Epg help neededHigh Definition FortecStar HD satellite TV receiver help and support forum. | |
| Member Join Date: 17-11-2008 Location: UK Essex
My System: Passion + and Dell vostro 1500 laptop |
Hi, this my first question to the forum, I have just bought a passion + reciever, my first satelite system, so I am a novice. I have put the latest loader on and also the latest firmware. All this seems to be successful, I have BBC HD and ITV HD (when they broadcast) I am really pleased with the unit with the exception of the EPG system, it sems all but useless. Only a few channels sem to have any info and then only or the next hour or two. I have tried the seven day EPG button but no info shows. I have followed suggestions on the forum, left the EPG on but it does not populate. Any ideas out therewhat I m doing wrong or not doing ?? thanks Jeff | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Do a factory reset and choose 'UK Channels'. This works for my Passion HD, should be the same with the Passion HD+. Llew | ||
| The Following User Says Thank You to Llew For This Useful Post: | jeff golding (24-11-2008) |
| | #3 | |||
| Member Join Date: 23-11-2008 Location: UK
My System: Fortecstar Passion+ | I left the P+ on Brit Shorts (the blank one) and it did eventually populate the EPG but very slowly and all was quickly lost when I had to do a power down. It did stay (with the 'UK 7day EPG' set to on) and 'now and next' did come up on some channels once they were selected and tuned to. | |||
| | #4 | |||
| | #5 | ||
My System: Passion + and Dell vostro 1500 laptop | Many thanks for your advice, will try it with the EPG off. Emailed fortec star but no reply, dont fully understand all the other settings you suggested. Merry Christmas. jeff | ||
| | #6 | ||
My System: Fortecstar Passion+ | Seems to need 'Brit Shorts' tuned in *and* 'user time' set to off (or current time) before it will populate. Setting a timer event seems to autoset 'user time' to 'on' which may be ok providing the P+ has already found it's time from a channel, which it can't do if it's booted with 'user time' set to 'on'. All completely unacceptable, but it's a 'workaround' for now. | ||
| epg, needed |
