Satellite Dishes | |
| Info Exec Join Date: 09-10-2002
Different kinds of Satellite Dishes 1) Offset antenna 2) Prime focus antenna 3) Flat antenna 4) Cassegrin antenna 5) Multi focus antenna Offset antennas These antennas represent just a part of a parabolic or prime focus antenna. Their focus is not in the geometrical centre of the dish but a bit lower. Since the LNB doesn’t stand in the way of the signal these antennas can be smaller than others. Prime focus antenna Prime focus antennas have a parabolic shape and characteristic is that the focus is in front of the centre of the parabola in the geometrical centre that is. That means if the LNB is attached to this antenna it can be found above the middle of the antenna and so the LNB blocks a part of the emitted signals and therefore these antennas have to be bigger than offset antennas. Offset antennas replaced these antennas nearly completely. Today they are mostly used for the reception of signals in the C belt, since these are the only antennas that are built in scopes up to 10m. Cassegrin antennas These antenna with two reflectors receive signals better. It looks like an offset antenna with the exception that in the place where the offset antenna has a LNB attached the cassegrin antenna has an additional reflector, which has the task to reflect signals coming from the main reflector onto the LNB, which is placed on the LNB-carrier in front of the small reflector. This means the signals are reflected twice before they get to the LNB. Gregorian dish A subversion of satellite antenna that uses a concave hyperbolic reflector that points signals to the converter and that is placed opposite of the main reflector. Flat antennas This antenna is made of many units, which receive signals, afterwards this received signals are united and directed to the LNB. Technically speaking this antenna collects electromagnetic waves. Since this antenna receives through several units it receives a stronger signal. This antenna can be smaller than advised for several areas. Multi focus antennas These antennas are made not long ago. They are offset antennas, which have a specially built reflector, which reflects received signals from surrounding satellites to one focus. You can recognize such an antenna easily, since it quadratic and it’s longer than wider. .................................................. .................................................. ..... | ||
| -------------------------------------------------------------------------------- EIRP & DISH SIZE LNB 0.6dB EIRP in dB~~~~Dish size in cm. 64----------------22 63----------------24 62----------------26 61----------------28 60----------------30 59----------------32 58----------------34 57----------------36 56----------------38 55----------------40 54----------------45 53----------------50 52----------------50 51----------------55 50----------------60 49----------------60 48----------------70 47----------------75 46----------------80 45----------------90 44----------------90 43----------------100 42----------------110 41----------------120 40----------------120 39----------------135 38----------------150 37----------------180 36----------------240 35----------------300 34--------------- 360 32----------------450 30----------------570
__________________ You never know | ||
Similar Threads | ||||
| Digital satellite viewers lose free channels | net1 | B Sky B Digital and 28.2 East General | 5 | 16-06-2005 01:22 PM |
| R.R. Satellite Communications Ltd with Viaccess | net1 | Daily Satellite and Broadcast industry News | 0 | 06-01-2004 07:34 PM |
| Last-minute deal on free-to-air satellite | net1 | B Sky B Digital and 28.2 East General | 11 | 29-10-2003 11:29 PM |
| EchoStar launches ninth satellite | net1 | Daily Satellite and Broadcast industry News | 0 | 08-08-2003 06:22 PM |
| Will the BBC's satellite dream ever take off? | net1 | Daily Satellite and Broadcast industry News | 0 | 26-06-2003 08:49 PM |
