Problems using USB HD with the Passion +
High Definition FortecStar HD satellite TV receiver help and support forum.
Old 02-01-2009   #1
My System: Passion + with seagate 500gb HD via usb
Hi, Newbie here.
I have just set up a Passion+ on my old sky dish and it all appears to work ok...except the USB HD. I got it from Maplins and its a seagate 500GB thatb they said they have tested it with.
I is recognised but is hit and miss when you go to USB and try to view a recording (or sometimes when trying to record / timesift) It says USB not ready or not FAT 32.
Any suggestions?
Nick Hood is offline   Reply With Quote
Old 02-01-2009   #2
tjl
tjl's Avatar
My System: Fortec Passion +HD Panasonic LCD
Originally Posted by Nick Hood View Post
Hi, Newbie here.
Any suggestions?
This could help
Passion Plus Hard Disc Problem
tjl is offline   Reply With Quote
Old 02-01-2009   #3
My System: Humax 5400irc 80cm Dish Invacom 0.3 LNB ToH 3.3 5.7. P4 Xp home 3.2 pro.
Hi Nick Hood,
Try this, (Event Recording Bug Fixed).
Bbigfoot is offline   Reply With Quote
Old 02-01-2009   #4
Thanks all,
Will try both options and let you know if it works.
Nick
Old 07-01-2009   #5
Nig
My System: Fortec Passion and Fortec Innovation with WD elements HD 1tb
Nick, I use an Innovation but I don't think it makes much difference. I have the same prob sometimes. One easy way to cure it which works for me is to connect the harddrive to your computer. Then run checkdisc on it (My computer/rightclick -properties/Tools/Error checking) Then reconnect to your Passion+ and hope for best. Nuisance to have to do this tho when in a hurry to record a programme.
Nig is offline   Reply With Quote
Old 26-02-2009   #6
My System: fortec passion+
passion+ hdd problems
I have also recently bought a passion + STB, the box is great and it does record to HDD but mine won't stop spinning (it has it's own psu) even though the HDD external power control on the box is turned on. So, as I don't record much, I decided to buy a 16gb pen drive (Emtech), it doesn't like it says not ready or not fat 32, have formatted it in the box and also in my PC. The drive works fine with the pc. I had an 8gb pen drive and that works fine. Can anybody help. Thanks.
malchall is offline   Reply With Quote
Old 28-02-2009   #7
My System: Fortecstar Passion+
The current software powers up to select the rear USB socket, so if you attach a drive to the front socket you need to switch the STB to the front socket. If the drive still isn't recognised try switching the STB between the front and back USB sockets to force and initialization (reading of the FAT).
icarusi is offline   Reply With Quote
Old 02-03-2009   #8
Thanks for that, I have already tried it. I would ideally like to return to using my hard drive does anyone know how to stop it spinning when it is not in use? I have the ext hdd control turned on
Old 02-03-2009   #9
is 113 the latest software for the passion+?
Old 06-04-2009   #10
My System: Fortec Star HD Digital Satillite System Passion+ with a Maxtor Basics external hard drive.
I also have a Passion+ it will record direct onto the hard disc but not with the timer it will switch on ans switch off but nothing on the hard disc.
Peter Nash is offline   Reply With Quote
passion, problems, usb
[IMG] code is Off
