V-Box for Fibo 90cm?
Thread Tools Display Modes
Old 08-06-2008   #26
My System: Skystarcard,Fortec's life time ultra's, MaxPlus 2100's,Dreambox and a Tandberg
Joekir
Simpel every box named what you will have the 2 relais black boxes also yours i see on the Photo.
Arround that you will find also a 5 Volts piont (best to search around a resistor) Take this for your 5 Volt and test perhaps he switch of the 5 volts and meseure the resitor of the V is drop down if yes remove this resistor and thats it.
Do you have a circuit diagram of it??
Ron
Good luck
Snuffer is offline   Reply With Quote
Old 08-06-2008   #27
My System: Raven 60cm, Fibo 90cm, Channel Master 90cm, Technomate 5400
No circuit Ron and very unlikely to be able to get one. Lets just say that the distribution of this product has some...limitations. But, so that I can get the Fibo up at least, is it safe to use a 5V supply from an adaptor?
joekir is offline   Reply With Quote
Old 08-06-2008   #28
Yes you can use the 5 volt from a adapter no piont bult hem inside the vbox you have 5 volts are continius there.
Ron
Forum Jump
All views and information expressed in users' communications and profiles represent the opinions of the users concerned and do not represent the views of Satellites.co.uk. All images and news content are believed to be in the public domain, except where otherwise stated. Forum software by vBulletin® Version 3.7.2
