Fibo Gregorian - alternative motor setups | |
| | #26 | ||
| Specialist Contributor Join Date: 23-07-2005 Location: S.Wales
My System: 1.2M & 55cm Gregorian Dish`s, 1.5m Gibertini on a Jaeger 1224 H-H motor. Dreambox 7025 200gb HD, Vbox-II. SS2 Card. | The satellite super store used to make them, but not any more, just as well as you pay through the nose with them ![]() Have a go your self, it looks easy.
__________________ Roiders are like the sun, big, orange, and never stare directly at them | ||
| | #27 | |||
| Member Join Date: 25-03-2005
My System: I use a 1.2 Gregorian dish connected to four receivers including a scopus 4.2.2 professional ird2800 and Echostar3600 and two blind scan rx's. My lnb is a quad invacom. All rx's are linked to my packard bell easy one silver laptop. | No problem Crossbones! The dish has now been replaced with a Precision 1.8 with a C/Ku LNB setup | |||
| | #28 | |||
__________________ Roiders are like the sun, big, orange, and never stare directly at them | |||
| | #29 | ||
My System: I use a 1.2 Gregorian dish connected to four receivers including a scopus 4.2.2 professional ird2800 and Echostar3600 and two blind scan rx's. My lnb is a quad invacom. All rx's are linked to my packard bell easy one silver laptop. | | ||
| | #30 | |||
My System: 1.2M & 55cm Gregorian Dish`s, 1.5m Gibertini on a Jaeger 1224 H-H motor. Dreambox 7025 200gb HD, Vbox-II. SS2 Card. | Thats the way mate, dont part with it. I nearly sold mine, but glad ive kept it. I also have a 90cm, and a 55cm fibo on the way ![]()
| | #31 | ||
My System: 1.2M & 55cm Gregorian Dish`s, 1.5m Gibertini on a Jaeger 1224 H-H motor. Dreambox 7025 200gb HD, Vbox-II. SS2 Card. | Here are some pics of my modified Fibo mount ![]() I didn't attach the motor to the dish, only on the center spindle, as I don't think its needed. ![]() A big Thank you to johnsattuk for the help and e-mails, and my good mate in work who did the work![]() Please let me know what you think johnsattuk
| | #32 | |||
| Oldgeezer Join Date: 04-09-2004 Location: West Mids, UK
My System: Topfield 5800 Echostar3000,DB7000, Relook 400S, Humax HDC2000, 55cm Fibo Gregorian dish with waveguide and Motek 2100 mod, 90cm Fibo Gregorian dish, 120cm Fibo Gregorian dish on a 1224 motor with waveguide | ![]() I would be worried about a 90cm dish being restrained only by a 5mm roll pin in a 14mm shaft, I added two 5mm bolts to my 55cm. ![]() But if it works then it's OK. One of my worries would be that if the pin sheared, the dish would fly round and aquire a big dinge when it hits the mount.
__________________ Oldgeezer | |||
| | #33 | |||
| | #34 | |||
| | #35 | ||
My System: 1.2M & 55cm Gregorian Dish`s, 1.5m Gibertini on a Jaeger 1224 H-H motor. Dreambox 7025 200gb HD, Vbox-II. SS2 Card. | Hmmm......you do have a point there, maybe I will add the extra 5mm bolts before I field test it ![]() Thanks for the advise mate
| | #36 | ||
| The Following User Says Thank You to scopus For This Useful Post: | CROSSBONES (03-06-2007) |
| | #37 | ||
| Regular Member Join Date: 27-06-2006 Location: Amsterdam
My System: Skystarcard,Fortec's life time ultra's, MaxPlus 2100's,Dreambox and a Tandberg | To take away that problem for 5 mm make a hole in the 14 mm shaft at top and bottom make i 8mm wire insite an use 2 - 8x 10 mm with a nyloc ring below insite. now the shaft can never away from it house. Good modification and simpel to. | ||
| | #38 | |||
My System: Topfield 5800 Echostar3000,DB7000, Relook 400S, Humax HDC2000, 55cm Fibo Gregorian dish with waveguide and Motek 2100 mod, 90cm Fibo Gregorian dish, 120cm Fibo Gregorian dish on a 1224 motor with waveguide | ![]() Simple - yes, Good - not so sure I think it would weaken the shaft so much that it would be likely to shear off. It is not a mod. that I would use myself.
| | #40 | ||
My System: 1.2M & 55cm Gregorian Dish`s, 1.5m Gibertini on a Jaeger 1224 H-H motor. Dreambox 7025 200gb HD, Vbox-II. SS2 Card. | I have made two brackets out of box section for my Jaeger 1224 H-H motor. Welded some threaded bar on to attach the C/master adaptor plate. Here are the pics Jaeger 1224 Fibo mod
