Frozen and locked!! Help
Thread Tools Display Modes
Old 27-05-2008   #1
My System: Fortec Star Passion
I've managed to get my receiver locked, was just channel surfing, went onto ch 6494 I think, now it wont move or respond, tried turning it off and on and just goes back to this channel, is there a way of hard resetting? baring in mind i cant use the software menus? Thanks
scottgough is offline   Reply With Quote
Old 27-05-2008   #2
sorted thanks, removed the sat lead so it couldnt get a signal, which stopped it locking on! phew
Old 27-05-2008   #3
Amo Amas Amant Admin
Topper's Avatar
Mmm
I hope you powered it down first, or at least before you re-inserted the cable from the lnb
__________________
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 27-05-2008   #4
My System: fortec star passion
Hi there i had the same problem and done exactly the same thing is unpluging the cable a stupid thing to do can it cause some damage while the thing is still switced on.
tricky1 is offline   Reply With Quote
Old 27-05-2008   #5
yes, powered it off first, disconnected, then fired back up! ;-)
Old 27-05-2008   #6
Well looks like i was lucky this time will make sure its switched off next time. cured the problem though.
Old 27-05-2008   #7
Mod and septic resident
Channel Hopper's Avatar
That is a fault that used to occur on some of the early Samsung receivers.
The channel that you are watching is transmitting outside the DVB minimum requirements, and will cause the receivers firmware to 'cycle' whilst trying to process logic from the data stream.
Which channel caused the loss ? and have you deleted it from the channel list ?
__________________
Old 27-05-2008   #8
Well the channel it got locked on was BBC HD
Old 28-05-2008   #9
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams
This latest (beta) firmware cures the BBC HD locking problem -
Download Link
http://rapidshare.com/files/118233628/p_av113_20080525.zip.html
__________________
Llew is offline   Reply With Quote
The Following User Says Thank You to Llew For This Useful Post:
clobryn (01-06-2008)
Old 28-05-2008   #10
Thanks LIew its been ok for a few days now will try the new beta if it happens again that version is not on the fortec website are you one step ahead of them?
Old 28-05-2008   #11
Robbo's Avatar
My System: TM6800HD+TD110+StabHH90 motor,TM1000D+Orbital 1m Multifeed 16E,23E,28E.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox.
That'll be firmware from laurals on the sataid forum.
Old 01-06-2008   #12
My System: fortecstar Sky+
Download Link
can confirm this patch Llew posted works A1 thanks
clobryn is offline   Reply With Quote
[IMG] code is Off
Forum Jump
