Freesat info and freesat receiver info for you | |
| Guest
Posts: n/a
Here is some info on freesat uk for you the main website is _www.freesat.co.uk all channels are FTA there is two HD channels BBC HD & ITV HD to access ITV HD you must press the red button when prompted when viewing itv 1 SD when a program is available in HD, Freesat has it's own EPG and i have a humax freesat receiver myself this can also be used on other satellites and has diseqc controls and can be used with a motorized dish, Apart from the humax the other freesat receiver can not add channels so can only be used on freesat, Five & fiver & five us will be on freesat very soon (within 3 months) when they get space on astra 2d and will leave their current home on astra 2c this has been confirmed to me by ch5 tech department, At the moment the receiver you can get are below use the links to see photos of the receivers and the user guides for them: Humax foxsat-hd : _www.humaxdigital.com/freesat/ Grundig HD & SD : _http://www.grundigdigital.co.uk/ Bush SD & HD : _htp://www.bushdigital.co.uk/ Goodmans SD & HD : _http://www.goodmansdigital.co.uk/ There will also be a panasonic tv with freesat built in which is due out very soon : _http://www.panasonic.co.uk/html/en_GB/711712/index.html#anker_711712 Last edited by mhku; 10-05-2008 at 03:17 PM Reason: removed live links | ||
| The Following 2 Users Say Thank You to For This Useful Post: | evans20 (23-06-2008), the-cod-father (28-06-2008) |
| | #4 | |||
My System: TM6800HD+TD110+StabHH90 motor,TM1000D+Orbital 1m Multifeed 16E,23E,28E.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox. | You need to be able to get a signal from Eurobird 1 and Astra 2D at the same time. Have a read of this thread:- Humax Freesat postcode?
__________________ | |||
| | #5 | ||
| Member Join Date: 15-09-2008 Location: North East England
My System: Fortec Standard Definition Kit (as sold by Maplin) |
I'm lost...what is it that I can get through FreeSat that I can't get through any receiver picking up FTA channels from Astra 28.2E? (Apart from the HD channels if I've got a SD receiver) | ||
| | #6 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | A seven day EPG is one major advantage, soon with DVR facilities, also dedicated text and interactive service. If you are not interested in either of those, then nothing much extra.
| | #7 | ||
I set up my first satellite system only yesterday evening, so I haven't investigated it much yet (and I'm at work now). I seemed to have an EPG - are you saying that it wouldn't show me programmes much into the future? And if I add a new channel that's not in the presets, will I get EPG information at all? | ||
