Motor Problems
Section specifically for discussion by owners and would be owners of the Fibo Gregorian dish and clones
Old 19-08-2008   #1
My System: dreambox 90cm fibo dish
Motor Problems
Hi there nice to see a section dedicated to the fibo gregorian dishes
Ive had mine 8 years and suddenly the motor is playing up. Its connected to an echostar 3600ip and Im not sure if its the motor or the receiver. For some reason it has started skipping when moving and then stopping with motor error. When I say skipping I mean the counter on the echostar software. If I do a factory reset then it seems to work for a while but then starts playing up again.
I don't know much about motors but is there a part on its way out. I try to maintain the dish at least twice a year spraying the motor areas with wd40.
regards
Monty34 is offline   Reply With Quote
Old 22-08-2008   #2
Just a small update that might help others. I removed motor and opened casing. The problem turned out to be a dry joint where the terminal block is soldered on to the small pcb. cheers and happy viewing
Old 22-08-2008   #3
rolfw's Avatar
Real name: Rolf
Glad you got it sorted, strange for a dry joint to manifest itself after so long.
Rolf
Old 31-08-2008   #4
CROSSBONES's Avatar
My System: 1.2M, & 55cm Gregorian Dish`s, 1.8m Precision dish Jaeger 1224 H-H motor.Dreambox 800, Vbox-II. SS2 Card.
apparently its a common fault with these motors, had it happen to me
CROSSBONES is offline   Reply With Quote
motor, problems
[IMG] code is Off
