nylon cogs for the 90 cm Fibo motor.Section specifically for discussion by owners and would be owners of the Fibo Gregorian dish and clones | |
| Member Join Date: 30-07-2007 Location: North west London
My System: technomate 7800 |
Hi does anyone know a company in the UK where i can buy the nylon cogs for the 90 Cm fiblo motor. I did find a company in germany that sold then. But what with bank charges etc etc it will cost about £20.00 pounds just for the bank charges all because they wont accept a easy payment ie like paypal or normal debit cards. If this is the only way. I supposed i will have to bite the bullet. but i would rather find a cheaper way if possible. Anyone can help with details on this would be great. Russ | ||
| | #2 | |||
| Oldgeezer Join Date: 04-09-2004 Location: West Mids, UK
My System: Topfield 5800 Echostar3000,DB7000, Relook 400S, Humax HDC2000, 55cm Fibo Gregorian dish with waveguide and Motek 2100 mod, 90cm Fibo Gregorian dish, 120cm Fibo Gregorian dish on a 1224 motor with waveguide | Don't know any company with spares, but I do have a few spares, including nylon pinions and might be persuaded to part with one to a deserving cause. ![]() What is wrong with yours, is it just general wear and tear, or has the dowel deformed the slot. PM me John | |||
| Oldgeezer | ||||
| Regular Member Join Date: 27-06-2006 Location: Amsterdam
My System: Skystarcard,Fortec's life time ultra's, MaxPlus 2100's,Dreambox and a Tandberg | Rus I can help you for all parts of all models from it. Only i'am not in the UK i'am in Amsterdam The Netherlands Ron | ||
| Member Join Date: 15-03-2007 Location: uk
My System: Dreambox 7000s dreambox 500s humax 5400 90cm gregorian dish motor knacked | Hi, I have the same trouble my motor has gone on my fibo 90cm dish the dish has moved right over to the west and when i try and move the dish back to the east its moving a bit then drops down back the the west ? does anyone know what it could be ?. best regards paulh1966 | ||
| | #5 | |||
| Regular Member Join Date: 01-01-2000 Location: Rainham, essex
My System: 90cm gregorian 5way zone2 |
had simular issues, went one way but kept trying to go back but wouldn't. The long bit of SS 10mm dowl that runs through the motor pivot point, thats held in but a scrole pin, had surface corrossion, removed cleaned and refitted, now ok | |||
| | #6 | ||
| Specialist Contributor Join Date: 25-04-2005 Location: Austria
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband! | no problem,with my h to h mount from jager,since now over 7 years on fibo 90 cm works like on the first day the reason that not many people acepts paypal,in german speaking area is,that is first 2 expensice,2,is it not secure,like paypal promize to there costomors,i often read reports ,that people send money,the seller,sends the goods out,that are some problems with,mostly stolen credit cards,and then paypal takes back mony from the acount,you have no good and paypal hold back your money normal bank to bank transfer in germany esasely on onlinebanks are free of charge in europe,or only 20 cent per transfer,so there is no use to use paypal | ||
| | #7 | |||
From the symptons, it is most probably some broken teeth on the nylon pinion, it may be a broken 3mm drive pin in the motor shaft or a damaged pinion where the drive pin engages. There are other possibilities but these are the most likely. You will need to take the motor off to find the actual cause. Be sure to secure the dish before taking the motor out, they can damage the dish if it hits the mount. ![]() I think that the biggest single fault of the Fibo mount is the lack of any hard wired limit swithes. The motor has enough torque to break the pinions and/or the drive pin, if accidentally overdriven, this is usually the cause of damage to them. | |||
| Oldgeezer | ||||
| | #8 | ||
My System: Skystarcard,Fortec's life time ultra's, MaxPlus 2100's,Dreambox and a Tandberg | Its also posible to send a closed envelope with the Euro's inside. I have send last time 2 of that parts to the UK in a small carton box for +/- 30 Euro's total I can let make it from a special metal# but must make 20 peices minium. # No coper but same color ' Sorry my bad English | ||
| | #9 | |||
My System: Topfield 5800 Echostar3000,DB7000, Relook 400S, Humax HDC2000, 55cm Fibo Gregorian dish with waveguide and Motek 2100 mod, 90cm Fibo Gregorian dish, 120cm Fibo Gregorian dish on a 1224 motor with waveguide | ![]() The nylon pinion acts as a safety device at the moment, if you make metal pinions this increases the chances of damaging the internals of the motor, or breaking off the diecast teeth on the quadrant, a worse result. Would also probably be noisier. The nylon pinions are good enough for the job, unless overdriven. | |||
| Oldgeezer | ||||
| | #10 | ||
My System: Skystarcard,Fortec's life time ultra's, MaxPlus 2100's,Dreambox and a Tandberg | Thats 100% correct i will see what is the price if i let make it from Delrin or Teflon. | ||
| cogs, fibo, motor, nylon |
