Jeager 1224 EL with 1.2 Fibo | |
| | #51 | ||
| Regular Member Join Date: 25-04-2005 Location: Austria
My System: 1,25 Fibostop Jäger Smr 1224 Dual Axsis Echostar Dvr 7000 Monterey 140 Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesch for cband! | yes there is only conax slot integrated! on pansat 3500 modell you can save the receiver setings and the programm setings to sd memory card blind search is very long first the h then the v position but you can save back with in secounds! then the only way,buy in thailand the dynasat f1 +++dynasat.com with this you have scew 36 v controll and ci what you need! price aproxiemntly 130€ + shiping and tax! | ||
| | #52 | ||
| Member Join Date: 13-08-2008 Location: Italy
My System: Echostar DVR7000 - Egis Rotor - 180 cm prime focus dish -Chaparral Polarotor I Ku Wideband - Astrotel Precision 0.6 dB Quad Wideband LNB. | I went to Dynasat web site but the F1 does not seem to have all the characteristic you are mentioning. | ||
| | #53 | ||
My System: Echostar DVR7000 - Egis Rotor - 180 cm prime focus dish -Chaparral Polarotor I Ku Wideband - Astrotel Precision 0.6 dB Quad Wideband LNB. | A very good and well working receiver with 36v positioner and Common Interface by now is the TOPFIELD 5000 CIP (Pro version). Very stable and usable, but it does not have Blind Search and/or High Definition capabilities. | ||
| | #54 | ||
My System: 1,25 Fibostop Jäger Smr 1224 Dual Axsis Echostar Dvr 7000 Monterey 140 Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesch for cband! | very good thx for the info,what is the difrence,in the pro version? maybe there other 36 volt receivers,in the indian and south east asian market of unkown brands,that we dont know here in europe?! | ||
| | #55 | ||
My System: Echostar DVR7000 - Egis Rotor - 180 cm prime focus dish -Chaparral Polarotor I Ku Wideband - Astrotel Precision 0.6 dB Quad Wideband LNB. | There are three Topfield 5000 Digital receivers models: 5000 CI, 5000 CI Plus, 5000 CI Pro and only the PRO has the 36v motor and mechanical polrizer support. You can see it at Topfield web site. ***.topfield.co.uk | ||
| | #56 | ||
My System: 1,25 Fibostop Jäger Smr 1224 Dual Axsis Echostar Dvr 7000 Monterey 140 Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesch for cband! | can this receiver also store scew by transponder,or only by satelite? | ||
