sky Remote. 2>Press 5 (or System Settings Menu). 3>Now Quickly Press 0,1, Select (the centre Button). 4>You should now see the INSTALLER SETUP Screen.. if not Repeat the steps Again. 5>Here You Get 3 Options: 1>LNB SETUP 2>RF OUTLET 3>MANUAL TUNING 1>LNB Setup the Default Settings ARE: LNB TYPE: DUAL LO Frequency:09750 High LO Frequency:10600 Spectrum Inversion: Normal Don't Forget to Save Settings And Exit 2> RF OUTLET UHF/VHF Outlet Channel Can Be Changed Here (Default 68) 3> Manual Tuning Signal IN4A-14 (ie. INSAT 4A Transponder 14) Here you get to select the signal from the Satellite Transponder (Just incase you decide to change the Service Provider to Dish TV or Reliance Blue or if you go to a Foreign country with your Satellite Receiver). | ||
| SAT HUNTER Join Date: 20-08-2007 Location: india
My System: One 12 Feet Heavy Antenna, one 10 Feet Double Rib Antenna Dreambox Dm500S, DM 7025. HD Receiver,Envision, Eurostar receiver, 4 Dual LNBS, 5 PFA Lnbs | This info is TOTAL FAKE THERE IS NO ADULT CHANNEL ON INSAT SAT... | ||
My System: TATA SKY | | ||
| Section Leader Join Date: 10-05-2007 Location: north west india
My System: coship receiver 2000,Dreambox 500;2 ku3cband dishes of 2,4,6&8feet,amd 64 pc with 1GB ram usb tv tuner card | Dear Jammy,if you are prepared to invest for a big dish of 6/8 ft of good quality with appropriate LNB and receiver,you will get channels having occasional erotic content in neither english nor hindi language. | ||
