Passion HD software upgrading problem?High Definition FortecStar HD satellite TV receiver help and support forum. | |
| Member Join Date: 21-09-2008 Location: Nuneaton
My System: Fortec star passion hd and maplins dish package, including F/S FSKUVN |
i inadvertently upgraded the firmware without upgrading the "loader" is there a "get out of jail free" card for this? cheers Andrew owner of one of those Maplin kits where you had to twist the LNB contrariwise to get a signal but i now have 67 strength and 100 quality for astra 2, also 67/92 for astra 1 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | And what was the result? The box not booting up? If that's the case, switch off the box, plug in a USB stick with the loader file on it and switch back on. You should get 'file read' on the front display, then 'file 1'. Press the box's 'OK' button and you see '1 Loader'. Press OK again and it should go through the loading sequence and end with 'Power off'. Switch off the box and remove your stick. It should now boot up with the loader, after which you can load the firmware. Llew | ||
My System: Fortec star passion hd and maplins dish package, including F/S FSKUVN | no boots up fine , but am i missing something, can i upgrade the bootloader now as if i hadnt boobed? andrew | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | As it's booting up, your loader should be intact. Just update with the latest loader file, then your firmware. | ||
| | #5 | ||
| Member Join Date: 15-11-2008 Location: England
My System: Fortec Passion +HD Panasonic LCD | .Hi New member,Have just purchased the Passion+and thanks to this site have learnt a few things trawling through past posts,my question is I have downloaded the latest update for my box and after unzipping do I send the unzipped folder or do I send the file inside the folder to my stick drive,advice needed before I complete the update will be grateful.... | ||
| | #6 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Just have the .dnl file on your stick tjl. The Passion won't recognise files or folders without that extension. Llew | ||
| The Following User Says Thank You to Llew For This Useful Post: | tjl (20-11-2008) |
| passion, problem, software, upgrading |
