Fibo Dish Problem
Section specifically for discussion by owners and would be owners of the Fibo Gregorian dish and clones
Old 11-12-2007   #1
AndyX's Avatar
My System: Technomate 5000adip Fibo 1.2dish Mesh Computer with Skystar 1 card
Fibo Dish Problem
Help
my Fibo dish, operated by a Technomate 5000ADip has taken to suddenly turning as far west as it can go without me being able to stop it. It is doing this aoccassionally while I am focusing in on a satellite.
Any ideas what is going on?
I have checked the connections
AndyX is offline   Reply With Quote
Old 12-12-2007   #2
CROSSBONES's Avatar
My System: 1.2M, & 55cm Gregorian Dish`s, 1.8m Precision dish Jaeger 1224 H-H motor.Dreambox 800, Vbox-II. SS2 Card.
Have you a different receiver you could try the dish on?
Maybe its a fault with the technomate?
CROSSBONES is offline   Reply With Quote
Old 12-12-2007   #3
RedDevil_UK's Avatar
My System: Sky+ Multiroom,Thompson PVR, Dreambox 7000S, 300gig HDD, 1.1m Dish, Moteck SG-2100A DISEQC Motor, Gemini image, 2g USB Stick.
A defender of the Remote Control Brigade, Sir R can flick channels faster than a Robben dive
How windy is it?
sorry
have you changed any setting on the box recently? have you tried unplugging the box for 10 mins... might be a sofware fault.
"A Wise Man can see more from the bottom of a well than a Fool can see from the top of a mountain."
RedDevil_UK is offline   Reply With Quote
Old 12-12-2007   #4
AndyX's Avatar
There is no wind problem. The receiver has been off over night.I also have tried a factory reset. Unfortunetly things have got worse. After the last lurch to the west the motor now shows no signs of life. The Technomate clicks as per normal when it tries to move the dish. I checked in side the receiver for any obvious damage such as blown capacitors.
i am getting a Technomate Vbox 5 volt for Christmas, so if it is the receiver, I will be able to check the possibility for the receiver being at fault.
I don't know if there is any sort of circuit breaker on the Fibo motor should the dish be pushed to the west limit by a fault on the receiver. A diagram may be handy. Otherwise it may be difficult to replace the motor with the manufacturer ceased trading.
Thanks for your suggestions guys
Old 12-12-2007   #5
Oldgeezer
johnsattuk's Avatar
My System: Topfield 5800 Echostar3000,DB7000, Relook 400S, Humax HDC2000, 55cm Fibo Gregorian dish with waveguide and Motek 2100 mod, 90cm Fibo Gregorian dish, 120cm Fibo Gregorian dish on a 1224 motor with waveguide
As said before, one of the main concerns with the Fibo mount is the lack of any hardware limit switches.
If there is a fault with the receiver or an accidental overdrive, it does over stress the motor, often damaging the pinion and/or the drive pin. There is no O/L mechanism on the motor.
One or two of us do have some spares around, when you find out what the problem is. You will probably need to take the motor off the mount to investigate. be aware that with the motor removed, the dish is free to flap about and damage you or itself.
There are also motor mods that use a reed sw. so that you don't need the 5v , which is becoming harder to source.
Fibo Dish Problem-fibo90_motor_connections-jpg
Oldgeezer
johnsattuk is offline   Reply With Quote
The Following User Says Thank You to johnsattuk For This Useful Post:
AndyX (14-12-2007)
Old 14-12-2007   #6
AndyX's Avatar
An update: I found my old Echostar AD2000ip and connected everything up. The receiver attempted to drive the dish but there is not a peep outside from the motor. I guess the next stage is to dismantle the dish and check the motor visually for damage. My father is an ex telecoms engineer who is good with electrical things so I might take it over to him to look at. If it is not repairable I might have to use my old channel master 1.2 dish, sitting in my shed thus leaving, sadly, the Fibo owners club.
Old 15-12-2007   #7
wod
wod's Avatar
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+
no you could fit a jaeger 1224 motor to the fibo dish to replace the current motor if that is broken
Old 15-12-2007   #8
Oldgeezer
johnsattuk's Avatar
If you can make/get made suitable bracketry, you could use a 'jack' to drive the dish on its existing mount. The reinforcing ring on the back of the dish is quite substantial enough to accept a bracket at the right sort of radius.
I do have spare Fibo motors.
