Is this Fibo AZ/EL mount right?Section specifically for discussion by owners and would be owners of the Fibo Gregorian dish and clones | |
| Regular Member Join Date: 29-12-2005 Location: Zürich
My System: Fibo 90cm, Inverto White Tech 0.3dB, Moteck SG-2100A, Dreambox DM7020S, Dreambox DM 600C, Fibo 55cm (to be installed!) |
I'm finally going to have time to install my dish this weekend - weather permitting! Yesterday I was just looking at the AZ/EL mount it came with and it doesn't look quite right to me. Are the pieces that clamp to the pole really supposed to be that big? If I tighten the nuts, will this not just destroy the green plastic bits? | ||
My System: Fibo 90cm, Inverto White Tech 0.3dB, Moteck SG-2100A, Dreambox DM7020S, Dreambox DM 600C, Fibo 55cm (to be installed!) | Thanks lloyd21, I feel a bit more reassured. I found the mounting instructions to be a bit misleading as well. The diagrams don't show the the green plastic and the metal clamps are much smaller, having a width less than that of the body of the mount. | ||
| ASBO Club Member - Persona non grata Join Date: 30-07-2003 Location: Stockholm, Sweden
| Actually there are two models of the mount. One revision have the larger clamps and the other have the smaller clamps that fits inside the green plastic thing as you can see from my picture thread. It all depends what year it was manufactured. http://www.satlex.de/en/image_viewer...=fibo90&pic=11 | ||
| | #6 | ||
My System: Fibo 90cm, Inverto White Tech 0.3dB, Moteck SG-2100A, Dreambox DM7020S, Dreambox DM 600C, Fibo 55cm (to be installed!) | Hi Likvid. Yes, I noticed the smaller clamps in your pictures, that's what made me wonder if mine were right. The plastic does seem to be quite hard, but I'll be careful not to overtighten the nuts come Saturday. The small ones do look neater. | ||
| | #7 | |||
Do you want the smaller clamps? otherwise you have to contact my source in Germany and you can order it from them. Don't know why Fibo used different clamps. | |||
| | #8 | ||
My System: Fibo 90cm, Inverto White Tech 0.3dB, Moteck SG-2100A, Dreambox DM7020S, Dreambox DM 600C, Fibo 55cm (to be installed!) | Yes, if you could give me their contact details that would be great. I'll use the ones I have in the mean time as it's about time I got my dish up! | ||
| | #9 | |||
Email them as they have hard time speaking English. Send the pics from this thread to them and say that you need those clamps or otherwise they will prolly send you the large clamps again. | |||
| | #11 | ||
| Member Join Date: 19-05-2007 Location: Scotland
My System: 1.2meter gregorian dish original 36v positioner motor twin lnb Tm 5500 cip plus Tm9100 Humax hdci200 Silvercrest-SL65 E Dragon cam Diablo cam 2xSS1 and SS2 V stream dvbt pci Cas 3 | i am intrested in converting my gregorian 1.2 looking to change the mount on the back to the same as above but unsure where to get one can you help | ||
| | #12 | |||
| I have spare parts for a 120cm, but only the Polar mount, subreflector, feedarms, backplate and feedhorn. | |||
| | #13 | ||
My System: 1.2meter gregorian dish original 36v positioner motor twin lnb Tm 5500 cip plus Tm9100 Humax hdci200 Silvercrest-SL65 E Dragon cam Diablo cam 2xSS1 and SS2 V stream dvbt pci Cas 3 | my motor still works but it has lots of play in it now so was looking to change the motor to disq1.2 and get new clamps do you know if any one has spare set would be greatfull | ||
| | #14 | |||
| The metal will sheer in the clamps and brackets after a while and it's living hell to adjust it with the Moteck as the Fibo dish is too heavy for it. | |||
| | #15 | ||
| Oldgeezer Join Date: 04-09-2004 Location: West Mids, UK
