Best results LNB ???? | |
| Regular Member Join Date: 27-06-2006 Location: Amsterdam
My System: Skystarcard,Fortec's life time ultra's, MaxPlus 2100's,Dreambox and a Tandberg |
What LNB Quad have the best results with a 120 Cm Fibo dish. Invacom Quad is in use here now but there are Iverto and MTI also i think It MUST BE A QUAD for 4 recievers. | ||
| Specialist Contributor Join Date: 23-07-2005 Location: S.Wales
My System: 1.2M & 55cm Gregorian Dish`s, 1.5m Gibertini on a Jaeger 1224 H-H motor. Dreambox 7025 200gb HD, Vbox-II. SS2 Card. | Inverto work well. But ive only seen the twin outputs, not sure they make a quad.
__________________ Roiders are like the sun, big, orange, and never stare directly at them | ||
| Dont eat yellow snow Join Date: 05-05-2003 Location: .
My System: Hotbird 13E - 8ft dish Arabsat 26E - 8ft dish Invacom quad LNB Powersky 8210 (multicam) Startrack receiver Viaccess cam T Rex Cam Diablo Cam ART subscription | I researched this last year, by looking at various reviews and recommendations etc Came up with an invacom, http://www.nil-dan.de/html/lnb_invacom_quad.html It improved my fringe reception on Hotbird by 20-30% (Although I did have a cheap local LNB at the time) Might be worth checking a few reviews again, I'm consious that the techology moves pretty quickly...... | ||
| Regular Member Join Date: 25-04-2005 Location: Austria
My System: 1,25 Fibostop Jäger Smr 1224 Dual Axsis Echostar Dvr 7000 Monterey 140 Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesch for cband! | Hello! i have an old smw xline 800 Lnb,and i want,to fix it on the fibo antenna,but,the conection,looks complitly difrent,inside,what,type,of polareizer,is needed,that the conection on both size,is compatible? i contacted smw,in Sweden,but they cannot help me! | ||
| | #5 | ||
| ASBO Club Member, AKA Likvid Join Date: 05-08-2007 Location: EU
My System: None | The SMW LNB is a WR-75 LNB and not the usual C120 flange LNB you are most often seen in the shops. SMW needs an OMT or a polarizer or ferotor of some sort to connect to the feedhorn. | ||
| | #6 | ||
My System: 1,25 Fibostop Jäger Smr 1224 Dual Axsis Echostar Dvr 7000 Monterey 140 Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesch for cband! | Hello Thx,for your answer,where,i find an omt,i dont have any! have,hirschmann csp 1210 polareizer,but,i dont find it at the moment,must seach it ![]() iam not sure,is the hirschmann compatible or not,i was thinking,smw has the right stuff.. does any one,testet the smw lnb kuband on www.smw.se website,does it perfom better,then the old x 800 Series? | ||
| | #7 | |||
My System: None |
Just install the SMW LNB to the flange output on the Hirschmann polarizer. Oh..i found a picture of the same setup. | |||
