26 East | |
| Information Exec Join Date: 07-05-2007 Location: South Midlands, UK & Lanzarote, Canary Islands, Spain
My System: 43cm Dish, Sky Plus v2, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N |
Another interesting query. Here goes, regarding 26 East Badr 3/4. Tp 11 - 11919 H shows an individual beam mbc not receivable in UK. I can pull this in no problem with an 88cm. (flysat & lyngsat show the footprint for middle east only. Is this a mis-print or is that Tp on the BSS beam?? Are most of the Middle East, BSS and FSS beams receivable in the UK and what dish sizes are recommended? Cheers | ||
My System: 43cm Dish, Sky Plus v2, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N | Only 25 miles from you as it happens | ||
| | #4 | |||
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | I rather suspect that is a convenient work of fiction rather like the Astra 2D coverage area so that the MBC channels can continue to transmit fta....
__________________ | |||
| | #6 | ||
My System: 43cm Dish, Sky Plus v2, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N | Understand but kingofsat are showing it as on the BSS beam | ||
| | #7 | ||
My System: 43cm Dish, Sky Plus v2, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N | North, Banbury | ||
| | #9 | ||
My System: 43cm Dish, Sky Plus v2, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N | Ok cheers, in which case I am very impressed with the signals being pulled in with a TD88 & Invacom LNB for testing. (78% signal / 99% Quality) on 11919 Tp11. Technical - 77dBuV, BER 2E4, Noise margin 5 | ||
| | #10 | ||
My System: 43cm Dish, Sky Plus v2, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N | So...what's the conclusion. Is Tp11 mbc 11919H on a tighter footprint away from the Uk? Clean signals picked up in all weather conditions with a 88cm dish & invacom. Is it that the better LNB is pulling it in? | ||
| | #11 | |||
| Regular Member Join Date: 20-07-2007 Location: London
My System: Channel Master 1.2m and 1.8m, Vantage VT-X221TS CI and 8000s, Technomate V-Box II, 18" Superjack actuator | Footprints aren't conclusive when you are outside the intended footprint! They're only ever a general guide. I would say that there is a large inaccuracy with that beam though. Some transponders are much stronger than others when you are well outside a footprint. | |||
| | #12 | ||
| Member Join Date: 02-07-2005 Location: Essex
My System: 104cm Gibrertini 45 east to 58 west C120 Inverto 0.3 Andrews Feed horn TM5200usb Plaza ST100 TM1500CI+Super | This beam on Badr 4 11919H 27500 is much weaker than the other transponder's on this satellite & it is no myth that the beams on this are restricted same as with Astra 2D in Southern Spain reception is next to impossible without a very large dish, To get good reception on satellites that do not have a footprint in your area a good match with Lnb & Dish is essential sometimes it can work ok with a 88cm dish with a well matched Lnb & in the same location a 104cm dish with the wrong Lnb will get nothing from MBC on Badr-4, The Focus of the Lnb onto the dish makes all the difference. The better Lnb will pull in the signals if the Lnb is matched to the dish {re focus of the entire dish is spot on & the feed horn on the Lnb is round on a dish that is higher than it is wide so that from the Lnb arm the Lnb see the dish as a circle as opposed to an elipical horn Lnb used for a dish that is wider than it is high like a Sky mini dish or an eliptical raven dish. Last edited by william; 09-06-2008 at 12:38 AM | ||
| | #14 | ||
They may be the one's that we cannot receive in Europe ![]() I have suggested to flysat that 11804H 27500,11862V 27500,11900V 27500 are all on a tighter footprint either BSS or steerable beam, flysat agree & have adjusted their footprint maps as for MBC this is more difficult during the day but ok in the evening. | ||
| | #15 | ||
| Regular Member Join Date: 25-04-2005 Location: Austria
My System: 1,25 Fibostop Jäger Smr 1224 Dual Axsis Echostar Dvr 7000 Monterey 140 Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesch for cband! | Hello ! i have tested now the bader 6 satelite,with the gregory 1,25m on 3 transponder i have no signal all others working,but some are very weak, 11806 V, and 11900 needs in eastern germany 3,70m Fullsize dish,i got reports on german satelite board! on 11806 V i have Signal here,with the gregory dish on 11900 V still no signal,this are the transponders i can receive,tested with cloudy sky this morning now its sunny,in night time normaly it works much better,i will see..! signals weakest 34% .45% for 11806 V,and the rest 6D in Dvb 2000 like on Astra! | ||