My System: Topfield 5800 Echostar3000,DB7000, Relook 400S, Humax HDC2000, 55cm Fibo Gregorian dish with waveguide and Motek 2100 mod, 90cm Fibo Gregorian dish, 120cm Fibo Gregorian dish on a 1224 motor with waveguide | Have you located where the play is, very often the nylon pinion and/or it's drive pin get damaged. There is an adjustment in the motor itself, but this will normally only give a small amount of backlash. Are the bolts holding the motor loose. | ||
| Oldgeezer | |||
| | #16 | ||
My System: 1.2meter gregorian dish original 36v positioner motor twin lnb Tm 5500 cip plus Tm9100 Humax hdci200 Silvercrest-SL65 E Dragon cam Diablo cam 2xSS1 and SS2 V stream dvbt pci Cas 3 | will check for loose bolts on the motor if it cant be done can you recomend a good dish of same spec as gregorian which can use disq 1.2 also a motor i dont want to get rid of the dish it is one of the best dishes and i dont think i could get better thanks for all your help | ||
| | #17 | |||
My System: Topfield 5800 Echostar3000,DB7000, Relook 400S, Humax HDC2000, 55cm Fibo Gregorian dish with waveguide and Motek 2100 mod, 90cm Fibo Gregorian dish, 120cm Fibo Gregorian dish on a 1224 motor with waveguide | ![]() It is unlikely that the large diecast internal gear is worn on a normally used dish. The lure of diseqc 1.2 is always there. I have modded all three sizes of Fibo, but IMO, as Likvid says, the 120cm is a bit too much for the 2100 type of diseqc motor. With a different design of mount where the axis of rotation was on the C of G it would perhaps be OK since there would be no offset loading, and the wind loading would be much reduced. Another possibility, which I haven't tried myself, would be to remove the Fibo motor, and use a Diseqc jack (linear actuator) on the Fibo mount. | |||
| Oldgeezer | ||||
| | #18 | ||
| Sadoun in USA has released a new Diseqc motor that reminds you about Moteck but this new model got metal cogs instead of the usual plastic ones and a different design of the housing. http://www.sadoun.com/Sat/Products/P...0_HH_Motor.htm | ||
| | #19 | ||
My System: 1.2meter gregorian dish original 36v positioner motor twin lnb Tm 5500 cip plus Tm9100 Humax hdci200 Silvercrest-SL65 E Dragon cam Diablo cam 2xSS1 and SS2 V stream dvbt pci Cas 3 | took the dish of and removed the motor box the white clog has play a small bit inside the pin not the outside clog but looks worse when the dish is on so used small plastic tie wrap to take up the play and it worked the motor inside looks like it was made yesterday and its only 14 years old so looks to be lots of life left in it so may have it for a few years yet but it will give up one day and will have to look at disq1.2 | ||
| | #20 | ||
My System: 1.2meter gregorian dish original 36v positioner motor twin lnb Tm 5500 cip plus Tm9100 Humax hdci200 Silvercrest-SL65 E Dragon cam Diablo cam 2xSS1 and SS2 V stream dvbt pci Cas 3 | was able to find a clamp for the back of the fibo 1.2 to alter motor to disq 1.2 so will buy just incase i can get a motor strong enough to move and last out the rest of the dishes life i hope also have not found a dish to better the fibo dish which is years and years old why? | ||
| | #21 | ||
My System: Topfield 5800 Echostar3000,DB7000, Relook 400S, Humax HDC2000, 55cm Fibo Gregorian dish with waveguide and Motek 2100 mod, 90cm Fibo Gregorian dish, 120cm Fibo Gregorian dish on a 1224 motor with waveguide | | ||
| Oldgeezer | |||
| | #22 | ||
| The tools for the 55, 90 and 120cm Fibo antennas are still alive but in storage for now, so anyone willing to buy the tools for production are welcome to contact the company that owns them. It's not commercially viable to sell and produce this kind of antenna today, one of the reasons Fibostöp stopped production and sold all tools to Swe-Dish in Sweden. However Swe-Dish used part of the tools to make the Fibo 90cm reflector and sub-reflector and accessoires for their military line-up of broadcasting equipment. Today what i know they don't use the tools anymore and they are in storage here nearby. | ||
| az or el, fibo, mount |
