Paphos Reception | |
| Specialist Contributor Join Date: 28-06-2004 Location: southern england, Berkshire
My System: Technomate 1500ci+, skystar2,1.1m dish .3db bluline lnb,Sky, Span 58W to 42e with trees bare! |
Can anyone advise what birds are available in pafhos on 1.1m dish. Just looking around there dont seem to be many motorised systems either. Not interested in the 3m systems for sky but is a motorised system worth the effort? Thanks | ||
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | 70.5E (some), 53E, 42E, 39E, 36E (some),33E, 26E, 16E, 13E, 10E, 9E, 7E, 5E (European Beam), 4W, 7W, 8W, 12.5W and 15W, should all produce some channels Ross, you can always use a slingbox for UK based channels if you have broadband.
__________________ | |||
| Specialist Contributor Join Date: 28-05-2003 Location: Stuttgart (48.79N/9.19E)
My System: Kabel BW | Allow me to add some: 80E (some)/75E/62E/30.5E (probably none anymore since its power reduction)/21.6E/19.2E (some of the strongest)/1W (some of IS 10-02)/43W (very low on your SW horizon) From 4W only the Middle East Beams can be received. The European Beams require huge dishes. Since this is an often used marketing trick i should mention that a 1.1m dish is not 100*110 but 110*120 for example. Always the smaller diameter gives the name not the bigger one.
__________________ I demand: Pay-TV subscriptions worldwide available - with any receiver - just like print magazines ! Free access for free citizens now ! | ||
| Regular Member Join Date: 21-10-2003 Location: Kent UK and Cyprus
My System: Technomate 1500 80cm motorised Smart titanium 0.2 lnb in both Kent and Eastern Cyprus | Hi Rossy I,ve just motorised my 80cm in cyprus and i get all the above sats except 1W.Thor 5 is just about to start at 1W so the signal should improve. And yes it is worth going motorised Regards | ||
| | #5 | ||
My System: Kabel BW | Thanks for your reply odellp. May i ask where in Cyprus you are located and what is your reception window ?
| | #6 | ||
My System: Technomate 1500 80cm motorised Smart titanium 0.2 lnb in both Kent and Eastern Cyprus | Hi Deepbluesky I am in eastern cyprus and i receive from 15W to 75E if thats what you mean by window | ||
| | #7 | ||
My System: Kabel BW | Yes, that's what i have meant.
| | #8 | ||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorkshire, uk
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | how big a dish can you go to ? as a 1.8m dish on a polar mount setup would be even better than a 1.1m as you would get some channels from 19e, etc | ||
| | #9 | ||
My System: Kabel BW | By the way, in Lemesos/Limassol is a DXer that gets full Sirius 4 on his 2.1m. The footprint is far too pessimistic.
| | #10 | ||||
__________________ | ||||
| | #11 | ||
My System: Technomate 1500ci+, skystar2,1.1m dish .3db bluline lnb,Sky, Span 58W to 42e with trees bare! | | ||
| | #12 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | LOL, have meter will travel.
