Fibo Motor
Section specifically for discussion by owners and would be owners of the Fibo Gregorian dish and clones
Old 12-11-2001   #1
peterbarlow's Avatar
Fibo Motor
Does anyone know where I can get a Fibo motor for a Gregorian dish?
peterbarlow is offline   Reply With Quote
Old 15-11-2001   #2
Mod and septic resident
Channel Hopper's Avatar
RE: Fibo Motor
Spectrum of Addington (Im not promoting them 2Old) used to claim thay had some but this goes back maybe two years ago
Let me know how you get on, is it the nylon cog thats stripped or the motor thats burnt out ?
Old 15-11-2001   #3
RE: Fibo Motor
I tried Spectrum but they have sold out. I have now found out that Wyre Forest Systems can repair them as he has some spares. The cog and motor are fine but I suspect that the reed switch has gone as when the dish moves (an arbitrary distance)it produces an 'actuator error" message on my Monterey.
Old 23-11-2001   #4
RE: Fibo Motor
Fibo dishes dont have reed switches
They use opto coupling devices inside them
You need to have five wires runing from the motor to the receiver (reed switch units need only four)
Are you certain you havent pulled a wire out ?
It might be worth trying the motor on another receiver (you need a 1permanent voltage supply to drive the circuit out at the dish
Old 28-11-2001   #5
RE: Fibo Motor
Yes, you are right. It does have five wires and I have checked the cable and also changed it. No luck. I have sent the motor to Wyre Forest for repair and hopefully will get it back soon.
I found out about the opto coupling just after I had posted the original message.
Thanks for your assistance!
Old 12-05-2005   #6
ivrm's Avatar
My System: HumaxHDCI2000, Humax Foxsat HD, Tripple Dragon, ManHattan 450 fibo 1.2 dish, Channel Master 1.2
Having problems with my Fibo 1.2m dish same as described here by PeterBarlow.
If Peter still on this forum can you give me details of firm who fixed your system
ivrm is offline   Reply With Quote
Old 12-05-2005   #7
Buy a new mount, you can fix the Jaeger SMR-1224 to the back of the dish easily, you need to do some drilling on the Jaeger back-plate.
Likvid is offline   Reply With Quote
fibo, motor
[IMG] code is Off
Similar Threads
Mount for Fibo dish? steffan_st Fibo Owners Club 1 23-04-2007 06:14 PM
Fibo Moteck motor modification johnsattuk Picture of Members' Setups and general satellite installations 13 25-01-2006 09:08 PM
My Gregorian Fibo in Tokyo lloyd21 Picture of Members' Setups and general satellite installations 8 09-09-2005 09:51 PM
Fibo 1.2M dish and Moteck SG2100? Likvid Fibo Owners Club 13 11-07-2005 03:29 AM
Fibo Motor? bazzey DISH SETUP: Single sat, Multi-Sat & Motorised systems 1 24-04-2003 11:15 AM
