Passion General Settings
Thread Tools Display Modes
Old 25-06-2008   #1
mick2me's Avatar
My System: 'Fortec Star Passion' (& a dead SL65) One of them big Woks on the outside, and a thingy that moves it about a bit.
Question Passion General Settings
What settings do I use on the Passion Antenna setup menu?
Below are my (current settings) and other choices?
Antenna setup/Satellite/Astra 2a 28.2e
LNB Freq (Universal)
DiSEqc (DiSEqC 1) choices DiSEqC 1, DiSEqC 2, DiSEqC 3, DiSEqC 4?
Transponder (11469 H 2750)
22KHZ (Auto)
LNB Power (on)
0/12v control (off) always greyed out?
Positioner setup (DiSEqC 1.2)
DiSEqc 1.1 (off) choices when on, Ports 1-16?
I am picking up Astra2a but the dish is not moving to others?
__________________
The best way to learn is from your mistakes... Sorry I made a mistake!... The best way to learn is from others mistakes.
_www.Nottstalgia.com
The Nottingham Forums
mick2me is offline   Reply With Quote
Old 25-06-2008   #2
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams
Have you set up DiseqC 1.2 as per the manual (E/W Limits, Sat positions)? Assuming your dish is correctly lined up on the arc.
Antenna Setup will be as per the Menu -
__________________
Llew is online now   Reply With Quote
Old 26-06-2008   #3
mick2me's Avatar
I set up as your diagram
I originaly found the due south satellite (thor) But I cant go to it now?
I set the limits but now it wont go to back to Astra or any other satellite?
The East west controls work intermitantly?
__________________
Old 26-06-2008   #4
mick2me's Avatar
Trying a start from fresh, just struggling to find thor manually now
__________________
Old 26-06-2008   #5
Llew's Avatar
Can't help much with the Passion's DiseqC 1.2 mick. I use DiseqC 1.0 with fixed dishes and motorised dish. Should be straightforward enough though.
__________________
Old 26-06-2008   #6
mick2me's Avatar
Trial and error, more of the latter
Got a fairly weak signal on Thor, with motor set for centre.
Locked it off, tried to drive to other satellites without success.
Now unable to pick up thor by resetting motor for centre.
Still not sure of the procedure for Limit setting.
Is this as far as the dish will move freely each way?
Does it need to be set for each Sat?
Try again tomorrow.
Freeview is looking a good option at the moment!
__________________
[IMG] code is Off
Forum Jump
