any body knows about ren tv it is not on 80 degree
Thread Tools Display Modes
Old 18-05-2007   #1
jtahlian's Avatar
My System: Jp singh c band 8 feet dish co ship CDVB2000B receiver
Smile any body knows about ren tv it is not on 80 degree
hello friends,
i am living in north India Punjab i have a c band regular 8feet dish and co ship dvb2000B receiver i was getting ren tv four channels and 7 tv ,and a few another Russian channels on 3675 sr 33484 but from few weeks i am not getting ren tv's channels and i have checked the lyng satellite news they said that ren tv left 80 degree so please tell me where to get the channel or may i watch any other channels similar to ren tv if yes the please provide me the direction and feeds and required information to caught the channels with my equipments
thanks a lot
jtahlian is offline   Reply With Quote
Old 18-05-2007   #2
Section Leader
member91040's Avatar
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S
Ren Tv is Available on
Yamal 201
Yamal 202
Eutelsat W4
Eutelsat W4
Sirius 3
Home Page : _h**p://www.ren-tv.com
__________________
member91040 is offline   Reply With Quote
Old 18-05-2007   #3
jtahlian's Avatar
on yamal 201 90 degree that does not show playboy movie if you know please send me c band details i shall be thankful to you
Old 18-05-2007   #4
Section Leader
I can abele to send you, But all are pay ...! what i know...! what do you say.
__________________
Old 14-06-2007   #5
My System: Zenega 1004iS Receiver + Chainees FTA STB with 60 & 120 Cms fiber dish + PIV Pc, My Sats: ABS1, NSS6, DD DTH, Mob: 9811786161
Any one getting Yamal 90*E Ren Tv in Delhi Pls confirm and give me tp sr for the same
matri is offline   Reply With Quote
Old 14-06-2007   #6
Site administrator
Analoguesat's Avatar
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S
http://www.flysat.com/yamal90.php
__________________
Analogue forever!
RIP BBC2 analogue on all Scottish Borders transmitters, switched off 0031GMT November 6th 2008
Final analogue switch off from all Scottish Borders transmitters - BBC1 ITV C4 & C5 - 0010GMT November 20th 2008.
Analoguesat is online now   Reply With Quote
The Following User Says Thank You to Analoguesat For This Useful Post:
matri (14-06-2007)
Old 15-06-2007   #7
My System: 10 feet dish universal c band lnb eurostar 9700 FTA stb
hello friends,
thanks a lot
ren is available at yamal 202 49 degree at C Band even in 6feet dish at kerala
unni is offline   Reply With Quote
Old 20-07-2007   #8
surajhegde
My System: i am service engineer
thanking u information is very good
surajhegde is offline   Reply With Quote
Old 20-07-2007   #9
SATELLITE SNIFFER
mehra's Avatar
My System: Dish Tv complete equipment- 70 cm Ku Antenna, Kaon KSC-i260 MCO, Two Dish Tv OE universal LNBF, 6' C Band Antenna, Eurostar C band LNB. All attached to NSS6-ABS1-Thaicom
Wink
Yamal 201
Yamal 202
Eutelsat W4
Eutelsat W4
Sirius 3
can u read russian ???!!!
mehra is offline   Reply With Quote
Old 21-07-2007   #10
Section Leader
Yes Mehra Bro...!
__________________
Old 11-10-2007   #11
ren tv is at yamar 202 49 c band 6feet dish is enough but with teflon
The Following User Says Thank You to unni For This Useful Post:
jinx1985 (29-01-2008)
Old 25-03-2008   #12
My System: i hve dish tv only and pc with window xp
hello sir im here as danishsplender2000
sir im in moradabad now i want to know how can i access adult channels in my city which is in up moradabad can i get ur email pls or pls pm me i want to ask many thing to u please reply me and how can i access theesseee channels in moradabd actually imnew to this site thats why i dnt hve any knowledge about satellite what are lyngsat and what is yamal what is kuband etc please tell me in breif
thanks
danishsplender2000
danishsplender2000 is offline   Reply With Quote
Old 25-03-2008   #13
rolfw's Avatar
We have been receiving our Direct To Home television service from a ring of satellites, parked in fixed (Geostationary)locations over the equator, this area is known as the Clarke Belt.
The vast majority of DTH TV transmissions are broadcast in the 10 - 12.75Ghz band, commonly known as the Ku-Band, although some are broadcast at much lower frequencies, in what is known as C-Band, these generally are lower powered and require bigger dishes.
Over the years, the transmitting power of many of these Ku-Band satellites, has become stronger, requiring smaller dishes for trouble free reception in the target transmission areas. The reception strengths in close, but non-target areas is roughly mapped in what are called Footprint charts, these will enable you to work out what sized dish you will require for those satellites which are not directly aimed at your location.
See here for some examples:
http://www.satellites.co.uk/satellite/684087-post3.html
http://www.lyngsat.com/asia.html
To receive signals from these satellites, you need a dish of appropriate size, and LNB (Low Noise Block Converter) these can also be known as LNBF and LNC, but best not to go into too much detail here.
You can receive these channels via a static dish aimed at one satellite, a multi satellite dish, with several LNBs on offset brackets pointing at several satellites, or a motorised dish, which can swing around the visible arc of satellites. One dish pointing at one satellite cluster, will not be able to pick up other satellites, unless it is moved, or has an offset bracket with further LNBs, as alignment of the dish needs to be very precise.
Now you need to do a bit of reading in this section and others, after this, then people will be happy to answer your questions.
__________________
Rolf
Donate
Old 17-05-2008   #14
My System: CABLE NET WORK
help
hellow,
i m rajeeb from kolkata i am missing ren-tv friends please help me i want to know can i run it at yamar 202 49 c band 6feet dish is enough with teflon
Sirius 3
i dont know any thing about teflon what is it and what about Eutelsat W4
Eutelsat W4 what is the best and how much cost required for total system please help me i am have now bakwas cable network where no any ftv no any ren nothing special in it :mad
RAJEEB is offline   Reply With Quote
Forum Jump
