Just got a Philips Gregorian 90cm Dish - help neededSection specifically for discussion by owners and would be owners of the Fibo Gregorian dish and clones | |
| | #27 | ||
| Regular Member Join Date: 17-12-2006 Location: Portugal
My System: _____Multi-LNB _____DM8000s_______ _____DM800s__________ _____DM500s_______ _____FIBO90_______ | The cover in the feedhorn. | ||
| The Following User Says Thank You to NunoV For This Useful Post: | bigup (13-09-2009) |
| | #28 | ||
| Member Join Date: 10-09-2009 Location: Lancashire
My System: Philips Gregorian Dish | yep, that is what i do not have! im hoping the LNB has internal waterproofing! can anyone confirm? Robbo i know you used this lnb, please can you advice? | ||
| | #29 | ||
| Specialist Contributor Join Date: 25-04-2005 Location: Austria
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband! | Hello! here in this auction 380135120323 you can see the slide protection cap of the invacom quad lnb what i mean,its looks with that much more bigger then a normal incacom without!,but i think is only avalible in usa! | ||
| The Following User Says Thank You to Turok For This Useful Post: | bigup (13-09-2009) |
| | #30 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | The LNB itself does not need waterproofing as it has a transparent membrane at the mouth. However, at some dish elevations it may be possible to get rain in the feedhorn, and if it was able to collect at the lnb, you would get no or little signal. I cannot see unfortunately the feedhorn rain cover listed in satmueller catalogue, just the feedhorn that comes with it. I think you will have to improvise for a little while, pet food can cover maybe? | ||
| The Following User Says Thank You to Robbo For This Useful Post: | bigup (13-09-2009) |
| | #31 | |||
My System: Philips Gregorian Dish | please let me know if the Invacom QDF-031 lnb would be a easy fit. Thanks | |||
| | #32 | |||
or what do you think would be the best way of doing it? | |||
| | #34 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | That certainly looks like a standard C120 mounting. | ||
| | #35 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | OOPs I thought I had replied, but didn't. Yep, looks OK. Hopefully the screw holes will line up OK too, but the flange and the waveguide diameter look to be correct. As for the rain cover, you're going to have to play with that, and see what works, but doesn't affect signal. I'd be tempted to bung some tape round it initially. | ||
| | #37 | ||
| Member Join Date: 26-07-2009 Location: hampshire uk.
My System: 1m gib,1.2m precision, both motorised. tm6800 ,vantage,quali& manhattan receivers. | Try TLC electrical supplies direct. or your local electrical supplier for 5 core wire( tlc will supply it by the meter). | ||
| | #38 | ||
My System: Philips Gregorian Dish | something like this: _http://www.tlc-direct.co.uk/Main_Index/Cable_Index/Flex_White_3/index.html "1.0mm 5 Core Pvc - PVC White Flexible Cable 3185Y" | ||
| | #39 | ||
My System: 1m gib,1.2m precision, both motorised. tm6800 ,vantage,quali& manhattan receivers. | I use the 0.75mm 6amp cable on a run of about 20m with no problems (the Vbox max currant 3amps). | ||
| The Following User Says Thank You to purplemarina For This Useful Post: | bigup (15-10-2009) |
| 90cm, dish, gregorian, needed, philips |
