Help I've lost Ch4 and Ch5 - again
High Definition FortecStar HD satellite TV receiver help and support forum.
Old 30-03-2008   #1
My System: Skystar2, Fortecstar Passion HD, moteck 2100, Lidl 80cm dish
Hi, I have Fortec passion with Diablo cam(with latest software) and freesat s*y card. I used to get Ch4 etc. fine. Now it wont work. The card works in a s*ybox so doesn't need updating.
I suspect the caids file may have changed when I updated the diablo software?
If this is the case, can someone please post a copy of their working caids file.
I tried editing mine in Fausto but couldn't seem to load it into fausto.
many thanks
woodlouse is offline   Reply With Quote
Old 30-03-2008   #2
Have you tried atering the CAID file in teh configuration menu? I seem to remember another member has indicated that you might need to select the UK CAID file.
Mickha is offline   Reply With Quote
Old 30-03-2008   #3
Yes I've done that - still doesn't work.
Old 31-03-2008   #4
Which Stealth file was it working with, and which Stealth file have you now loaded?
ch4, ch5, lost
[IMG] code is Off
