CM Polar Mount and Fibo | |
| Regular Member Join Date: 04-09-2004 Location: Hounslow
My System: Echostar AD3600IPVA, White Inverto 0.3db LNB, Fibo Gregorian 1.2mtr, Skystar 2 |
Hi, Does the CM Polar Mount Fit the fibo??? Does anybod have a closeup picture of the CM Polar mount? Regards | ||
| Specialist Contributor Join Date: 23-07-2005 Location: S.Wales
My System: 1.2M & 55cm Gregorian Dish`s, 1.5m Gibertini on a Jaeger 1224 H-H motor. Dreambox 7025 200gb HD, Vbox-II. SS2 Card. | Yes it does fit with a little modification ![]() You have to add some angle brackets to the bottom set of bolts and also extend the threaded bar at the top. I think scopous is the best person to ask as its his mod. Was thinking about doing it my self. I have a C/master 1.2m dish and polar mount here if you want too swap them for your 1224 mate? | ||
| The Following User Says Thank You to CROSSBONES For This Useful Post: | olisun (25-11-2007) |
| | #3 | |||
Thanks for the images...I will contact scopous to get more details out of him... As of now I am not selling the 1224 but may do so once I manage to sort out a decent mount for the Fibo | |||
| Regular Member Join Date: 25-04-2005 Location: Austria
My System: 1,25 Fibostop Jäger Smr 1224 Dual Axsis Echostar Dvr 7000 Monterey 140 Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesch for cband! | Hello! i bought this mount in auktion house should reveive this week! then i can try after winter is over on other antennas, is there,a special adapter plate nesercary,between the polarmount,and the antenna,i have the 90 cm cm,but curencly not installed coz the polarmount was missing,now the system is complete i hope.. maybe still miss some parts? to conect th emount,on the backside? i only heavey big 36" acutrators,maybe i must buy small 8" acurator,outerwise it could happen that i dont have the full range,like on gibertini ,when i use big motors,so what should i do? | ||
| | #5 | ||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorkshire, uk
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | 18inch actuator should be well enough for a 90cm dish | ||
| | #6 | |||
You would have to drill new holes for the location of the 90cm mounting bolts on the adapter plate. An 18" actuator would be fine for that channel master mount. Can you get hold of any more c/master polar mounts? | |||
| | #7 | ||
My System: Echostar AD3600IPVA, White Inverto 0.3db LNB, Fibo Gregorian 1.2mtr, Skystar 2 | | ||
| | #9 | ||
My System: 1,25 Fibostop Jäger Smr 1224 Dual Axsis Echostar Dvr 7000 Monterey 140 Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesch for cband! | we have nothing to share,coz we have no secrets ![]() i dont have this adapter,for the smr,where i can find it articel number? | ||
| | #10 | ||
My System: 1.2M & 55cm Gregorian Dish`s, 1.5m Gibertini on a Jaeger 1224 H-H motor. Dreambox 7025 200gb HD, Vbox-II. SS2 Card. | You have the adaptor on your 1.2m Fibo. -http://www.satshop24.de/cgi-bin/satshop24/iboshop.cgi?show310,47286148720818 Adapterplatte fürSMR 1224 | ||
| | #11 | ||
My System: 1,25 Fibostop Jäger Smr 1224 Dual Axsis Echostar Dvr 7000 Monterey 140 Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesch for cband! | Hello Crossbones! Good Morning! now,after a long search,of 5 years i have found a used fibo 1,25 mount,but there was now screws includes,what type must i use? also i have a new channel master mount,the size is here 9 cm,and fibo mount has 8,5 cm to fit it! now,i diinstall my jager dual axis system,with gibertini mount that never works corectly,any always must use a . positioner for the western and eastern stalites,hope soon cold rainy weater will be ofer.. maybe i also try to install the channel master mount on the triax 1,40 m dish! | ||
| | #12 | |||
Can you send me the exact measurements of those 2 plates please? | |||
| | #13 | ||
My System: 1,25 Fibostop Jäger Smr 1224 Dual Axsis Echostar Dvr 7000 Monterey 140 Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesch for cband! | Hello Olisun! okay,no problem,i recharge my camera at the moment i measure it s.a.p.for you! you only want the size of the adapter plate? yes thoose parts,very expensice,i paid nearly 100€ each,coz shipping was aroung 40€ each item..very heavey the cm mount much more then the fibo,on the fibo mounts and channel master all screws are missing.. what type is exactly needed on each mount? | ||
| | #14 | |||
| | #15 | ||
| The Following User Says Thank You to olisun For This Useful Post: | CROSSBONES (17-06-2008) |
| | #16 | ||
My System: 1,25 Fibostop Jäger Smr 1224 Dual Axsis Echostar Dvr 7000 Monterey 140 Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesch for cband! | Hello Olisun! okay i mearure now the cm plate for you,sorry for the delay ![]() lenth is 21 cm ,and the high of the back plate 19,5 cm do you need more size? | ||