Oldgeezer
Old 15-12-2007   #9
CROSSBONES's Avatar
or take a look at the alternative motor set up`s, you could mod your c/master polar mount quite easy to fit your fibo
Fibo Gregorian - alternative motor setups
Old 15-12-2007   #10
My System: Skystarcard,Fortec's life time ultra's, MaxPlus 2100's,Dreambox and a Tandberg
Andy X
I have never see a Fibo motor that not can be repair.
All and i meen ALL parts are on the market for it the motor are also complete to buy and a inside motor is also for sale at the orginal company that make then for Fibo-Stop in Holland.
Perhaps a idea to make:
2 micro switches 1 on East and 1 on West zo he can not break te glog.
simple to make the 36 Volt line + and - first to the micro and then to the motor.
use a smal Ampere meter down at the reciever to see the Ampere that the motor use when turns if this change there is a problem and you see always of there is a problem with the reciever, wire or motor.
Tip the ampere mter can be replaced by some leds and resitirs red and green.
With this system you have a complete control on all things happens.
My last idea are a small magnetic(electrical) that when no works when no power is to the motor to push a metalpin in a hole so the system are lockted.
P.s. sorry for my bad English
Snuffer is offline   Reply With Quote
Old 15-12-2007   #11
AndyX's Avatar
thanks for all your help: I am going to take the motor to my father next week and see if we can see what is gone and if we have the know-how between us. If unsuccessful, then plan B would be a the Jaeger suggested. From some of the images on this forum, it does not too complicated, just some holes drilled in the 2 brackets attached to the dish. I have always fancied an inclined motor option!
Does anybody know if it is possible to extract the motor without taking down the dish? I see there is a bolt underneath the motor.
Old 15-12-2007   #12
AndyX's Avatar
I might come back to for a price if that is all right
thanks
Old 15-12-2007   #13
Andy if you can not repear it i will plaese buy it from you we repair and help Fibo users with it, or repair for you.
Ron
Old 15-12-2007   #14
Oldgeezer
johnsattuk's Avatar
Not sure what you mean by inclined 'motor'
The axis that the dish rotates on is the inclination that controls how the dish tracks the arc, and the 'Fibo' certainly has an inclined axis. Where and how the motor is mounted will depend on the design of the gearbox etc, but wherever it ends up it does not affect the tracking of the dish.
The motor comes off quite easily, 4 x 8mm a/f pins, and should then just pull out easily. As mentioned before, once you remove the motor, the dish is free to flap about and knock you off your perch, I always tie it back to somthing first
If the motor has been overdriven, It may have bent the dowel pin which drives the delrin pinion and possibly damaged the pinion as well. This can sometimes make the motor more difficult to remove as it gets jammed in the housing.
Oldgeezer
Old 15-12-2007   #15
AndyX's Avatar
sorry johnsattuk, what I meant by inclined really meant the optional additional motor on the Jaeger for inclined orbit satellite s (I am into feed hunting). Anyway, that is if I give up on the Fibo motor.
Now the 4 x 8mm a/f pins you mentioned: I can't see them at the lower end of the mount so I presume they are hidden under the fan shaped top of the mount, this being the 1.2m version and not exposed as in the .9m version, so I presume I will have to take this section off first to access the a/f pins. I suspect I may have to dismantle the dish to access these a/f pins. Fortunately I have a ground mount in the garden and will be able to get help to lift the dish off the pole. With the short days, I will have to wait until I have a day off work now so I can see what I am doing. It will give me time to gather information from experts like yourself so I will know what I am doing
Old 15-12-2007   #16
Oldgeezer
johnsattuk's Avatar
Argh 'inclined orbit' sorry about that
The pins for the motor (4 off) are quite accessible, no need to dismantle anything to get at them.
Oldgeezer
Old 15-12-2007   #17
Oldgeezer
johnsattuk's Avatar
Having a senior moment day
On the 120cm you do need to lift the dish of the mount, there is a retaining pin with a retaining plate. If you loosen the pin and it is the origional retaining plate, it will unclip and allow you to lift off the dish.
Oldgeezer
Old 24-12-2007   #18
AndyX's Avatar
Hi John
thanks for your help so far. I have finally managed to look at the dish. I got help to remove the dish and found a bolt underneath going into the pivot and through a small plate. I have removed this pin, bolt & plate. I assume the fan shaped cover section should now lift of. I pulled upwards and did indeed get a slight movement. Unfortunately it will not budge any further. Am I doing the right thing, as I do not want to do damage by forcing the cover off? Could the motor be jammed?
