ITV HD on Passion+ Newbie needs help
Thread Tools Display Modes
Old 11-07-2008   #1
surfgeek's Avatar
My System: Sky +, Passion+ HD, Various Mac's, too many gadgets to count.
Hi, just bought my Passion+ Kit today from Maplins, great price at £160 include PVR recording.
I have tried all the suggestions on this site to get ITV HD running, but had no joy yet.
I have updated to Loader 1.5 and installed the other channels file on the passion website ( is this the updated firmware ?)
I have re scanned Astra, interesting I live in yorkshire, but the 2 yorkshire regular channels do not work either, having to select Midlands as my area.
Please can somebody give me a real easy step by step guide of what to do.
P.s. I am still using my Sky 45cm dish, going to install the 60cm dish tomorrow.
surfgeek is offline   Reply With Quote
Old 12-07-2008   #2
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams
Moved to appropriate section.
If ITV HD isn't appearing in your regional list, try a factory reset, then re-upload the firmware/channels file.
If still no go, you can manually add the ITV HD channel by pressing Menu on your remote, clicking Advanced Scan and entering these values -
11428 H 27500
DVB Standard = DVB-S
FEC = Auto
Video PID = 3401
Audio PID = 3402
PCR PID = 3401
Service ID = 10510
PMT PID = 3400
HD/SD = HD Channel
__________________
Llew is online now   Reply With Quote
Old 12-07-2008   #3
surfgeek's Avatar
Thanks, please can you confirm the firmware file for me, is it v1.14 ( june 27, 2008) ?
To install I have put on a memory stick and loaded by switching on the passion and pressing the OK button on the front. The pasison then re boots after installing the file.
I have tried thye second suggestion but do not have the option in input
"Service ID = 10510
PMT PID = 3400
HD/SD = HD Channel"
Old 12-07-2008   #4
Llew's Avatar
Strange, the additional parameters to allow scanning ITV HD have been added since firmware version 1.12. What version does it show in System Information?
__________________
Old 12-07-2008   #5
surfgeek's Avatar
Perhaps I am not loading the firmware correctly, please can give a brief step by step of what I need to do.
I have installed Loader 1.5 without a problem, but only showing software version 1.0.
Is the file p_av114_20080627.dnl the correct file. How do I install it?
Thanks very much
Old 12-07-2008   #6
Llew's Avatar
Yes, that's the latest version.
I assume you've transferred the file like this -
Choose Data Transfer - USB
Transfer Mode - USB Read
Then choose p_av114 from your USB stick
__________________
Old 12-07-2008   #7
surfgeek's Avatar
sorted it, had corrupt data on my usb stick, used my Mac and all went well. Thanks for your assistance.
Old 12-07-2008   #8
Llew's Avatar
surfgeek, I notice you mention that your Passion has pvr capability.
So you have the latest model, which is not the same as the original Passion (different chipset).
Nevertheless, if it is working OK with the Passion loader and channel S/W, fair enough.
__________________
Old 14-07-2008   #9
My System: Passion+
@surfgeek
The kit you bought at Maplins is the receiver the Passion + one?
If so, did the update work ok. I tried to update one today (Passion+) and it did not work. There is no update on the Fortec website for the + version.
lopos2000 is offline   Reply With Quote
Old 15-07-2008   #10
surfgeek's Avatar
Originally Posted by lopos2000 View Post
@surfgeek
I had to try a number of times, I have a number of issues with my usb stick not being rcognised properly. But yes it is the new Passion + with PVR and the files I used is the current file for Passion HD. Cheers
The Following User Says Thank You to surfgeek For This Useful Post:
lopos2000 (16-07-2008)
Old 15-07-2008   #11
Llew's Avatar
Originally Posted by surfgeek View Post
I But yes it is the new Passion + with PVR and the files I used is the current file for Passion HD. Cheers
So the files for the non-pvr Passion do work on the Passion+.
Fortec brought out the Passion Innovation before the Passion + ( I thought they were one and the same until I checked Fortec's site), and that is the one with the different chipset. For a moment I thought you might be loading software into the wrong box. Panic over
__________________
Old 16-07-2008   #12
My System: Passion+
Thanks surfgeek for your info. Will try it out later.
Old 17-07-2008   #13
My System: Fortecstar passion+ with 65cm motorised dish
Hi Llew, I also have a passion + and cant seem to be able to load new firmware. The firmware i have at the moment is v1.0.0
I have tried 2 different usb memory sticks and the software wont load.
Is the firmware the same for the passion +?
also i dont have all of the parameters available like the other guy to enter the itv hd settings to manually search for itv hd.
Neil.
outerdelta is offline   Reply With Quote
Old 17-07-2008   #14
My System: Passion HD Diablo CAM Sky Star 2 PCI Sky +
Neil.
I don't know for sure but doubt that the original Passion HD firmware would be compatible with the Passion +. A closer match is likely to be the Innovation software as the boxes have almost identical specs. The Innovation has 2 embedded card readers as well as 2 x CI slots whereas the Passion+ only has the 2 x CI slots, apart from that and visual appearance they look to be identical. There is new firmware available for the Innovation on the FS web site.
Edit - outerdelta has just noticed the actual Passion+ FW is also available (listed as 'HD Passion+' just to confuse everybody).
Ratchet is offline   Reply With Quote
Old 17-07-2008   #15
I have just noticed a new update on the official web site for the passion+. I will try that now.
Thanks.
Tried this and it works, the passion+ has its own firmware.
Old 18-07-2008   #16
My System: Passion+
I can confirm it. I tried it out and it worked.
Old 19-07-2008   #17
mattybee's Avatar
My System: 65cm Mesh Standard Dish, Fortec Star Sigma Reciever, Standard LNB, Samsung 42" LCD TV
Maybe i'm a bit slow here but i'm sure i read that ITV HD was only availble on Freesat!?!
Or has things changed?
mattybee is offline   Reply With Quote
Old 19-07-2008   #18
surfgeek's Avatar
ITV HD is available on your Passion, needs latest updates. Just excluded from Sky
Old 19-07-2008   #19
Llew's Avatar
It's not exclusive to Freesat. It's open to any HD receiver capable of setting the vpid manually ( that excludes the Sky HD box).
__________________
Old 23-07-2008   #20
My System: FORTEC STAR PASSION HD
Itv hd on fortec star passion
Hi Llew
I note a number are having trouble getting ITV HD to list I had the same problem until after downloading update and factory reset I chose UK & RIO instead of ALL CHANNELS and it listed
Briamb is offline   Reply With Quote
Old 23-07-2008   #21
Llew's Avatar
Just the ticket Briamb. I only use the All Channels list myself, had to enter the ITV parameters manually with an earlier channel list if I remember.
__________________
[IMG] code is Off
Forum Jump
All views and information expressed in users' communications and profiles represent the opinions of the users concerned and do not represent the views of Satellites.co.uk. All images and
