1.2M Fibo Dish
Section specifically for discussion by owners and would be owners of the Fibo Gregorian dish and clones
Old 29-06-2007   #1
Site Services's Avatar
My System: Motorised 1.2M Fibo looking between 45E - 60W, TM9100 Receiver running EDG-Nemesis 3.2 in flash
1.2M Fibo Dish
I've come across one of these that has a problem with tracking. If you go from sat 'a' to sat 'b' and back it settles slightly off. It sounds like a lot of slack in the gearing for the motor / gearbox.
Is this likely to be an easy problem to solve? Can spares, or even replacement motor units, be got hold of easily?
Any info would be appreciated.
Site Services is offline   Reply With Quote
Old 29-06-2007   #2
CROSSBONES's Avatar
My System: 1.2M, & 55cm Gregorian Dish`s, 1.8m Precision dish Jaeger 1224 H-H motor.Dreambox 800, Vbox-II. SS2 Card.
It does sound like your motor is on the way out.
It is very hard to get new parts for these dish`s. I have only just sold 2 motor`s.
Your best bet is too ask snuffer, he has a mate who has some spare parts.
Or you could mount it on a Jeager 1224.
See the alternative motor thread, plenty of ideas there.
CROSSBONES is offline   Reply With Quote
Old 29-06-2007   #3
Thanks, all is not lost then.... I've had a look through the thread you suggested, some excellent ideas there. Should have noticed it before but thanks for pointing it out.
Old 29-06-2007   #4
Oldgeezer
johnsattuk's Avatar
My System: Topfield 5800 Echostar3000,DB7000, Relook 400S, Humax HDC2000, 55cm Fibo Gregorian dish with waveguide and Motek 2100 mod, 90cm Fibo Gregorian dish, 120cm Fibo Gregorian dish on a 1224 motor with waveguide
It is not usually the slack in the motor (is adjustable ) itself which gives noticeable backlash, it is more likely to be the nylon pinion and/or the drive pin in the motor shaft. These damage quite easily, the 3mm roll pin in the motor shaft bends if overloaded and also deforms the slot in the nylon gear, which then has free play. Often caused by accidentally driving the dish too far, unfortunately there are no limit switches fitted.
I do have some spare parts about.
Oldgeezer
johnsattuk is offline   Reply With Quote
Old 29-06-2007   #5
Thanks Johnsatuk, when the weather gets a little better I'll get the dish down and have a look to see whats going on. Looks like you're in the same part of the world as well, so we'll see what happens when I get it stripped apart.
Old 29-06-2007   #6
Oldgeezer
johnsattuk's Avatar
It is quite easy to unbolt just the motor to have a look at, just have to secure the dish first to stop it swinging about when you take the motor off.
Oldgeezer
Old 02-07-2007   #7
I owe you one johnsatuk. Removed the motor, this morning, and stripped it down. Tightened everything up, replaced the roll pin (just in case) and cleaned and greased everything up. Just replaced it now and everything is as solid as a rock. It goes to where it's told, and back again, with no sign of drift. Thanks for your information, it helped alot.
Old 02-07-2007   #8
CROSSBONES's Avatar
Thats excellent news mate
Get some pics up of that Great dish
Old 02-07-2007   #9
My System: Skystarcard,Fortec's life time ultra's, MaxPlus 2100's,Dreambox and a Tandberg
Its like a car it need sometime's a little attention.
A small plestic tube with Copergell and the parts are alway's in the greased
Snuffer is offline   Reply With Quote
Old 23-11-2008   #10
My System: use technomate 1500 use loptop
hi i am trying to take the motor down ,clean and back againe can you tell me how you down it any instruction .thanks if you explain it,
shahram62 is offline   Reply With Quote
Old 23-11-2008   #11
dorsetbob's Avatar
Real name: Bob
My System: 60cm SKY Dish with PACE Digital Digibox, 90cm PHILIPS (Fibo clone) Gregorian (started with all original features). MTI AP8-TW LNB. TECHNOMATE 5500 CIP PLUS Receiver, STRONG 4375(as Backup)
Hi
Read this thread,it tells you everything you need to know
How (and with what) to lubricate motor etc
Bob
dorsetbob is offline   Reply With Quote
Old 24-11-2008   #12
and this ?????
1.2M Fibo Dish-gfas-jpg
12m, dish, fibo
[IMG] code is Off
