Understanding Passion settings- Please help
Thread Tools Display Modes
Old 08-06-2008   #1
My System: novice; fortecstar
I recently purchased a h/d pasion sat rec/box,but being a novice i am struggling to understand the four digit imput No's and how to lock them in to fav list and how do these No's re-late to tv listings? can anyone help? thanks. Tom
thomas is offline   Reply With Quote
Old 08-06-2008   #2
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams
All named channels have corresponding four-figure numbers. Are you saying that the channel names in your list are numbers instead of names?
__________________
Llew is offline   Reply With Quote
Old 09-06-2008   #3
Tom
Hi liew, thanks vm for ure reply.when i press white for fav list the ch No's come up thus:- 0975 itv yorks - 0942 bbc west, 0984 bbc4- 0985 bbc3 etc, how do i lock these into the fav list? the orange butn brings up the last 5 ch's watched. The t/v listings in the Sun t/v mag gives different ch No's, i.e. for bbc4=sky116,virgin107 and bbc3 as sky115 and virgin106, so i presume that each media company has its own set of No's built into their own equipment. I am only on free to air sat, and as you can see, i'm a bit new at this system, but very pleased with the picture quality,- if I could only get it organised right. so I would be glad to hear from you again. thanks Tommy.
Old 09-06-2008   #4
Llew's Avatar
Forget the channel numbers published in the newspaper. These are the EPG channels for the Sky boxes.
To add a channel to a Favourite list -
Press Menu
Right click to Channel Edit
Input Password as 0000
Select which channels you need to make your favourites
Press Mosaic button on your remote. A * appears beside your selection(s)
Press White button, then OK to add to the Fav list
Press OK and save the result.To view a Favourite, press the White button twice.
I'm assuming you haven't a user manual, as it describes the procedure there.
__________________
Old 09-06-2008   #5
To Llew = thanks very very much for those instructions Llew , i will put them into operation tomorrow - and yes, i do have a manuel with the box,and i have read that section about ten times over but i never realised that i had to imput the 0000 number. so its making sense now, so thanks v.m. again, and for being so quick, cheersTom mirfield
Old 09-06-2008   #6
My System: None
Whilst we are on the subject of "How do you do that"
Is it possible to create a new Fav list, I see you can edit the title and you then remove all the channels in that Fav list and then replace them.
I want to create a new HD Fav list (I know there are only three...but you got to start somewhere !)
Can it be done ?
Retronana is offline   Reply With Quote
Old 09-06-2008   #7
Llew's Avatar
Use the Setedit program to change one of the seven favourite lists to your choice of name, then you can add channels to that list in Setedit by copying/pasting to the Favourite list box.
__________________
Old 10-06-2008   #8
tom
Llew, followed your instructions and "bingo" so i am well pleased. I read your advice also to Retronana, which will also come in handy (ive printed them off) so thanks again very much. all the best Tom Mir...
Old 10-06-2008   #9
Llew's Avatar
Good to hear that Tom. A belated welcome to the forum
LLew
__________________
[IMG] code is Off
Forum Jump
