Ku band satellites with a 10 metres dish | |
| Member Join Date: 11-04-2008 Location: Spain
My System: Satellite Receiver: a Mvision. | How many Ku band visible satellites do I receive in SE Spain with a 10 metres satellite dish from 80 degrees West to 75 degrees East? Explain there with words for each Ku band satellite, basing of this model: Satellite - Orbital position (in degrees) Dish size needed. Hybrid C- and Ku band satellites also are welcome! If a satellite is launched, please modify the list! Thanks. | ||
| | #2 | |||
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | No-one is going to make that sort of list for you. ![]() Sufficient to say that a 10m dish would give you most if not all of the European sats, and maybe a few of the C-band Yank birds near 61W. (80W will be below your western horizon)
__________________ | |||
| The Following User Says Thank You to Analoguesat For This Useful Post: | patente3 (13-04-2008) |
| | #3 | |||
| | #4 | |||
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | My original comment stands no-one will make that sort of list up. You want the info - you make the lists up - although this may help: http://www.flysat.com/satlist.php Its all academic anyway - its unlikely you would be able to afford a 10m dish
| | #5 | |||
My System: TM6800HD+TD110+StabHH90 motor,TM1000D+Orbital 1m Multifeed 16E,23E,28E.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox. |
Robbo
| The Following User Says Thank You to Robbo For This Useful Post: | patente3 (13-04-2008) |
| | #6 | ||
| Information Exec Join Date: 07-05-2007 Location: South Midlands, UK & Lanzarote, Canary Islands, Spain
My System: 43cm Dish, Sky Plus v2, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N | You'll need an empty field to site it | ||
| The Following User Says Thank You to satelliteman For This Useful Post: | patente3 (13-04-2008) |
| | #7 | ||
| Amo Amas Amant Admin Join Date: 18-11-2004 Location: NW England (Siberia)
And a few hundred cubic metres of concrete to fix the mount to ![]() Oh and a red flashing light to warn the low flying aircraft
__________________ War does not determine who is right, it determines who is left! Formerly toppervte33h whose six pack has turned into a keg Help support this web site by making a donation Or use other options to help support Sats UK Show Your Support by clicking the button ![]() Thank you. Freddie Flintoff is back | ||
| The Following User Says Thank You to Topper For This Useful Post: | patente3 (13-04-2008) |
| | #8 | |||
| Member Join Date: 18-10-2005 Location: BE
My System: Twin monoblock and twin LNB on 80cm transparant dish rigged for twin reception + TopField TF 7700 HDPVR + TwinHan VisionDTV | 10m is indeed enormous. I've only once had the privilege of working with one, and even the secondary 3m we were using was just small in comparison. Note that the pointing accuracy of something this big is also not to be ignored. We had a special seeking algorithm to point it exactly at the satellite we wanted to test. (Our goal was In Orbit TeSting) | |||
| | #9 | |||
My System: TM6800HD+TD110+StabHH90 motor,TM1000D+Orbital 1m Multifeed 16E,23E,28E.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox. | ![]() The theoretical 3dB beamwidth of such a beast is in the region of 0.18 degrees. Total surface area of 78.5 square metres. I can't even begin to imagine what the mount looked like, but it must have been pretty solid.
