Help please!Section specifically for discussion by owners and would be owners of the Fibo Gregorian dish and clones | |
| Regular Member Join Date: 20-12-2004 Location: Midlands UK
My System: Sky+ TM1000D 1m Orbital Motorised Dish Echostar 3000 |
Hi guys, I have been offered a Philips Gregorian 1m? I thought they only did a 90cm on this dish? My current setup is as follows :- 1M Orbital dish - mounted to a 2" mast SG2100A Motor (Disecq) Technomate 1500 Ci Echostar AD 3000. My second question is can you easily get pole mounts for these dishes? It has been fixed to a wall. Final question - will it be too heavy for my SG2100 to drive, will the Echostar happily drive the Gregorians built in motor? Cheers | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | The dish you have been offerred I think will be the 90cm, they are about 1m tall. By replacing the polar mount with the az/el mount, the dish can be used with a Diseqc motor. The motor used on the Fibo uses an optical sensor instead of a reed switch. The opto sensor needs a 5V DC supply. There is a mod to convert the motor to use a reed switch though. Not sure about the pole mount, the one I had, someone had very crudely welded a pole to the back of the polar mount. | ||
