Search the small PCB inside the FIBO motorSection specifically for discussion by owners and would be owners of the Fibo Gregorian dish and clones | |
| Regular Member Join Date: 27-06-2006 Location: Amsterdam
My System: Skystarcard,Fortec's life time ultra's, MaxPlus 2100's,Dreambox and a Tandberg |
Hi I search for the small printed Circuit inside the Fibo motor the one with the optocoupler on it. The parts are not realy nessesery but the print. i have a print burning out so perhaps i can rebuilt the motor for his owner. Plaese look at your stuff perhaps you have one for me. Thanks in advange. Ron/Snuffer | ||
| Regular Member Real name: Bob Join Date: 31-08-2008 Location: Weymouth,Dorset,UK
My System: 60cm SKY Dish with PACE Digital Digibox, 90cm PHILIPS (Fibo clone) Gregorian (started with all original features). MTI AP8-TW LNB. TECHNOMATE 5500 CIP PLUS Receiver, STRONG 4375(as Backup) | Hi Ron/Snuffer I have looked inside my motor and the only thing I can find is a label inside the cable cover housing. I'm not sure if this what you are after but the numbers read as follows 9904 130 06802 G31-10.02 32/9 I couldn't see anything else apart from the numbers on the AIRPAX motor,if it is those you want then message me back. Hope this helps !! Bob/Dorsetbob | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | I believe that Ron means Printed Circuit board. | ||
My System: 60cm SKY Dish with PACE Digital Digibox, 90cm PHILIPS (Fibo clone) Gregorian (started with all original features). MTI AP8-TW LNB. TECHNOMATE 5500 CIP PLUS Receiver, STRONG 4375(as Backup) | Hi Thanks Rolfw There aren't any numbers on the pcb.All there is is some lettering which reads CLAUS (if this means anything ? ) | ||
| | #5 | ||
My System: Skystarcard,Fortec's life time ultra's, MaxPlus 2100's,Dreambox and a Tandberg | Yes thats the part 2 Transitors 4 resistors a optocoupler are on this printboard. And text are claus correct. | ||
| | #6 | ||
My System: 60cm SKY Dish with PACE Digital Digibox, 90cm PHILIPS (Fibo clone) Gregorian (started with all original features). MTI AP8-TW LNB. TECHNOMATE 5500 CIP PLUS Receiver, STRONG 4375(as Backup) | Hi Ron I have had another look but still can't see any numbers on the PCB. Perhaps you could try Fibo.as in Norway for an answer. They still have these motors in stock. I have been in contact with them last week and they are very helpful with all sorts of inquiries. I know that they haven't been making the dishes for 8/9 years but motors and the nylon cogs are still available from them. Hope this helps. Bob/Dorsetbob | ||
| | #7 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Ron actually wants one of the small PCBs, as the tracks are broken on the one he is trying to repair, but perhaps Fibo still have some spares. Have altered his original post to make it clear. | ||
| | #8 | |||
| Member Join Date: 18-11-2008 Location: england
My System: use technomate 1500 use loptop |
| | #9 | ||
My System: 60cm SKY Dish with PACE Digital Digibox, 90cm PHILIPS (Fibo clone) Gregorian (started with all original features). MTI AP8-TW LNB. TECHNOMATE 5500 CIP PLUS Receiver, STRONG 4375(as Backup) | They do have a web site. _http://www.fibo.no/ I dont have a price,but use the form on the site and they will get back to you Bob | ||
| | #10 | ||
My System: Skystarcard,Fortec's life time ultra's, MaxPlus 2100's,Dreambox and a Tandberg | Bob I have also some motors but the PCB are in fire so i must have a new board only. Price from a motor are 150 Euro's for new at the regular shops. I go change here to the JohnSat option and remove the boards compleet out of the motors thats better for me also in combination with my PC controler for use woith the motors. Ron | ||
| | #11 | ||
My System: 60cm SKY Dish with PACE Digital Digibox, 90cm PHILIPS (Fibo clone) Gregorian (started with all original features). MTI AP8-TW LNB. TECHNOMATE 5500 CIP PLUS Receiver, STRONG 4375(as Backup) | Ron I think that the reed switch option,like you are doing is the way forward(removing the small PCB). I would do this myself if I had the tools and facilities available to me to do so. Of course there are also other options to consider. 1. Change the polar mount to fixed and use a diseqc motor 2. Change the polar mount to fixed and use a Jaeger smr 99G motor 3. Install a Jaeger smr 1224 motor including adapter plate 4. Install a Andrews polar mount including adapter plate and use a actuator All these options I think will work. What do you think,Ron ? Bob | ||
| | #12 | ||
My System: Skystarcard,Fortec's life time ultra's, MaxPlus 2100's,Dreambox and a Tandberg | Bob That are the options yes correct. What i will do is use it orginal and compleet. I make a motor with reed (as JohnSatUK ) and control this by PC. The only piont is that i can not change the program someone have make for me. Works great but have no remember the puls insite. Whit ather words i look for a programmer that will finish a wonderfull option. Hardware are compleet working here. see picture. | ||
| | #13 | ||
My System: 60cm SKY Dish with PACE Digital Digibox, 90cm PHILIPS (Fibo clone) Gregorian (started with all original features). MTI AP8-TW LNB. TECHNOMATE 5500 CIP PLUS Receiver, STRONG 4375(as Backup) | Hi Ron Try this link _http://www.pc-user.co.uk/motor-bee_info.htm I thought this might help if you are going to try to program your software yourself. It could be the same software Bob | ||
| | #14 | ||
My System: Skystarcard,Fortec's life time ultra's, MaxPlus 2100's,Dreambox and a Tandberg | Bob This unit is what i use with the software you see on the picture. This software (picture) are working great bud what i miss on it are the part to remember the steps so turning left right slow ast etc are 100% But i must store the pulsen from the reed, to make this in the program and a sat list that the motor can turn to the sat are the problem i am a technican not a software engineer. Perhaps i must look for a prof.company and spent some money on it. Ron | ||
| | #15 | ||
My System: 60cm SKY Dish with PACE Digital Digibox, 90cm PHILIPS (Fibo clone) Gregorian (started with all original features). MTI AP8-TW LNB. TECHNOMATE 5500 CIP PLUS Receiver, STRONG 4375(as Backup) | Hi Ron There is another alternative. You could use a DVB-S card in your pc and connect it to a V-Box to control positioning. Bob | ||
| | #16 | ||
My System: Skystarcard,Fortec's life time ultra's, MaxPlus 2100's,Dreambox and a Tandberg | Bob I use a SS2 card and a Prof 7300 card with the rotor control of MIBI for about 2 years now and use a Fortec star Ultra for rotor control (best reciever for it ever used here) bud i will do it without a card and with my PC and the program haha Thanks | ||
| fibo, inside, motor, pcb, search, small |