| | #10 | ||
My System: Twin monoblock and twin LNB on 80cm transparant dish rigged for twin reception + TopField TF 7700 HDPVR + TwinHan VisionDTV | | ||
| | #11 | ||
| Super Moderator Join Date: 13-08-2007 Location: Middle East - Israel
My System: Satellite Dish 1.6m Hotbird 13E, DreamBox 7000S with Gemini 4.5.0; Dish 1.2m Amos 4W, Nokia 9600S; Nokia 9800S; Hauppauge Nexus-S PCI Card ![]() He battled for 3 days against the Tux and won! Hurray!! | Just wondering if you can estimate the dish size used at Yes Israel HQ Is it anywhere near a 10m dish? Yes Israel Package on Amos 4W Post #8 | ||
| | #12 | |||
| | #13 | ||
My System: Satellite Dish 1.6m Hotbird 13E, DreamBox 7000S with Gemini 4.5.0; Dish 1.2m Amos 4W, Nokia 9600S; Nokia 9800S; Hauppauge Nexus-S PCI Card ![]() He battled for 3 days against the Tux and won! Hurray!! | | ||
| | #14 | ||
| Regular Member Join Date: 25-04-2005 Location: Austria
My System: 1,25 Fibostop Jäger Smr 1224 Dual Axsis Echostar Dvr 7000 Monterey 140 Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesch for cband! | Hello! Siemens,produced in the 90s 10 Meter dishes,but only for telcom operators,what brand you are using,when i was visiting the thaicom uplink in march,this year,i saw a 15 Meter dish,with auto trucking in real! how do you want to motoreized your dish? what brand it is? this motorsoultion,is very expensive 15000€ or more,i can imagine.) long time ago,drdish told in his show,in europe,there are not to much enthusiast,to make,this experience,what happens in kuband! the reunion beam should work on 16 east eutelsat F>2 Amos,east digital,middle east channel working with 4,5 meter dish, but not the videogurard package from israel,when we see reports from turkey reveiving astra ,with 10 meter,in the east part of the country,the signal is very unstable,depens on the weather! make,your experiment,in cband,then,normaly you sould reveive more channels on 37 east ,with this dize size then on kuband,36 east eutelsat w4,is working with 3 meter channel master here,and also 2 of the packsat freqencys, same with 3,60 m mesh but not much programm on this satelite! turksat 1c very weak,will be soon replaced with turksat 2A,and depends what kind of spotbeam the using,you dont need a bigger dish then 3 meter anymore,here on my location,in spain,where you leave 16 east reunion beam,the footprint map says,is much stronger,then here in central europe,maybe you have luck,with amos east,but there is only one analoge israle channel on this stalite,to other was swiched off last year ps:with out motor,this antenna,you can only fix on one satelite!! | ||
| The Following User Says Thank You to Turok For This Useful Post: | divibi (31-08-2008) |
| | #15 | ||
My System: TM6800HD+TD110+StabHH90 motor,TM1000D+Orbital 1m Multifeed 16E,23E,28E.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox. | Well, I was just looking at the size of the windows and they look about a meter wide, so x by 3 plus the bits in between, it looks like a tiddly 5m. You know what size it is don't you Dish, and I'm going to look silly.
| | #16 | |||
My System: Satellite Dish 1.6m Hotbird 13E, DreamBox 7000S with Gemini 4.5.0; Dish 1.2m Amos 4W, Nokia 9600S; Nokia 9800S; Hauppauge Nexus-S PCI Card ![]() He battled for 3 days against the Tux and won! Hurray!! | I was hoping that someone can give an educated estimate. | |||
| | #17 | ||
| Regular Member Join Date: 28-05-2007 Location: Terre Rouge, Mauritius
My System: 1.2 m Eurostar dish KU band W3A, 3.7M C band on the arc from Atlantic bird3 to Measat 3, 1.5 m offset on PAS 10 KU, 70cm Offset on Eutelsat W2, 3.4m prodelin prime fibreglass on Intelsat 906 64 Deg E STARTRACK NC707 Plus, Skystar 2 DVB card | 15M Vertex Cassegrain Antenna. Very very heavy motors.Beamwidth very small.Gain at C band around 58 dB | ||
| | #18 | ||
My System: 1,25 Fibostop Jäger Smr 1224 Dual Axsis Echostar Dvr 7000 Monterey 140 Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesch for cband! | you have,the right cband tripod holder,for this antenna,calculating the right f/d yet? can you post a picture of this 15 m antenna? normaly cband must work very well,on full size dishes ! | ||
| | #19 | ||
| Specialist Contributor Join Date: 28-05-2003 Location: Stuttgart (48.79N/9.19E)
My System: Kabel BW | Just a comparison: A mini Mabo 1.85m in front of a 6.30m for Astra 2D in Crete: http://www.saloras.gr/images/gallery/big/16.jpg And here are some more photos: http://www.saloras.gr/index.php?action=12 I don't dare to think about a 10m or 15m !!
__________________ I demand: Pay-TV subscriptions worldwide available - with any receiver - just like print magazines ! Free access for free citizens now ! | ||
