What receiver with the best tuner sensitivity
If you live outside the reception footprint of a satellite and would like to, or can already receive services, post your questions or information here.
Old 09-10-2007   #1
patmos's Avatar
My System: 1.2 m Eurostar dish KU band W3A, 3.1 M mesh C band on the arc from Atlantic bird3 to Measat 3, 1.5 m offset on PAS 10 KU, 70cm Offset on Eutelsat W2, 2.4m prime (Dual LNB) on PAS 7/10 @ 68 Deg E and Thaicom @ 78 Deg E STARTRACK NC707 Plus, Skyst
It is well known and I have experienced it, not all receivers behave the same with respect to low signal level. For example we tested the metabox 3 tuner to be poor yes poorer that the metabox 1. I am in fringe area and 1 dB can make a big difference, can someone tell what is the best FTA tuners.Has any test been conducted to know at what Eb/No or C/N these tuners locked or unlocked.I do not rely on advertisement that always tells that their product has the best sensitive tuner. I need help from you who have had the chance to test your receivers with regard to signal conditions.
patmos is offline   Reply With Quote
Old 09-10-2007   #2
keano's Avatar
My System: 2.4mtr Channel Master Dish, Fracarro Penta 85cm Dish, 64cm Traix Dish with 4 multi LNB'S Sky HD, Dreambox 800, Dreambox 500, IPBOX 250, Sky HD and a mad wife !
Hi m8,
Over the years I have owned many receivers and for me nothing works better on weak signals then the Technomate range.
I still have my old DACI 5500 for sat hunting and tuning in the dish.
I used to own a Technomate CIP 5500 and this again was just like the DACI 5500.
The newer range of Technomates have a even more sensitive tuner in them.
Hope this helps.
Keano
keano is offline   Reply With Quote
The Following User Says Thank You to keano For This Useful Post:
patmos (09-10-2007)
Old 09-10-2007   #3
wod
wod's Avatar
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+
also vantage receivers are good with very quick blind scan and tuner quality
The Following User Says Thank You to wod For This Useful Post:
patmos (10-10-2007)
Old 10-10-2007   #4
Turok's Avatar
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband!
buy the homecast 5101 ci,it has the sensitvest tuner ever tested!
fastest blindscan on market at the moment ist the new smart mx 04 fta, 5 minutes for hotbird,and only 3 minutes for complete scan of 40,5 w cband!
technomate,is the same then clarc tech,i have this reveiver in the past ,and sold it rapidly,coz,the signal strenth,showing always good signal 90%,no metter,is signal realy good or not
Turok is offline   Reply With Quote
The Following User Says Thank You to Turok For This Useful Post:
patmos (10-10-2007)
Old 10-10-2007   #5
My System: dish1.1 with 4 lnbs&humax5400z& dreambox5620& dreambox500s&sky
humax 5400z is very good
moridark is offline   Reply With Quote
receiver, sensitivity, tuner
[IMG] code is Off