Anyway, I guess I better get ready for the big day tomorrow.
Happy Christmas to the Fibo owners club
Old 24-12-2007   #19
Oldgeezer
johnsattuk's Avatar
Hi John
It does just lift off, however it is a short (approx. 70mm) stepped shaft about 60dia at the lower end, and needs to be pulled off squarely, much easier to achieve without the dish mounted. You may need to pry gently with a couple of bars
To complicate things, the bottom part of the shaft has a thin plastic shim/bearing ( about 0.12mm thk.) glued to it. I think this is to prevent the alu. shaft picking up on the alu. housing. Unfortunately this nearly always comes adrift and can then interfere with withdrawing the shaft. The other thing which can cause tightness is if the motor pinion has been damaged and is jammed against the gearquadrant, also if water has got in and corroded the shaft/bearing.
I have used scotch 'magic' tape on occasion to replace the plastic, you have to be careful not to use too much, else reassembly will displace it.
Taken a few pics, hope of some use.
Fibo Dish Problem-pict0045s-jpg   Fibo Dish Problem-pict0044s-jpg   Fibo Dish Problem-pict0042s-jpg
Oldgeezer
Old 25-12-2007   #20
AndyX's Avatar
thanks for the pics. They gave me confidence in removing the top. I have extracted the motor and brought it indoors. My intention is to try attaching the motor by a short length of 5 core to the Echostar, which I know works and see if the motor still shows signs of life. If it is dead I guess I will have to open the motor up an look for any damage. My concern is what caused the dish to shoot west to begin with. I would be fine adjusting a the dish to a satellite and then the dish would suddenly take of to the west, never the east. Switching the receiver off stopped the motor but switching the receiver back on allowed the dish to continue its lunge west.I am hoping it may be a reciver fault.I am not sure what to do next if these plans do not work, but if I can't get it going I do have my new remote controlled Dalek to play with
Old 25-12-2007   #21
Oldgeezer
johnsattuk's Avatar
The symptons do sound more like a reciever fault.
Oldgeezer
Old 26-12-2007   #22
AndyX's Avatar
....this is why I have brought my old Echostar into service to make sure I am using a reliable receiver. I have connected all the wires except the 5 volt and I tried moving the motor now out of it's shell. I got a little bit of life out of the motor before it stopped again. By gently pushing the larger metal wheel while pressing the west- east buttons,I was able to coax it to move again slightly. It only wants to move one way for a couple of seconds. Moving the wheel does turn all the cogs and turns the external gog that drives the dish. There is no obvious sign of damage.
This establishes:
the motor is working....a little bit
there is no physical damage
could it be that the motor is no longer strong enough to drive the dish and is damaged internaly?
Fibo Dish Problem-motor-1-jpg   Fibo Dish Problem-motor-2-jpg   Fibo Dish Problem-motor-3-jpg
Old 26-12-2007   #23
Oldgeezer
johnsattuk's Avatar
If you do not connect the 5v, you will not get pulses back to the reciever, ( unless you have converted it to a reed sw. ) and generally, recievers stop driving as soon as they lack pulses
The pulse circuit boards do fail on these motors occasionaly, usually due to a misconnection, or a fault in the reciever 5v supply
Oldgeezer
Old 26-12-2007   #24
AndyX's Avatar
Thank you John
I have now found some extra wire and attached the 5 volt. Unfortunately it has not made any difference. It does sound like if the optic circuit may have gone then. I think I may have to send the motor to Amsterdam for repair then. or buy a motor from you, if that is still on offer
Old 27-12-2007   #25
Take 2 wire's and a 36 Volts (or lower) power suply.
Put it direct on the motor and see of he turns. cross wire's and he must turn to the ather site.
If turns motor are ok.
If you turn the gold colored gogh insite the complete part must turn. This is the low resistens piont for turning by your hand.
If you will i can send a new print with the resistors etc on so you can switch it to see of this is broken.
Afther you test you send it back or keep it and pay for it.
When thats to mutch work send me that motor i send a revision motor to you.
All when you will it ofcourse
Sorry for bad Englisch
The Following User Says Thank You to Snuffer For This Useful Post:
AndyX (28-12-2007)
dish, fibo, problem
[IMG] code is Off
